Question about Apple aluminum 13-inch MacBook laptop- Intel 2.1GHz l Core 2 Duo, 1GB 667MHz DDR2 SDRAM, 320 GB HD, ... Mac Notebook
Macbook i have two mac os x 10.6.4 disc but i need step by step help.to get it started and running
    Problem Solver:
  • 25 Answers
Slot the disc in and follow the on-screen instructions.
Posted on Nov 09, 2013
    Sergeant:
    Champion:
  • 387 Answers
Insert Disc 1 and Restart holding down the C key. Follow directions
Posted on Oct 04, 2013
4 Suggested Answers
seaniepie
  • 250 Answers
SOURCE: Mac laptop
Hi Garfo,
Try this:
  1. If the computer is on, turn it off.
  2. Disconnect the AC Adapter and remove the computer's battery.
  3. Press and hold the power button for 5 seconds and then release the button.
  4. Reconnect the battery and AC Adapter.
  5. Press the power button to restart the computer
That resets the SMC and should fix your problem.
Sean
PiDigital.co.uk
Posted on Dec 31, 2008
arnomonfort
  • 115 Answers
SOURCE: mac tune up software
Use ONYX instead. Better and complete solution:
http://www.titanium.free.fr/
Posted on Feb 04, 2009
MacAppleTech
  • 206 Answers
SOURCE: InstallatIon of Mac OS X 10.4.10
White screen issues on your Macbook are more often than not, an indication that you may have a connected peripheral or device which may be hindering your Macbook's normal start up function
What you need to do first, is remove all peripherals from (printers, scanners, USB drives etc.) and then reboot your Macbook.
If your Macbook starts up normally without a white screen, leave all the peripherals disconnected and see if you can proceed to run all of your software updates, in Apple menu>Software Updates, first, including updating to the final version of Mac OS X 10.4 Tiger, 10.4.11.
Once all of your updates are completed, then you will need to go through a process of elimination by connecting one peripheral at a time, then properly shutting down and restarting your Macbook with each device, to see if your Macbook goes to a White screen.
Depending on the number of peripherals you have normally connected to your Macbook, this may seem a little tedious at first. But considering how bothersome a White screen is, it will be worth it solving the mystery of which peripheral is causing the white screen and failure to boot up normally.
If it turns out that one of the devices you had connected was in fact, causing the white screen, this will be the opportunity for to research online, visiting the affected device's manufacturer's website or even use Google, to confirm if there are any known issues and/or updates available to address that issue.
There are other variables which can come into view with a white screen issue, but this is a good way to start in terms of working toward a viable solution to this issue with your Macbook.
I hope this helps, let me know if you have more questions.
Regards,
-Mactechtrainer
Sr. Mac Support Specialist
Posted on Jan 26, 2010
Why is my apple mac pro is very slow
There are a lot of possible reasons can cause a MacBook Pro to start running slow, generally related to hardware and software issues.
Check out this site http://www.macbookproslow.com/ for the top causes and quick step by step fixes.
Hope it helps!
May 18, 2014 | Apple MacBook Pro Notebook
Why is my macbook air a1466 showin a file with a question mark when i turn it on and how do i fix it
http://support.apple.com/kb/ts1440
A flashing question mark appears when you start your Mac Symptoms
If you see a flashing question mark when you start your Mac, it's probably because it can't find the system software it needs to start up. Usually, all you have to do to get your Mac back up and running is remind it where its software is.
Resolution
If your computer starts up normally after a brief delay, you probably just need to reselect the startup disk in Startup Disk preferences. It's normal to see the flashing question mark when a startup disk has not been selected. In most cases, reselecting the startup disk is all that is required to resolve the issue.
Sometimes, your computer may not start beyond the flashing question mark.
Tip: If your computer has a gray screen (with no flashing question mark) startup issue, see Mac OS X: Gray screen appears during startup.
Check the mouse and keyboard
This issue might occur if a mouse or trackpad button is pressed during startup. Make sure the button isn't pressed.
