Question about Whirlpool 25.4 Cu. Ft. Side-by-Side Refrigerator w/Thru-the-Door Ice & Water - Satina Stainless-Look
Shelves in 1996 model et21dm - Whirlpool 25.4 Cu. Ft. Side-by-Side Refrigerator w/Thru-the-Door Ice & Water - Satina Stainless-Look
I need parts for and hdx shelving unit model 1701099
You can find all parts for this unit at www.apgparts.com.
Dec 09, 2013 | Polycom HDX 5-Shelf 18 in. D x 36 in. W x...
I have an upright Woods freezer model # V1813RW3. It really needs to be defrosted. I wanted to take the shelves out, but there is so much frost, that I can't tell is the shelves are wired with coils...
hello,
the best thing to do is err on the side of caution and melt some of the frost on shelve using a hair blow dryer to remove enough frost so ya can see what the shelves are
Jul 29, 2011 | Refrigerators
Oven shelve falls
You are right, this is very dangerous. It is possible that your oven walls expanded, but honestly, I've never heard of this before, but this is what it sounds like!! I would call Sears right away and have them come out and check it. If the walls did expand, you have a defective oven and they should recall that model. I'd really love to hear the outcome of this complaint, so please let me know how everything turns out for you. And you better get it repaired before Thanksgiving. Have a great day!
Sep 07, 2009 | Ovens
I have an older ET21DM with an icemaker. Water is
you need to clean the drain after you clean the ice out you should notice a hole run a piece of wire down the hole a couple of times then flush with hot water
Jul 12, 2009 | Refrigerators
I want to use my undercounter wine fridge as a real fridge. Wher can I get replacement shelves and baskets/drawers. U-line large model
This cannot be done. The doors are not designed to be as a refrigerator door. The controls are different. This model is designed to be 45 to 60 degrees. WILL NOT WORK FOR REF TEMPS!
The liner has racks that is screwed into them. Shelves are with liners that are molded so the shelves are resting on them.
Sorry
Jul 07, 2009 | Refrigerators
Broken Shelves
The only shelves you'll get for this model is probably the ones offered by the manufacturer.
The best way for longevity of the shelves, is to make sure that you do not put too many heavy things on it, and be careful when cleaning and replacing shelves..
May 28, 2008 | Frigidaire FRS3R5EMB Side by Side...
Replacement shelves
Yes you can get a replacement for the shelves, at a hardware store or somewhere else. Or you can try spray painting the spots there are rust.
Mar 29, 2008 | Sanyo HF-5020
Whirlpool 25.4 Cu. Ft. Side-by-Side Refrigerator w/Thru-the-Door Ice & Water - Satina Stainless-Look Logo
26 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
