Question about Elo 15" Touch Monitor
How to adjust sensitivity on ELO Touch Screen monitors
I have 3 ELO Touchscreen monitors that are not responding to all of the touches. How do I go about adjusting the sensitivity on these monitors? It only responds to finger press not finger nail or pen. Should it respond to all of these? HELP!!!!! These are in a restaurant and it is making for a very bad situation.
  • fix_fast Jan 28, 2009
    ELo touch screens not responding to the touch???
    pls help....
    Problem Solver:
  • 5 Answers
I agree the answer upstairs.
7 Inch Touch Screen LCD Monitor
Posted on Sep 06, 2010
  • 82 Answers
You probably have a capacitive screen, it only responds to finger press. You need a resistive screen to be able to respond to finger, nail, or pen press.
Posted on Aug 27, 2010
4 Suggested Answers
SOURCE: Elo 17" LCD Touch screen ET1725L Powers off after 1 second
Your problem lies ion either your back light inverter or in the backlight tubes ( bulbs) which are embedded in the LCD display. The display has 4 ccf tubes inside of it that provide the backlighting. if any of these tubes are bad the backlight inverter will shut off after about 1 second. Because there are 4 of these tubes inside the screen you may not notice ( brightness wise) if 1 of them is out.
You can buy another backlight inverter( about $70.00 US) however, from my experience that would be a waste of money. Unfortunately, I think your problem probably lies in your LCD and the backlight tubes are not replaceable.
Hope this helps all who have this problem.
Good luck
Posted on Jun 25, 2009
  • 7 Answers
SOURCE: Elo ET1725L with no video. Flash on screen on
When LCD's "turn on" momentarily before going blank again it is an indication that the backlights have worn out. Cold Cathode Floursecent Lamps (CCFL's) have a limited amount of hours which they can be in operation for before the mercury vapor in them breaks down (or leaks out). When that happens the backlights no longer look like a load the inverter (device inside the monitor which turns low voltage into high voltage) is programmed to look for, and long story short, the inverter does not keep the lamps illuminated because of this being a safety setting, if the load no longer looks like what the inverter is looking for, it could be sustaining an open arc which then leads to extremely high temperatures, and a possible fire. The flash you see is the "firing voltage" (I think that is what it is referred to in the industry) which is a very high voltage pulse used to create the arc between cathodes in the CCFL, creating the arc takes a much higher voltage than sustaining the arc, so even if the inverter successfully creates the arc and lights the cathodes, it quickly doesn't look like a proper load and then inverter quickly turns off to prevent damage.
In essence CCFL's are usually the weakest link in LCD monitors as far as what is most prone to failure, technology has been improving, but if you keep your monitor on all day long at full brightness, never shutting it down, don't expect more than 3 years out of it :( Some brilliant LCD manufacturers recognize this problem and even make the backlights replaceable!! What a novel concept!!! But due to price gouging, the replacement backlights are usually sold for a premium from resellers, better option than the majority of LCD displays which have the backlights so integrated that you end up destroying the LCD and introducing contaminates in the process of "reviving" the display...
Your best bet if the backlights are in fact shot, is, if you are handy with a soldering iron, get the LCD apart, get out the backlights (there are probably four in there, possibly 6) measure the diameter and length, and look on eBay to see if someone is selling the particular CCFL you need-- that may be the cheapest route if you are out of warranty...
Posted on Jul 25, 2009
  • 348 Answers
SOURCE: cannot align touchscreen properly.
yes it may possible that a spike may came and damaged the sensitive chip you are been advised to attact spike arrester and surge suppreser before the computer replace the synaptic ic inside the device problem will be solved
Posted on Mar 08, 2010
Touchscreen calibration
does lightly swiping your finger across the screen from the bottom left corner across to the upper right corner? there are different swiping motions that perform commands.
Dec 04, 2013 | Elo Computers & Internet
Touch screen do not work when touch on any icon
Your might need touchscreen configuration. Please follow the below solution.
If you are asking about the touchscreen of your desktop PC then I would suggest you go to control panel and look for ELO Control Panel where-in you will be guided to touch three targets on the screen. Then Verify the touchscreen if it is working and aligned properly. If you need to align further then go back to the ELO control panel and repeat the process.
Jul 16, 2011 | Computers & Internet
Does not work on the edges, can not access start by touching. when the screen is touched the arrow appears about half an inch away
Sounds like the calibration for the touchscreen needs to be reset. If you check in the control panel, there should be a ELO shortcut that allows you to calibrate/test the touchscreen. Try running through the calibration and see if the touchscreen behavior improves. If the calibration doesn't fix it, then you may have an issue with the touchscreen itself.
Mar 07, 2011 | Elo CarrollTouch touch-screen Monitor
Cannot align touchscreen properly.
Mar 07, 2010 | Elo 1525L 15" LCD Monitor
is the screen worn? you might need to replace the touchscreen glass
Aug 31, 2009 | Elo 15" Touch Monitor
Touchscreen does not wotk on my IQ770
check all the cable connectors, reinstall the driver, if all else fails, the touchscreen glass / controller need replacement
Nov 25, 2008 | Elo 15" Touch Monitor
Elo Touch Screen wont stay on!!
I spoke with ELO techsupport and they said that I have a bad backlight inverter. I am looking for replacement parts. Have you found anything? If not, would you be interested in selling your USB controller unit from your monitor? Wake
Jul 08, 2008 | Elotouch 17" LCD Monitor
Computers & Internet Logo
3,612 people viewed this question
Top Elo Computers & Internet Experts
Ricky Ostrom
Ricky Ostrom
Sam DeGonia
Level 1 Expert
Are you an Elo Computer and Internet Expert? Answer questions, earn points and help others
