Question about Dell 3300MP Multimedia Projector
Lamp reset button - Dell 3300MP Multimedia Projector
  • Dell Master
  • 7,733 Answers
What is the problem? What you want to do? Reset lamp?
Do you have the manual? Here is it PDF
Posted on Jul 16, 2013
Reset lamp time
The lamp time is the time counted after the last resetting. It is shown in the OPTION menu as the usage time of the lamp. Pressing the RESET button on the remote control or the ? button of the projector displays a dialog. To reset the lamp time, select the RESET using the ? button. RESET ? CANCEL • Please reset the lamp time only when you have replaced the lamp, for a suitable indication about the lamp.
May 13, 2015 | Hitachi CP-X505 Projector
How to change lamp timer on sanyo plvz4
Hello
* Turn the projector ON, and press the MENU button to display the on-screen Menu. Select the 'setting' menu with point UP/DN button. Press '>' button to acess sub menu items.
* Select the Lamp Counter reset and press the OK or '>' button. "Lamp replacement counter reset?" will appear. Select "Yes" and then press OK or ">" button
8 Another confirmation dialogue box appears, and select "Yes" to reset lamp replacement counte.
** Do not reset the lamp replacement counter without implementing lamp replacement. Be sure to reset the lamp replacement counter only after replacing the lamp.
Dec 17, 2011 | Sanyo PLV-Z4 Multimedia Projectors
Hello, i would like to know if resetting the lamp timer on an LG MW60sz12 will allow you to get more time out of it?? also if it is possible, how do you reset it???
Quick answer = NO.
As projection TV lamps generally have a life somewhere between 3,000 - 6,000hrs (depending on lamp quality/type), the lamp timer is simply there to assist you in determining when the current lamp is due for replacement.
Resetting the lamp timer has no effect what so ever, on the longevity of the lamp.
The Lamp Timer Reset function is hidden within the Service menu and as such, technicians are usually the only ones who are authorised to reset the timer.
However, the following procedure has been known to reset LG lamp timers:
1. With the TV on, press and hold the MENU button on the TV front panel.
2. While holding that button, press and hold the MENU button on your remote.
3. Hold both buttons for ~5 seconds until the service menu comes up on the TV.
4. Release the remote MENU button first, then the TV MENU button.
5. While holding that button, press and hold the MUTE button on the remote.
6. Press and hold the ENTER (or OK) button on the TV front panel.
7. Hold both buttons until the Lamp Life Hours show up on your TV screen.
8. Release the MUTE button first, then the ENTER button on the TV front panel.
9. Make a note of the lamp hours if you want.
10. To reset the lamp hours, press the SELECT button (the one between the four arrow keys with two concentric circles on it) on your remote.
11. It will ask you to confirm the reset--press SELECT again to confirm
"If this has resloved your problem, please be kind enough to rate this solution and/or leave a testimonial"
Sep 19, 2011 | Televison & Video
Replaced main bulb in front but lamp button on front of tv is still blinking and tv won't show picture
The lamp timer on the Hitachi projector must be reset whenever the lamp has been replaced. The "Lamp" indicator on the display will light red or the "Change the Lamp" message will display when the lamp timer needs to be reset. Hitachi recommends that the lamp timer never be reset without replacing the lamp and to always reset the timer when the lamp is replaced. The message functions of the projector will not function properly if the lamp timer is not correctly reset.
  • Turn the power on. Press the "Reset" button for three seconds until the "Lamp xxxx hr" message appears on the lamp timer on the bottom of the screen.
  • 2
    Press the "Menu" button on the remote control while the lamp timer is displayed.
  • 3
    Press the left arrow button. Select "0" and wait until the timer display clears.
  • If this was helpful a vote on the thumbs up for the free advoce would be greatly appreciated. Thanks
    Apr 04, 2011 | Hitachi 60V500 60" Rear Projection...
    Re set timer?
    hi,
    To reset the lamp hour timer do the following,
    1. Power on the projector
    2. press the menu button
    3. Select option
    4. in the option menu select Lamp time
    5 press and hold the reset button on the remote or Right arrow button on the projector for 3 seconds
    the lamp reset diagonal box will appear
    6 using the up arrow button select reset.
    Also try to reset the filter time using the same procedure
    lamp reset is recommended only after the lamp replacement.
    ok
    Apr 04, 2011 | Hitachi CP-RS55 LCD Projector
    My lamp light is yellow green? what could be the cause?
    hi ,
    Do one thing just reset the lamp hour of your projector. For resetting the lamp hour do the following.
    While simultaneously holding down the Right arrow ( >) button and Auto sync button on the projector press Power ON button and Left arrow ( button . The lamp hour will indicate zero.
    If doesn't work you have to replace the lamp.
    Remember on thing Lamp hour reset is recommended only after the lamp replaced. so try to replace the lamp if it work after the resetting procedure.
    ok
    Mar 27, 2011 | Sharp Notevision PG-B10S Multimedia...
    Need to reset lamp. replaced lamp and installed new lamp.
    Press RESET, <, >, ENTER keys on remote within 5 seconds to reset lamp timer.
    Jul 29, 2010 | Sony VPL-CX86 Multimedia Projector
    After replacing the lamp in an XD480U projector, what are the 2 buttons needed when pushing the power button, to reset the Interval of lamp replacement time? The buttons to choose from are: Auto position...
    To reset the lamp operation time on a Mitsbishi XD480U:
    Plug in the power cord, turn on the lamp, and press the Left Arrow button, Right Arrow button, and POWER buttons on the control panel ALL AT THE SAME TIME, holding them all down for about three seconds.
    Notes:
    •Unless these three buttons are pressed at the same time, the lamp operation time isn't reset.
    • Make sure that the STATUS indicator is lit twice and the lamp operation time is reset successfully.
    • The projector doesn't turn on if the lamp cover isn't attached securely.
    • Be sure to reset the lamp operation time whenever you replace the lamp.
    • Do not reset the lamp operation time unless you replace the lamp.
    Dec 17, 2008 | Mitsubishi XD480U Multimedia Projector
    What 2 buttons other than the Power button
    Notes:
    Can't reset lamp timer
    Turn on the projector, and reset the lamp timer.
    (1) While the projector running, press the MENU button to open the menu.
    (2) Choose the “OPTION” on the menu using the / button, then press the
    button or ENTER button.
    (3) Choose the “LAMP TIME” using the / button, then press and hold the
    RESET button for 3 seconds.
    (4) Choose the “RESET” using the button.
    memo When the lamp has been replaced after
    Dec 11, 2008 | Hitachi CP-X1200 Multimedia Projector
    Dell 3300MP Multimedia Projector Logo
    60 people viewed this question
    Top Dell Office Equipment & Supplies Experts
    jasbo
    jasbo
    Electro Med Services...
    Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