If the issue persists, shut down your Mac with its power button, disconnect any external mouse and keyboard, then turn on your Mac with its power button. If the flashing question mark issue persists, reconnect the keyboard and mouse.
Additional steps
If your Mac still starts to a flashing question mark, follow the steps below. If any step resolves the issue, you don't need to continue to the next one.
  1. Select your Mac OS X startup disk with Startup Manager by restarting and holding the Option key. After your Mac starts up, restart again to verify that the flashing question mark does not appear.
  2. If the issue persists, insert your Mac OS X installation disc. Be sure to either use the disc that came with your Mac, or, if you installed a later Mac OS X version from disc, use the newer disc.
    MacBook Air note: On a MacBook Air, there are two options for starting up from Mac OS X media: Either connect a MacBook Air SuperDrive to the MacBook Air via the USB port and restart the computer, holding down the C key during startup, or use Remote Install Mac OS X to startup from a system software DVD that's located on a partner computer. Once started up from Mac OS X media, skip to step 3.
  3. Restart the computer, then hold the C key during startup.
  4. From the Utilities menu, choose Disk Utility. Don't click Continue.
  5. Select your Mac OS X disk (named "Macintosh HD" by default) in the left side of the Disk Utility window.
  6. Click the First Aid tab.
  7. Click Repair Disk to verify and repair any issues with your Mac OS X startup disk.
  8. After repairing the disk, try to start up normally.
    Important: If Disk Utility finds issues it cannot repair, you may need to back up as much of your data as possible (or use Time Machine to back up to a different disk), then erase the disk and reinstall Mac OS X. You should back up important files and data before erasing a drive. Erasing deletes everything on the hard disk (including things on your desktop). Also, you can install Mac OS X onto an external disk, start from the external disk, and use Migration Assistant to transfer items from your usual internal Mac OS X startup disk to the external disk, then erase the internal disk and reinstall Mac OS X.
  9. If the issue persists, and Disk Utility didn't find any irreparable issues, quit Disk Utility, quit the Installer, select your disk when prompted, and restart.
  10. If the issue continues, reset PRAM. Note: After resetting PRAM, if the computer starts up normally, reselect the startup disk in the Startup Disk preferences.
  11. If none of these steps resolve the issue, start up from the Mac OS X Installation disc and reinstall Mac OS X.
Last
Mar 30, 2014 | Computers & Internet
My macbook when i uploading i turn off macbook and i turn on macbook didn't boot up just see turn around aound forever not go to windows i lost system disk unable to boot macbook
Check for a failing hard drive
Trying booting from the Mac OS X install disc. insert the Mac OS X install disc. press the start button, while holding down the "C" key on the keyboard
Once you are running from the disc. go to Disk Utilities select the hard drive click the "repair permissions" button at the bottom.
If you get any red errors listed or it doesn't seem to finish repairing the permissions you have a failing hard drive and it will need to be replaced.
If the repair permissions finishes without any problems. You will have to reinstall the operating system.
Jan 05, 2011 | Apple 13.3 MacBook Intel Core 2 Duo...
Forgot password for macbook air
Dear Sir,
Welcome to Fixya Support
Resetting Your Password You can reset your administrator password and passwords for all other accounts. To reset your password, using a partner computer and Remote Install Mac OS X:
1 Follow the procedure for using Remote Install Mac OS X
To use Remote Install Mac OS X: 1. Insert the Mac OS X Install Disc 1 into the optical disc drive of the other computer. 2 .If the other computer is a Mac, open /Applications/Utilities/Remote Install Mac OS X. On Windows, choose "Remote Install Mac OS X" from the Install Assistant. 3. Read the introduction and click Continue. 4 .Choose the install disc you want to use, and click Continue. 5. Choose a network connection: AirPort, if you are using an AirPort network, or Ethernet, if the other computer is on an Ethernet network and you have an optional Apple USB Ethernet Adapter connecting your MacBook Air to the same network. Click Continue. 6 .Restart your MacBook Air and hold down the Option key as it starts up, until you see a list of available startup disks. 8. If you chose AirPort as your network in step 5, on your MacBook Air choose your AirPort network from the pop-up list. If the network is secure, you are prompted for a password. You can enter a private network name by choosing the ellipsis (...) and typing the name. 9. If you chose AirPort as your network in step 5, when you see the AirPort status icon indicating signal strength, click Continue in Remote Install Mac OS X.
