Question about E-Machines etower 466is PC Desktop
Start up menu
I have an etower 466is before windows start what key to you hit to go to the menu so i can change the way the computer boots. thank you Rob
  • rfpoil Aug 28, 2007
    ty i will i forgot to say i am running win 98 on it
    thanks
    ROb
    Problem Solver:
  • 16 Answers
I know nothing about this machine in particular but immediately when the computer beeps... Generally the "delete" key gets you into the bios menu. If not that, then its almost always a function key "F1"-"F12" Just try running your finger down and back the function row as it boots if "DEL" fails Windows' boot menu comes up when you hit "f8" repeatedly before the windows logo appears. For older Windows versions use the left shift key and hold it just before and during the windows logo. Give it a try!
Posted on Aug 28, 2007
SOURCE:
How do i access my boot menu on an etower 600is
Generally its ESC, F1, F2, F8 or F12, if you can get to at least the BIOS menu you can probably change the boot sequence to your liking.
Jan 05, 2013 | E-Machines etower 600is PC Desktop
When I goto shut down the computer it goes through the motions but then it restarts and goes back into windows. In order to shut it down I have to go through and when it starts to boot I have press the...
Try this, go to control panel, select Power Options, make sure the section that says "When I press the power button" it says shut down the computer.
You may also want to check in the BIOS where it says what do you want to do when you press the power button, you want both to say to shut off the PC.
I hope this helps.
Good Luck and have a pleasent day.
May 24, 2011 | E-Machines etower 466is PC Desktop
I have dell inspiron laptop, suddenly a problem occured I quot that :windows faild to start a recent software or hardware change might be the cause to fix the problem : 1-insert your windows...
Shut your computer all the way down. As soon as you turn it on, start hitting F8 about 3-4 times, that will take you to an advanced options menu. Select "Last known good configuration" and that should work
Mar 08, 2011 | Computers & Internet
How do I enter bios in an eTower 466is
Emachines systems generally use either the Del or the F2 key to enter the Bios. You just need to hit it at the right time just after the initial beep when the system turns on. If neither of those work, you can try the link below to see what some of the other more common keystrokes are that manufacturers use.
http://michaelstevenstech.com/bios_manufacturer.htm
Apr 20, 2010 | Computers & Internet
Gigaset 567 wireless router. unable to connect from desk top to laptop
try to disable the antivirus software and try to connect again, if this doesnt work try to go to safe mode w/ networking
to go to safemode w/ networking you can try this options:
when using windows XP, Vista and Windows 7. try to restart the computer as soon as the computer turns on immediately strike F8 key continuously, in advance menu option or advance boot option use the arrow key to highlight safemode w/ netwokring and hit enter ( if you see you operating system just hit enter again )
or try this one:
for windows XP,
click start
click run, type in msconfig
in msconfig click the tab for Boot.ini click safeboot at the bottom and choose network, hit enter
click apply and ok
for windows vista and windows 7
click start button or the pearl
type in msconfig in the start search and hit enter
click the Boot tab
click the safeboot and choose networking
click apply and ok
i hope this helps
Pls rate my resolution thanks!!
Mar 04, 2010 | Siemens Computers & Internet
How do i use my recovery disk to recover my pc
put the recovery disk in your dvd drive and restart your pc.
when you see the message "press any key to start from dvd" press enter.
the restore procedure will begin.
Jan 25, 2010 | E-Machines etower 600is PC Desktop
My acer aspire 5315 always show boot prepare os. When i want to install windows it cannot show cd boot (booting from cd/dvd) so i can't install windows. what is the solution sir? thank.
Restart you computer then hit F2 for Boot Bios Setting then GO TO Advance. Change the SATA Mode . ACHE. ot IDE. or Comfatibility.. then enable the F12 boot. make in enable. the hit F10 for save and exit...
Insert you cd os Installer then hit F12 for **** menu. select the CDROOM for boot....
Dec 30, 2009 | Acer Aspire 5315 Notebook
Hi My IBM T40 does not boot, could you help
Try this boot up fix, you will need a windows install disc.
Windows Start-up Errors
Step one, you need a Windows Installation CD. If you only have a recovery disk set like the ones from HP or Compaq they will not do what you need done. Under normal circumstances however, you can use a Dell disk because the Operating system is on a stand-alone disk. All retail versions are also acceptable as well as upgrade disks. For a rule of thumb, if the disk has the Microsoft hologram it should work.
While the computer is first starting up and you see the manufacturers splash screen, tap F12 (some computers it’s F9, others it may be another key, you may have to watch and see if the computer lists the key strokes for getting to the boot menu. If you still cannot find it, boot into the BIOS settings and change your boot order there. Save your settings and exit, the computer will now seek the cd rom as its boot source first.
Place your Windows disk in the computer and start it up. When you see the test at the top of the page “Press Any Key To Boot From CD” Just hit the space bar to activate. The next screen you will see will most likely be a Windows setup screen, when you see this press the “R” key to get to the recovery console. It will get there, it may take a little time, patience. Once it loads you will be given a choice of Windows installations, there should only be one, if there are more, always pick number one. It may ask for an administrators password, if you have not set this particular password, then just leave it blank and press enter. The next prompt you see is:
C:\Windows>
You need to type the following:
cd \
hit enter. Pay close attention to the spacing between the characters. There is a space between the character “d” and the “\”
You are now at the ROOT of the drive, this is where basic commands can be given and changed. You should now see the following:
C:\>
Now type the following:
CHKDSK /R
Hit the enter key.
The chkdsk /r command also includes the P command and will also look for lost recoverable information in bad sectors.
There are occasions depending on how corrupt the system is, that this process could take several hours, so be patient with it.
Now, after chkdsk has run type the following:
FIXBOOT
Hit the enter key.
It may prompt you with a warning, that’s ok, just continue. When fixboot has finished, type: EXIT hit enter and windows will reboot. When the system reboots, tap the F8 key during this time and you will see the multi-boot menu come up. Scroll to the title “Last Know Good Configuration” and hit the enter key. If you were having some simple drive errors this should have fixed them.
Nov 15, 2009 | Lenovo IdeaPad Y510 Notebook
Can't get past black screen and mouse
Power off your computer, then power on hitting F12, del or whichever key it states to go into setup. From the setup menu, select change boot order or boot menu. Set the CD ROM to the first boot device. Save changes. Restart. Your computer should boot to cd starting the installation.
Feb 06, 2009 | Dell Inspiron 1501 Notebook
E-Machines etower 466is PC Desktop Logo
140 people viewed this question
Top E-Machines Computers & Internet Experts
Ekse
Steve Allison
Steve Allison
Thomas F. Schneider
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
