Question about Singer Featherweight 132Q Mechanical Sewing Machine
How do i make a buttonhole on this machine?
I've forgotten how to work the dratted buttonhole foot! I have a shirt with no buttonholes--HELP!!
I do not have a buttonhole foot, but I can tell you how I do it with the zig zag foot on the Singer 132Q machine.
1. Mark the spacing and size for the buttonholes with chalk or marking paper. This consists of a straight line with a perpendicular line at the top and bottom that lets you know how big to make the hole. There is probably a pattern piece to let you know what the spacing should be, and you can get the size of the hole for the top and bottom line by laying the button you are going to use on top of the line you draw with the pattern.
2. Make sure the bobbin has plenty of thread.
3. Put the zig zag foot on the machine.
4. Set the stitch size to 1 or maybe a little less. You want a tight stitch to hold the hole together.
5. Start at the top of the buttonhole with the perpendicular line barely visible in the zig zag foot. Think of it as placing the "T" made by the mark in the "T" made by the opening in the zig zag foot.
6. Set the needle pattern to #1 of the buttonhole pattern (2nd from the top). Make sure it is toward the top of the number to insure you get a wide zig zag stitch. If you are getting a narrow stitch, you may have to fiddle with it, but it will work. Stitch 4-6 times making sure the stitch is wide, and end on the left side of the stitch.
7. Change the needle pattern to #2 of the buttonhole pattern and zig zag stitch down to the bottom mark. Do not pull the fabric or you will stretch the stitch. Make sure your last stitch is on the left hand side.
8. Change the needle pattern to #3 of the buttonhole pattern (same as #1), and zig zag stitch 4-6 times ending on the right side this time. Make sure the stitches are wide.
9. Change the needle pattern to #4 of the buttonhole pattern and straight stitch back to the top mark. Be prepared to hand roll the needle the last few stitches to make sure you do not pass the top stitches you have made.
10. Change the needle pattern to #5 of the buttonhole pattern and zig zag stitch back to the bottom mark. Hand roll the last few stitches and end on the left side.
11. Raise the foot and remove the fabric. You are now ready proceed to the next buttonhole or cut the buttonhole open with a small pair of scissors or a seam ripper. Make sure you do not cut any of your stitches.
Make sure you practice on some scrap fabric of the same thickness (2 layers of fabric plus pellon) to make sure you have the size right before you sew the buttonholes on the garment.
GOOD LUCK.
Posted on Oct 14, 2008
  • Singer Master
  • 1,388 Answers
The machine has a small arm that pulls down and it goes between the two button hole foot stoppers.
Once you place the button in the foot to guide the size, it is all done automatically (in theory).
If you try a few samples is always a good idea.
If you mess it half way, needs to be reset at start position.
Posted on Dec 11, 2011
SOURCE:
Can i use a walking foot to make a buttonhole on my 320 alna sewing machine
I don't see any reason to use a walking foot for sewing a buttonhole. The purpose of a walking foot is to move the top and bottom fabrics together. Feed dogs sometimes tend to move the lower fabric faster than the top fabric--a walking foot helps prevent that.
If you don't have a buttonhole foot for your machine, you can still stitch a buttonhole using a different presser foot.
How to sew buttonhole with an old machine
How to Sew Buttonholes with Regular Foot Sewing Tutorial with Alison Smith
Sewing Buttonholes Without Buttonhole Foot
Sew Buttonhole without Buttonhole Foot by Create Kids Couture
Feb 28, 2018 | Sewing Machines
Instructions for making a buttonhole
The method will depend on your make & model machine, although the vintage sewing machine buttonhole method will work on all zig-zag machines (just requires manually measuring and adjusting the stitch length & width during the process):
How to Use an Automatic Buttonhole Foot
Sew Buttonhole in 4 Steps on your Singer Sewing Machine
How to Sew Button hole tutorial
Be sure there is a stabilizer between the fabric where the buttonhole is located so the fabric will not stretch or tear.
Jan 09, 2017 | Sewing Machines
Buttonhole Foot Not Feeding the Fabric
have you checked the needle to see if it may be bent or damaged
try rolling it on a flat surface
have you also cleaned under the needle plate area where the feed dogs
are, for lint or loose threads
on electronic sewing machine when doing the buttonhole,,the buttonhole lever has to be pulled down before the machine will make a buttonhole, I know mine will not make a buttonhole unless the lever is pulled down .
