Question about George A. Gathecha Google Search
What other evidence besides fossil bones might be useful in describing the behavior of a dinosaur?
Where are the real bones of diplodocus
One of six "sets" said to exist went on the auction
block in England
How about that... for a native of Wyoming...?
https://en.wikipedia.org/wiki/Carnac_the_Magnificent
Diplodocus sale Wyoming dinosaur skeleton in Sussex auction BBC News
Jan 05, 2017 | Cars & Trucks
Calcium defiency
talk with a doctor about the problem
one indication is bones that break easily and that is only evident on breaking a bone from a minor incident
doctors can do a bone density test and that will indicate a problem
remedy is simple but talk with your doctor
Dec 18, 2016 | Dishwashers
I heard that its good to eat cottage cheese before bed. Why is that?
Cottage cheese is actually taken by many bodybuilders right before they go to bed because it contains casein protein, which is a type of protein that digests very slowly. Because it digests slowly, it makes us feel full for a longer period of time.
Feb 04, 2013 | Cooking
Need a replacement remote for my D-Rex prehistoric pet
I went to Mattel's web page, typed in D-Rex control bone, in the search area, and they came up. There are two different models so make sure you get the right control bone for your D-Rex.
Nov 22, 2011 | Dinosaur D-rex Interactive Dinosaur By...
Where may I get the control bone for the Mattel D-Rex Interactive Dinosaur?
Im having the exact same problem locating a replacement bone. Have you found one yet? If you have found one please contact me at kishamcculley@hotmail.com. Thank you for your time!
Aug 25, 2011 | Dinosaur D-rex Interactive Dinosaur By...
I haven't worn my fossil watch (FS 4337 model) for some time & decide to wear it & shook it, adjust it, & it dosn't work. Usually when I don't wear it for about 2 weeks, I shake it...
If you have a Fossil FS4337 Chronograph, shaking the watch shouldn't be doing anything other than exercising your muscles; the movement is a battery-driven quartz movement whose movement is controlled only by whether the stem has been pulled out (stopping the movement and saving power) or whether the battery still has enough power to activate the stepping motors that move the watch hands. Based on the symptoms that you've described, I would suggest that it's probably time to change your watch battery.
Often, when a watch battery is running low but isn't completely dead, pulling the stem into time-setting mode will stop the movement and permit the battery to "rest," giving it (briefly) a bit more reserve amperage to put out when you push the stem back in. That's how you can sometimes get a quartz watch to run for a few minutes after the battery appears to be dead. That may also be why your watch has started running again after you've set the time and date.
Fossil analog quartz watches tend to use silver oxide (usually #377 or #379) batteries instead of longer-lasting lithium batteries. In ordinary use, I would expect a silver oxide battery to provide between 1 and 2 years of service before it needs to be replaced. I can't remember if Fossil chronographs (which also use quartz movements) use a silver oxide or lithium battery. Lithium batteries often provide an additional year or two of service in analog watches, compared to silver oxide cells; digital watches using them supposedly may last as long as 10 years with a lithium battery, assuming you don't use the backlight or audible alarm functions. Note, however, that these batteries are different sizes and different voltages, so you can't substitute one for the other.
Finally, none of this advice applies if you have a Fossil watch with a true mechanical movement in it. In that case, gently shaking the watch may spin the winding rotor enough to start the watch back up again. However, an even faster way of winding those watches is to use the winding / time set crown to wind the mainspring directly instead of relying on the geared-down action of the winding rotor. Automatic watches can bind up if they are not used for a period of time; the lubricating oil used in some of the pivots can harden--or at least provide enough resistance that the movement may require more initial force to start running than to continue running. That behavior usually indicates that it's time to have the mechanical movement cleaned and re-lubricated.
May 31, 2011 | Fossil Brushed Brown Dial Chronograph...
Looking for an instruction booklet
hello i have one if you need images just e mail me diego
Mar 14, 2009 | Toys
Looking for Dino. parts
You can buy replacement parts for Spike the Dinosaur from matel at the following site:
https://store.mattel.com/CatalogBrowser.aspx?cmd=local&cat=140&sec=9528
Mar 11, 2009 | Toys
The Simpsons Game on DS.
Climb up the ladder.Make homer stand on the dinosaurs head then swop to bart.Make bart go to the tail and jump of and glide .
Feb 17, 2009 | EA - Electronic Arts The Simpsons Game for...
George A. Gathecha Google Search Logo
95 people viewed this question
Top George A. Gathecha Facebook Apps Experts
Michel Laprise Sr
shuyumeng
shuyumeng
Are you a George A. Gathecha Facebook App Expert? Answer questions, earn points and help others
