Question about Dryers
85094 02 We have lost the back cover which I think enables the remote, how can we fix, or get another remote to operate the fan. Please help.
    Genius:
  • 1,617 Answers
Not having the back cover on the remote transmitter will not enable the remote. What make/model fan do you have?
Posted on Jul 16, 2013
Directions to reprogram hunter 952g
You need remote control.
Go to your circuit breaker or fuse box, and turn off the power to the fan you will be programming.
  • 2 Turn the fan's remote control over, and remove the battery compartment cover. Take out the remote's 12-volt alkaline battery, and set it aside.
  • 3 Match the DIP switches inside the remote's battery compartment with the DIP switches on the fan's receiver unit.
  • 4 Reinsert the 12-volt alkaline battery into the remote's battery compartment, and replace the battery compartment cover.
  • 5 Go back to your circuit breaker or fuse box, and turn the power to your fan back on.
  • 6 Press the "Hi," "Med" and "Lo" buttons on the remote control in quick succession. Complete this step within 20 seconds of completing Step 5. The remote is now programmed and ready to operate your fan.
  • Sep 06, 2012 | Hunter Dryers
    Need to program Hampton Bay Ceiling fan remote control CHO88T7030T, HELP!
    Change the battery. This is the first step when troubleshooting a ceiling fan remote. The easiest fix to any remote control problem begins with battery replacement. A 9-volt battery is needed to operate all Hampton Bay ceiling fan remotes.
    Check the light switch used for the ceiling fan. The light switch found on the wall must be in the "on" position. This allows the ceiling fan to be operated by remote control
    Re-program your remote. If battery replacement fails to get your remote working again, try to reprogram the remote. Open the battery cover you will see 4 dip switches. These switches must be set to the same position as the receiver on the fan. Use the screw driver to move the dip switches either up or down.
    Follow the previous step to change the frequency if the ceiling fan is randomly turning on or off. Other electronic devices such as garage door openers can interfere with the ceiling fans receiver, causing it to randomly turn on or off.
    Sep 10, 2011 | Televison & Video
    My Callaway II ceiling fan transmitter shows that air is being pushed down. However, the ceiling fan is actually pushing air upward. I've tried everything I can think of to get the transmitter and...
    If I recall, this fan has no external switches that can be operated - all of the fan and light functions are controlled by the remote alone. If this is indeed the case, there is little that can be done outside of hoping the problem is with the remote itself. If that is the case, replacing the remote is likely to be cheaper and less labor intensive - that is if you can find one.
    From what I have read, this fan is no longer in production nor available for purchase. You may have luck bringing the remote to Home Depot - the main (possibly the exclusive) distributor of the Hampton Bay brand to see if they have fans on display that make use of remotes for fan and light control. If so, try to see if all your remote functions work. If you find that the reverse function no longer works - you should ask the sales associate about how to go about ordering a replacement remote. If the remote fails to work at all, you can 1) try a "shot in the dark" about ordering a an exact replacement remote - with the hopes that the remote itself is defective - rather than the paddle fan, or 2) start new by buying a new paddle fan with hardware switches for fan speed, direction and light operation AND a remote control module to perform a whole replacement of your existing paddle fan.
    The "add on" remote control gives you many of the benefits of the remote only fan - but also provides a "back up" way to operate the fan should the remote or module fail. Had this been the style you have currently, you could operate the fan by hand until the remote and / or ceiling module was replaced.
    I hope this helps and good luck. Please rate my reply. Thank you.
    Jun 01, 2011 | Hampton Bay 46056 Callaway II Ceiling Fan
    Casablanca Stealth Fan - Unresponsive To Remote
    I fixed this myself by upgrading to an Advan Touch unit. Details here: http://www.casablancafanrepair.com/HTMLFiles/ do_it_yourself/ComfortTouchCommonRep/CTToItConvert6-12- 07Web/SM_CTToAdvanConvert_P1.htmI purchased the P-RMM CT to AT Converts Comfort-Touch to Advan-Touch upgrade kit from http://www.fanmanlighting.com/shop/pc/viewPrd.asp? idcategory=56&idproduct=966The fan man was helpful and my parts reached me in 2 days, normal shipping!
    Jan 02, 2010 | Dryers
    Hello, I need code for model UC7067RC Hampton Bay ceiling fan. There are numbers 1234 and remote does not work Please help. Thanks
    Call Fan Man Lighting in Minnesota at 1-866-600-3267. They have 30 years experience and helped me with my UC7067 problems.
    Oct 14, 2009 | Universal Remote Control Hampton Bay...
    How to program 9242 remote to work with my Bell
    The following instructions will enable the Bell 9242 remote to operate a Bell 5900 receiver. Remove back battery cover. Just below the "Bell" lettering on the front of the remote, there is a half moon shaped plastic insert "key" that slids out downward. Turn over the plastic key and reinsert back into postion and replace the battery cover. Success!
    Oct 13, 2009 | Bell Televison & Video
    Remote controlled ceiling fan has mind of it's own.
    I have the same fan. The fan and the remote have some "jumpers" which allow you to change the codes, useful if someone else nearby has the same fan. You can see the jumpers inside the remote, open the back cover... you'll see "4 3 2 1" on the circuit board. Unfortunately you'll need to dismount the fan to change its jumpers, they need to be the same as the jumpers in your remote (which you can move around pretty easily).
    Jul 01, 2009 | Hunter Fan Co. 60 In.Brushed Nickel...
    Lost conection between fan and remote
    There seems to be a problem with the upper part of these remote controls. They work for a while and go out. I have replaced 5 for people in the last 3 months. The store where most of these were purchased gave me new fan, and let me bring back the parts that were bad. I did not have to assemble another fan, just change the bad receiver on the remote. I hope they work as well with you. I think they know there is a problem with them.
    Oct 09, 2008 | Hunter 52" Ceiling Fan With Light And...
    Hampton bay altura 68
    Read this on another thread - apparently the solution came from HB's tech support.
    Turn the fan speed to HI and then select Reverse.  You should hear a "click" and see the fan reverse direction.  It seems that the reversing relay only works when the fan speed is set to HI.
    Good Luck!!
    Two Metre Man
    Jul 12, 2008 | Hampton Bay 24002 Ceiling Fan
    Hampton Bay is a Home Depot brand name. Most (not all) have a lifetime warranty. I think that if you take it to the nearest HOME DEPOT store, WITH the receipt they will help you by fixing or replacing the remote.
    We have our home completely covered by HAMPTON BAY fans and one went out after several years and they replaced it no charge for another fan.
    We have had great success with HOME DEPOT products and shop there often. Our preferred store is the one in Mesquite, TX on I635 East.
    Feb 05, 2018 | Universal Remote Control Hampton Bay...
    Dryers Logo
    Top Dryers Experts
