Question about Frigidaire Stove / Oven / Range Cooktop BSQ - 318079378
Fridgidare model number mef305pbwf eyes stopped working
Can I fix them
  • Official Brand Answer
  • 4,342 Answers
Hello James - Thank you for your question! Let's try resetting the range by either unplugging it or flipping the household circuit breaker to the off position. It is important to wait roughly ten minutes and then turn the unit back on. If resetting the power does not correct the issue, your appliance could be experiencing a communication error with the EOC (electronic oven control), a potential wiring failure or faulty elements. In that case, a certified technician would generally replace the faulty part after proper diagnosis.
Posted on Jul 17, 2013
Where are the fuses on a fridgidare range,glass top,everything works except thesettings for my stove doesnt light up
Thank you for your post, friend!
Based off what you have described the settings on your Frigidaire range do not light up and you would like to know the location of fuses. There are no fuses within your range, if the control panel is not lighting up it could be a short within your panel and that may need to be replaced. I would recommend having a professional technician out to disassemble your range and replace any electrical components. This will protect you from any personal injury and future issues with your range. Hopefully this information is helpful. -Matt
Mar 10, 2015 | Frigidaire Stove/Oven/Range Black Glass...
My cooktops eye stopped working
Is the oven not working as well? If it isn't working check your breaker for that appliance.
Oct 06, 2012 | Frigidaire FEC36S6EB
One of the burners ignition will not turn off - it continually is sparking - i have to turn off the elec supply to stop the ignition ? any ideas
Hi and welcome to FixYa, I am Kelly. On the burner your having problems with the ignition control switch located in front of the gas control vale on the stem has failed. These are cheesy little switches that are thin ceramic with nothing but 2 strips of copper inside them. One piece is fixed and the other piece is movable by the ceramic switch cam. If the movable copper arm or fixed copper strip gets bent the ignition will not shut off. Also if the ceramic cam of the switch fractures it will cause the switch to stay actuated. The gas valve has to be disconnected and removed to change the switch on most units. The wires in the switch have to be unlocked by inserting a jewelers screwdriver into the holes in the switch body to release the wires. These switches are common to most every gas cook top models no matter the brand. Without your model number I can not provide you with the manufacturers replacement part number. Change the burner ignition switch on the front of the gas valve for the burner with the problem and it will work fine.
Thanks for choosing FixYa,
Kelly
Mar 05, 2011 | Cooktops
The elctric start has stopped clicking since i spilled over a dish into the element below the burners
Hello. the ignitor most likely shorted out with that small flood of moisture. the fix is to replace the part. if you wish to do this your self you could go to searspartsdirect.com, enter the model number of the electric cooktop and get the complete parts diagrams. Joe
4 thumbs up please. ty
Oct 28, 2010 | KitchenAid Cooktops
The electric igniter sometimes doesn’t stop clicking when the burner is off.
Hi and welcome to FixYa I am Kelly. The igniters are controlled by a switch mounted on the face of the burner control vbalve. The switch operates by rotating a ceramic cam against a movable copper strip of wire to contact a fixed contact. What happens is that sometimes the movable copper wire strip gets bent and stays in contact with the fixed contact. These switches are not repairable and must be replaced when they fail.
I used this model as a reference fopr your part as you provided an incomplete model number in your post. JGP326BEV1BB
The switch is common to all models and can be found as item 323 here:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=214745&diagram_id=20726625#d20726625
Close up view:
http://www.appliancepartspros.com/part_details.aspx?part_id=3191247
There is one switch per burner control. Replacing this switch will correct the problem.
Thanks for choosing FixYa.
Kelly
Sep 29, 2010 | GE 30 in. JGP326 Gas Cooktop
I am trying to fix my mother-in-laws Magic Chef cook top (Model # 8241 RB). It is a gas model. It appears the all four of igniters are not working. My mother-in-law said they stopped working one at a...
Suggest that the new igniter is defective.
The bath tub concept of early failures is the most likely explanation this recurring failure,
The prior failures relate to the late in component life the far end of the bath tub curve.
Hope this helps?
The Bathtub Curve and Product Failure BehaviorPart One The Bathtub Curve...
Jun 29, 2017 | Magic Chef CGC2430 Gas Cooktop
Large eye thermostat is not working. Heat stays
Hello JBlum, Yes, most stove top elements, including those with the thermo sensors, are replaceable. Without the model number, I can't steer you towards the exact part number, but you can look it up yourself at www.searspartsdirect.com
Just enter in the full model number of your GE range and it will bring up all the line drawings and parts lists for it. You can either order the parts from Sears, or use any other supplier you wish.
Just remember to disconnect the range from the wall outlet before you undertake any repairs or attempt to replace any parts, so you'll be safe.
Hope you find this Very Helpful and best regards!
Dec 10, 2009 | GE Cooktops
Coil element on kitchen aid model ker1201 slow to
some of the coiled eyes have two coils(elements). one of the coils can burn into at any point around the element rendering it useless while the other can still work. when you lift the glass top you will see the elements are shaped like springs. the elements metal is very britlle.it is you have to replace the entire eye to fix it. the coil most likely had a very gap in the break and acted like a short making and breaking connection until the gap was too wide then nothing. easy fix. just replace the entire eye (power UNPLUGGED!!!) match the old wires with the new part as you take the old part off. I mark them even with a sharpie. it has 3 to 5 wires on that plug into the eye unit. estimated cost for the part online is about 40 to 65 bucks.
Jun 07, 2009 | KitchenAid 30 in. KECC506R Electric...
Electric starters keep firing after I sprayed cleaner
your spark modual got shorted with the liquid you sprayed in there or spilled you can try unplugging it overnight to let it dry. at least 24 hours or you can take the cooktop of and get a hairdryer and dry out the spark modual.or if you wait 24 hours - 3 days and still not dried out you need to replace your spark modual but more than likley give it time it will fix itself.
Apr 23, 2009 | Amana AKS3040 Gas Cooktop
Frigidaire Stove / Oven / Range Cooktop BSQ - 318079378 Logo
56 people viewed this question
Top Frigidaire Cooktops Experts
Dan Webster
Dan Webster
Are you a Frigidaire Cooktop Expert? Answer questions, earn points and help others
