Question about TruTech PLV16190 Television
Turn subtitles off
Hoe to get subtitles off tv
How to turn off subtitle without a remote on a polaroid tv
Polaroid turn off subtitles tv Questions & Answers - Fixya
www.fixya.com > Forum > Tags > turn off subtitles tv
Polaroid turn off subtitles tv related problems. ... ...subtitles on certain channels? go into menu or setup on remote there ... Not finding what you are looking for?
Nov 17, 2015 | Polaroid Televison & Video
I have a 32 inch Upstar LED TV. How do I turn off closed captioning?
On the remote there is a button for Subtitles. Press that button and the Subtitles will disappear. If it is not on the remote then you have to find it in the TV's settings. 'Closed captions' are old words. We now call these 'Subtitles' and all TV's with remotes have a 'Subtitle' button. Look for it, then press while pointing the remote to the TV.
Dec 28, 2014 | Upstar Televison & Video
How do I turn the subtitles off for the yamaha HTR-5730 AV receiver? When I hook the cable up directly to the TV, there are no subtitles, but when the video output goes through the receiver, subtitles
The receiver manual may list it under "CC" (closed captions) instead of subtitles. Also, don't just check your AV receiver; try checking the setup menu on your TV, and look at the TV remote. See if there's a CC setting that may be turned on, either through the TV setup (probably under the "Display" or "Video" tab) or because you've accidentally pushed the CC (or Subtitles) button on the TV remote.
Nov 26, 2014 | Yamaha HTR-5730 Receiver
Subtitles always on
We believe you have the Closed Caption decoder in your TV enabled. Please turn off the CC feature in the TV.
Jul 17, 2014 | Panasonic DVD-S27 DVD Player
I can't get subtitle to turn on. Zenith DVD player to play movie with Subtitle
What you want is Closed Captioning. It has nothing to do with subtitles. If you turn off the speakers in your TV, the CC should appear after a brief pause. If your TV is not equipped for CC, this approach won't work
Nov 11, 2012 | Televison & Video
Getting rid of subtitles on samsung smart tv
There should be a button on the remote control to turn on and off the subtitles. On three of my Samsung products the subtitle button is marked as "subtitle"
Best Regards,
Mar 31, 2012 | Samsung UN46D7000LF 3D TV
HOW DO I REMOVE THE SUBTITLES FROM MY SONY BRAVIA
The Subtitle option is available only with the connected devices like DVD Player, Blu-ray Disc Player etc. The option avaialble in the TV is known as Closed Caption. The Closed caption option can be turned off by selecting the options below:
Press Menu button on the TV Remote. Select, Setup settings. Then select Caption Vision option to OFF. This option is for turning off the Closed Caption option in the TV to OFF. For disabling the Subtitle option in the connected devices like DVD Player and Blu-ray Disc Player, press the SUBTITLE button on the supplied Remote continuously to select OFF.
In few of the TV broadcasting channels the Subtitles cannot be turned OFF as this is being broadcasted with the channels.
Good Luck! KenSolutions
Oct 28, 2010 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Subtitles keep coming on
Hiya, have bought an Alba 26" LCD TV myself today. If you go into the menu and then into subtitles change it from English to Dutch. This should solve the problem. :-)
Dec 13, 2009 | Televison & Video
Cannot turn off subtitles
Turn off the closed captioning through your TV menu.
Aug 08, 2009 | Disney CARS 14 TV/DVD Combo
Subtitle Problem: Onkyo TX-sr605
The only remote that will definitely turn the sat subtitles on/off is the sat remote. The other subtitle buttons on the other remotes refer to the DVD subtitles and the subtitles generated by the tuner in the tv. The subtitle option is greyed out on the tv because you are not on the tv tuner.
Sep 03, 2007 | Onkyo TX-SR604 Receiver
TruTech PLV16190 Television Logo
13 people viewed this question
Top TruTech Televison & Video Experts
Bill Wright
Level 1 Expert
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