Jan 16, 2012 | Singer Sewing Machines
I made a test buttonhole that came out perfectly, but several subsequent attempts have resulted in a buttonhole that is only about 1/4 of an inch. I have rethreaded, removed and replaced the buttonholer,...
Are you sure that you are starting each button hole with the buttonhole slider foot back at the front? I know that they are usually spring loaded but is possible that yours isn't returning fully to the starting position.
Also, it is important to prepare the test buttonhole on a fabric sample identical to the garment you will be buttonholing, ie two layers with interfacing between.
I am trying to think what else could be causing this to happen for you. Are you going through the process where you stitch out the first buttonhole, then save this length and then repeat it multiple times. Or using the button in the back of the foot to provide the size of the buttonhole where there is a buttonhole trigger you slide down in place near the pressure foot.
If you have tried and followed the manual precisely and still arent getting a correct buttonhole out of the machine, then perhaps consider taking it to your local dealer and asking them to watch you go through the process and see if they can spot the problem; this should help identify if it is a machine problem or something you've missed in the process.
Good luck, hope you resolve it.
Nov 09, 2011 | Singer CE-200 Quantum Futura Computerized...
I have temporarily misplaced the instruction manual to my White 979 sewing machine. I need to put this shirt in todays mail and I have forgotten the direction to make a buttonhole. I s there a place I...
Automatic BUTTONHOLE making with 979:
  1. Carefully mark the position of buttonhole on your garment.
  2. Slide the button carrier and insert the button.
  3. Attach the buttonhole foot.
  4. Place the garment under the foot so that the needle pierces the fabric at the beginning of buttonhole.
  5. Lower the buttonhole lever and the presser foot lever.
  6. Push the buttonhole lever away from you.
  7. Start machine to complete entire buttonhole.
NOTE:
  • While making buttonholes, maintain an even sewing speed for uniform buttonholes.
  • When buttonholes are completed, be sure to push up the buttonhole lever as gar as it can go.
Feb 11, 2011 | White Sewing 979
I have a old Elna machine. The air electronic SU 390 B. I have lost the manual and am trying to do buttonholes on a dress. I have forgotten the sequence of nob adjustments to complete the process.
Is this the duplex model with the base that fits into a sewing cabinet?
My Elna booklet lists a SP "air electronic" duplex (CL.39), if so, then it would be same stitches as the 38, yellow front panel, 7 built in stitches and automatic knob with blue markings for buttonholing.
Here is the SU manual images for buttonholing, should be exactly the same for the SP.
tally_girl_4.jpg Instructions are:
use buttonhole foot. turn the 3 dials to buttonhole marked in blue (stitch selection, width and length).
Mark length of buttonhol on the material. Place work under foot with the mark in the middile fo the foot, the start being directly below the needle. sew the first side, raise the needle. Turn stitch width dial to 2, blue. Sew a few stitches for bartack. Raise the needle.
Turn stitch width dial to 3 blue. sew the second side. stop just short of the first side. Raise the needle.
turn the stitch width dial to 4 blue. sew a few stitches for bartack. Raise the needle.
Turn stitch width dial to "fastening off stitch" blue dot. Sew a few stitches, holding back the material by hand. Raise needle, lift pressure foot and remove work, triming off threads.
Open the buttonhole with your seam ripper (put a pin across the end to avoid any nasties).
Aug 26, 2010 | Elna 2007 Mechanical Sewing Machine
I keep getting the bl sound when trying to make automatic button
I'd forgotten to pull the little lever down that abuts onto the buttonhole foot! Simple!
Nov 28, 2008 | Janome Memory Craft 9000 Computerized...
Bernina Buttonhole foot #3A
Hi, you must have an 1130S which means it could also be a circuitboard issue. If the LED/LCD light for the buttonholer does not flash you either need a new RET-Print (circuitboard) or a new buttonhole foot. Sorry to say that you DO more than likely need a new buttonhole foot according to my manual on this machine. No way to repair the foot that I know of.
You should bring the machine in and try it first.
Guess not all news is good news. Sorry.
Rick (Bernina tech)
Aug 18, 2008 | Bernina Virtuosa 160
Singer Featherweight 132Q Mechanical Sewing Machine Logo
607 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
Kelley Buchanan
Kelley Buchanan
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
