Question about Swift Telemaster 841 (15-60x60 mm)
Camera mount what is the best way to add a camera mount to this scope
GSI Spotting Scope Manual?,"T" camera adapter? availability?
have a look on ebay, type in t2 under (camera > telescope-binoculars) look for a t-mount similar to the picture added. these t-mounts allow for the focus to be adjusted and the eye piece to remain in place. hope this helps87ec49f6-6cfc-43d9-b599-49b2897eaa42.jpg
Jun 16, 2013 | GSI Super Quality 20x60-80 Porro Prism...
I need to purchase screw that attaches scope to window mount on a 78-4405
The mount has a 1/4-20 screw that fits most camera equipment. If you have the scope (spotting scope) it should have that hole in the bottom of the mounting ring. If the screw is missing from the window mount then most 1/4-20 tripod screws will work or you may substitute a cap screw and flat washer, to work with an Allen wrench for tightening.
Feb 07, 2011 | Bushnell 784405 Tripod
I couldnt zero my leapers 3-9x50 airsoft scope. My shots keep going right. i tried turning the knob to the left (clockwise) until I couldn't turn it anymore. I thought there was something wrong with the...
it could be a faulty mount or a loose mount or you may need to "pack out" the scope to give you more movement 3 strips of 35mm camera film should do,,just pack it at the side of the scope between the scope and the mount
Sep 03, 2010 | Leapers 5th Gen 39x50 AO MilDot Rifle...
Windage adjustment will not adjust to the right - clicks but does not move the shot groups to the right.
if you have forsed the scope turrets you may have broken your scope,,,if the turret turns to the left set it to the center and change the scope mounts or pack out the scope mount with some strips of 35mm camera film 3 strips should do you,
pack out the eye end mount on the left side of the scope
Aug 28, 2010 | Pentax 4-12x40 Gameseeker Rifle Scope...
The is on a 270 it still shooting to the left and there is no more adjustment
the scope mounts are no good then,,,,,but you could try this,,,
cut up 3 bits of 35mm camera film so they will slide behind the scope mount undo the rear scope mount cap (eye end) and slip the film strips into the right side of the mount so they push the rear of the scope over to the left hand side of the mount (as you look at it from the **** end) then nip up the mount cap bolts,,,
this will move the point of aim well over to the "right" some thing like 4-5 inches at 100yds if this still dont line you up,,,
Aug 22, 2010 | Bushnell .22 Rimfire 3-9x32 Rifle Scope...
I need a Vangaurd VT-112 Camra/scope top mount
Try www.TripodQuickRelease.com for that part. There is listed the widest selection of quick releases and support more brands than any other web site I've seen.
Jul 21, 2010 | Vanguard VT112 Aluminum Digital Camera...
I run out of elevation when mounting a scope to my Mini 14. What can I do? I cannot bore site the scope because the elevation maxes out. I use a Leupold boresite device. At the range the gun shoots low,...
this is not that uncommon when mounting a scope on a rifle, the way to get around it is easy
find yourself a strip of old camera film (35mm) cut a strip off and slip it under the eye end of your scope then nip up the top mount this will drop the point of aim in the scope, i use this every time i have this happen to the guys at my club but dont try to put more that say 3 strips of film under the scope or you wont get it to shoot down low,,,
Jan 06, 2010 | Optics
Question about Swarovski Scopes
iv had this problem many times before,,,its more likley to be a bad set of mounts not inline with the barrel,,, if you have ran out of windage adjustment,, to get over it i use a strip of 35mm film inside the scope mount to push the scope over a bit,,, but a new set of mounts would be the best way forwards
Oct 13, 2009 | Swarovski Optik PH6-24x50 Weapon Sight
I have a model D-4 weaver rifle scope with missing adjustment par
Pretty much all rifle scopes have great warranties. Send it into weaver and i'm sure they will fix it plus replace any parts. I'm sure they will charge for missing parts but it would be best for them to look at it and check it out. TP
Apr 07, 2009 | Weaver Optics
SWIFT MARK II, MODEL 841 SPOTTING SCOPE BASE
Hi, I would contact Swift directly on this number: For ordering parts or warranty repair information, please contact Swift Customer Service at 800-523-4544. You can get other contact information and dealer locations on their website: http://www.swift-optics.com/support/faq/dealer The 'scope is mounted on a standard camera tripod thread so you can always check your local camera dealer. Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 13, 2007 | Swift Telemaster 841 (15-60x60 mm)
Swift Telemaster 841 (15-60x60 mm) Logo
Top Swift Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Greg Cann
Greg Cann
Tom Chichester
Are you a Swift Optic Expert? Answer questions, earn points and help others
