Question about Amana Easy Reach AFD2535DE Bottom Freezer Refrigerator
Ic6 ice maker
The ice is dirty every now and then. How do we clean the ice maker
  • Amana Master
  • 7,733 Answers
Some models like yours came with a defrost control board and others came with a defrost timer. They should be found inside the fresh food compartment and behind the temperature control panel. You will need to inspect and let me know which you have. Unplug first. If the control board looks or does not look burned it could be bad. The timer can be turned clockwise until compressor stops and should remain stopped for about 25 minutes. and then turn itself back on. If these look good then we need to remove the rear panel inside the freezer and test the defrost element with one wire disconnected to check for continuity. Just to be sure the element has not burned out. The defrost thermostat is connected to the defrost element and will have open contacts inside it above 50 degrees.
Posted on Jul 16, 2013
SOURCE: NO ICE - IC6
Mine was slow-to-none in ice making for a couple of years. One day for the first time I used the built in water dispenser. The long copper line feeding water was full of air gaps. After I bled that out, it has been perfect ever since.
Posted on Sep 09, 2007
SOURCE: i have a AMA IC6
Having problemAMA IC6 Icemaker. Water leaking into tray as it is making cubes causing previous cubes to freeze together and to the bottom of the container. Trying to defrost to see if that helps. Any suggestions appreciated.
Posted on Jun 09, 2008
  • 58 Answers
SOURCE: No water comes automatically to the ice maker
What you need is a new ice maker the front gear is not engaging the contacts, you can buy the front module only ( what u put the wire in to on the l & v contact ) but a whole new ice maker assy is the same price.
Posted on Jan 10, 2009
Controlfrk
  • 304 Answers
SOURCE: Water leak from ice maker
The fill line internal to the freezer is likely frozen up from the elbow inward.. When the icemaker calls for fill...pressure builds up on the plastic tubing causing it to pop out of the elbow. Check the tube inside the freezer by removing icemaker and running a long thin screwdriver or a rigid wire up into the tube until you feel ice or the plastic elbow outside.
Clear ice, if present, by squeezing hot water in from freezer side with turkey baster until cleared and water comes out back.
Posted on Aug 22, 2009
  • 101 Answers
SOURCE: ice cubes taste funny; cleaning the cube box, and
I've experienced this before, and have two solutions that helped. One is, boiling the water prior to putting them into the ice tray. And two, you can fill up your ice tray and then wrap it with aluminum foil. I've heard saran clear wrap also works, but I've used aluminum tin foil - and it helped. I hope this works for you. I've tried both of these solutions, and it made a difference. So I hope it works for you. Good Luck!
Posted on Apr 01, 2010
My Whynter UIM-155 ice maker used to make alot of ice quickly. Now, it does not make very much ice and it takes a long time? What should I do?
look at the condenser coli to see if it is dirty if so clean it. Dirty coil will cause it longer to make ice. also make sure nothing is blocking the condenser return.
Aug 20, 2013 | Whynter UIM-155 Stainless Steel Built-In...
How ofter should you clean the Scotsman ice maker?
Every 6 months and change filter unless you notice ice hanging up during harvest and dirty ice then i would every 3 monts.
May 25, 2013 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Ice cubes taste funny; cleaning the cube box, and using box of baking soda in freezer has not helped; model# BG20T2W, ice maker IC6
Apr 01, 2010 | Amana Refrigerators
Ice cube from icemaker have recently had a bad taste. Filter to service? Amana Mod BG20T2W Ice maker IC6
Bad taste or odor from ice cubes most likely a filter problem. If filter has not been changed for at least 6 months, that is where I would start.
Apr 01, 2010 | Refrigerators
Aug 21, 2009 | Amana Refrigerators
Jan 10, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Ice maker freezing up
The problem is in the water valve.
The water supply line going to the Ref is connected to a water valve. This valve is not shutting off completely which causes water to drip into the ice maker. This dripping will freeze and eventually completely block the fill tube in the freezer.
Aug 23, 2008 | Whirlpool ED2FHSS Side by Side...
I have a AMA IC6 ice maker and the ice is stuck together form water running over into the catch tray.i have removed the ice maker and let it thaw then reinstalled and the same thing happened. any...
Jun 09, 2008 | Amana Refrigerators
IC6 ice maker
No, completly deforst the freezer for 24hrs this will resolve the problem, i know its frost free, but still try to defrost this usaully resolves this fault Regards Advisor
Aug 21, 2007 | Amana Easy Reach AFD2535DE Bottom Freezer...
NO ICE - IC6
George, the ice maker will cycle about every 2.5 hours. Sometimes it takes a couple cycles to prime the lines. You can remove the white cover of the ice maker. On the module you will see two ports, one marked L and another marked V on the left side. Take a insulated jumper wire and jump these two terminals. You are now sending 120V to the valve. See if the water starts coming in. Also make sure the bailing arm is down. Catriver...post back.
Nov 05, 2006 | Amana Easy Reach AFD2535DE Bottom Freezer...
Amana Easy Reach AFD2535DE Bottom Freezer Refrigerator Logo
42 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