10. Click Continue in Remote Install Mac OS X. 11. On your MacBook Air, choose Utilities > Reset Password from the menu bar and follow the onscreen instructions. When you finish, quit Mac OS X Installer. 12. On the other computer, click Quit to exit Remote Install Mac OS X.
I think it helps.Let Me know.
Dec 25, 2010 | Apple MacBook Air
My MacBook air webcam stopped worked suddenly.
Nov 12, 2010 | Apple MacBook Air
I have a macbook OS X, i boot up on windows xp then i notice that theres only 10% remaining on the harddisk intended to windows, then suddenly the blue color appear and says that i must shutdown the unit....
Your hard drive is corrupted and the OS needs to be re-installed on the hard drive. Re-install the OS using your discs, but first use disk 1 to go into disk utilities and select your hard drive, then click repair disk permissions. After that click on repair disk and see if that don't help. If that don't help then your next step is to re-install the OS, because somewhere the startup file got corrupted. If that don't work, then your SOL, which means your hard drive has given up the ghost and you need to install a new hard drive.
Sep 29, 2010 | Apple MacBook Mac Notebook
Hi. I turn on the mac and the screen says Mac OS X then there is Name and password. How can I get in to the main screen?
If you do not know the password for the user, you can reset it very easily:
  1. Start up from a Mac OS X Install disc (one whose version is closest to the version of Mac OS X installed). Usually, you can start from the disc by putting it in your computer, restarting, and holding the C key. Or, put it in the computer and click the Install or Restore icon you see in the disc's main window (after which the computer will start from the disc without you needing to hold C). Or, you can use Startup Manager or the Startup Disk preference pane to select the Install disc.
  2. Choose a language, click the arrow button to continue,
  3. Mac OS X v10.6 or later: Choose Password Reset from the Utilities menu.
    Mac OS X v10.5 or v10.4: Choose Reset Password from the Utilities menu.
    Mac OS X v10.3: Choose Reset Password from the Installer menu.
    Tip: If you don't see this menu or menu choice, you're probably not started from the disc yet.
    Note
    : The default keyboard layout is U.S. English while started from the installation disc. If you use a keyboard layout other than U.S English, use the Input menu (the flag icon on the right side of the menu bar) to select the desired layout before typing a new password.
  4. Select your Mac OS X hard disk volume.
  5. Select the user name of your original administrator account.
    Important: Do not select "System Administrator (root)". This is actually the root user. You should not confuse it with a normal administrator account.
  6. Enter a new password.
  7. Click Save.
  8. Click the red button in the upper left corner to quit the application.
  9. Choose Quit Mac OS X Installer... from the Mac OS X Installer menu.
  10. Click Restart.
Aug 28, 2010 | Apple aluminum 13-inch MacBook laptop-...
There is a small little coloured ball that comes on my computer and then it freezes while I am playing a game
Thanks for contacting Fixya Support.
Anytime you see the "rainbow pinwheel" which does manifest itself from time to time in Mac OS X environments, this is an indication of either a software issue or even a hardware issue.
Considering you are playing a game, it would be safe to assess that this issue you are having is in relation to the game you are playing (being unresponsive), means that this is a software issue.
There are several variables in regards to fixing issues with the spinning pinwheel in relation to a software.
If your application is not responding, you can first of all Force Quit the application by selecting Apple Command, Option and the Esc keys, and either select the game application in the window, which should be displayed as "Not Responding" and Force Quit or select Finder and simply relaunch it.
If you are unable to get your Mac OS X system to respond at all, then try a PRAM Reset process as shown below:
--PRAM RESET --
• First, hold in your power button for approximately 10 seconds to do a hard shutdown, if you have not already turned your Mac off.
• Once your Mac is shutdown, you will need to perform what is called a PRAM reset (Parameter RAM)
This should help with the freezing issue:
• Locate the following keys on the keyboard: Command, Option, P, and R. You will need to hold these keys down simultaneously .
• Turn on the computer.
• Press and hold the Command-Option-P-R keys. You must press this key combination before the gray screen appears.
• Now, hold the keys down until the computer restarts and you hear the startup sound for the third time.
• Release the keys and allow the Macbook to start up.
--Check to see if you are able to launch and play your game now.
If neither of these steps work, then if you have your Mac OS X installation disc which came with your Macbook, then I would finally recommend you perform these steps below with the installation (Macbook Restore) disk:
-RUN DISK UTILITY WITH MAC OS X INSTALLATION or RESTORE DISK-
Insert your Mac OS X Startup disk (Note: make sure the disk contains the same Mac OS X platform that your Macbook is currently running)
•Reboot your Mac
•At the Apple Chime, press the C key and hold it until you see a White screen, gray Apple and eventually a Spinning gear.
• Release the C key only after you see the Spinning gear.
•Mac will boot from the startup disk to the Installer environment
• From the Installer Menu bar, click Utilities > Disk Utility and open up Disk Utility application.
• Click on on the hard drive at the top of the window in the left sidebar and
• Select "Repair Disk"
**Let Disk Utilities run this repair the disk until completion
• At the end of this process, reboot your Mac
Now attempt to run your game application and see how your system responds after the Disk Repair process.
If the Macbook still persists in freezing or the game application still causes the spinning pinwheel to appear, then you may need to increase your Macbook's RAM memory, as the game may require more memory resources than you current have installed with your Macbook, or it may not be compatible with the current version of Mac OS X you are running with your Macbook.
I hope these steps point you in the right direction.
Regards,
-Mactechtrainer
Aug 20, 2010 | Apple MacBook Mac Notebook
How can I find the admin password on my mac. I had a new hard drive put in my pc. I want to change some of the admin settings but I need the password. How can I find it or change it without knowing the...
Resetting the original administrator account password Follow these steps to reset a password when there is only one administrator account on the computer, or if the original administrator account needs a password reset. "Original" administrator account refers to the one that was created immediately after installing Mac OS X. If the original administrator password is known, that administrator account may be used to reset the passwords of other administrator accounts using the steps described above. These steps require an optical drive; if your Mac does not have an optical drive and you have a Mac OS X v10.6 Install disc, see below.
  2. Mac OS X v10.6 or later: Choose Password Reset from the Utilities menu.
    Note: The default keyboard layout is U.S. English while started from the installation disc. If you use a keyboard layout other than U.S English, use the Input menu (the flag icon on the right side of the menu bar) to select the desired layout before typing a new password.
  3. Select the user name of your original administrator account.
  4. Enter a new password.
  5. Click Save.
  6. Click the red button in the upper left corner to quit the application.
  7. Choose Quit Mac OS X Installer... from the Mac OS X Installer menu.
  8. Click Restart.
  9. After following these steps, you'll want to also follow the steps in this article.
Mac OS X v10.6: Resetting the original administrator account password on a Mac that has no optical drive
These steps require a second computer that has an optical drive.
Note: If the second computer is a Mac, make sure Mac OS X v10.5.3 or later is installed. If the second computer is a PC, make sure the DVD or CD Sharing Update 1.0 for Windows is installed.
  1. Open "Remote Install Mac OS X" from the Utilities folder.
  2. Follow the onscreen instructions.
Feb 10, 2010 | Apple MacBook PC Notebook
How do I unlock my macbook,I forgot my password
Oct 28, 2009 | Apple aluminum 13-inch MacBook laptop-...
Apple aluminum 13-inch MacBook laptop- Intel 2.1GHz l Core 2 Duo, 1GB 667MHz DDR2 SDRAM, 320 GB HD, ...  Mac Notebook Logo
54 people viewed this question
Top Apple Computers & Internet Experts
paulcarew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
