Question about Philips Televison & Video
Philips pronto remote problems
I have lost my picture on the tv. Sound is coming from the set top box and hi fi system. I have pressed something on the pronto remote and lost the picture. The tv displays no signal.
    Top Expert:
  • Philips Master
  • 74,383 Answers
Refer the user manual to your set-top box for details.
Posted on Jul 16, 2013
5 Suggested Answers
Techjoel
  • 79 Answers
SOURCE: 4 digit code for handheld remote control to program a Crest Universal remote control
Here are the codes for the RCP3 and RCP5:
RCP3 1023 1024 1074
RCP5 1014 1024 1074
Posted on May 12, 2009
the q guy
  • 393 Answers
SOURCE: Universal Remote used to control Digital converter box
I found that this website should have all the codes and instructions for most remotes
http://www.xdiv.com/remotes/
or http://www.remote-codes.com/
if this helps please give a fixya rating as thats how we get paid.
Posted on Jun 12, 2009
  • 76 Answers
SOURCE: Logitech Harmony 880 LCD / TV screen ''check signal cable''
This is a configuration problem. My guess is that when you set up the "Watch TV" Activity, the input source was not properly selected. Remember, you should almost never need to control devices separately,(as you would with a typical remote). In fact, the only time you need to specifically control a device would be a situation where you need to access a little-used function that was not programmed as part of an 'activity'. Sometimes, you may need to control a device to tweak an activity that did not start correctly, but apart from these situations, you will almost always be concerned with starting "Activities". This is very different from your typical universal remote! Instead of operating 'devices' like your TV, cable box or DVD, you configure and select "Activities" that automatically control the devices that are used during that activity. So, go back into the Logitech software and make sure that your Watch TV activity is selecting the appropriate input. If everything is setup correctly, and you still are unable to go to the correct input, you may need to adjust some of your delay settings, especially the Power-on Delay. Power on delay is the amount of time it takes for the device to turn on and start accepting IR commands. On most electronics when you first turn them on if you hit other buttons too quickly the device will not respond to them. This delay helps to keep that from happening. Hope this helps!
Posted on Mar 10, 2010
SOURCE: I have a Bush DVB-T set top box with no remote how do I program i
I NEED THE DRAWING OF THE CIRCUIT BOARD OF BUSH DVB DFTA 11/A
Posted on Sep 01, 2011
I have lost my remote control for my philips tv. i have a philips set top box with a tv option. i have read up and know that the remote for the set top box can be setup to control the philips tv. i had...
generally you push the "tv" button on the remote first before using any other buttons unless there are dedicated tv buttons. if the remote is preprogrammed for other makes/models then the list of codes will be found in the STB handbook under remote programming.
Aug 10, 2010 | Televison & Video
Sound problem
when you mail me,i have an service manual for you
haas1@kabelfoon.nl
Apr 02, 2010 | Philips 20DV6942 20 in. TV/DVD Combo
Volume lock of philips vardan tv
I hv philips 21RF vardaan TV ,there is sound on AV channel. and the picture is blinking. even some menu setting have changed.. i tried using the service menu but cudnt understand anything. 2 new av channels have come.. av2 and front which were not present before. sound is not coming even on the other channels but picture is fine on them. only on the av1 channel it is blinking., the philips technision had solved this prob once by pressing some code by remote and i don't know the system code
Sep 10, 2009 | Philips 20DV6942 20 in. TV/DVD Combo
Philips TV HDMI CEC EasyLink tries to control Cable set top box
I finally found a fix to this! YAY. I thought I might have to return the TV. I have the Phillips 42PFL5603D, but should work for other models.
On the TV press menu picture settings---picture---dynamic contrast (turn off) AND active control, turn off
If you have Comcast Moto box: on the Cable box go menu--->setup--->cablebox set up---RF BYbass set to ON
If you have a non-Comcast Moto Box, I'm sure there is an RF bypass setting in the menu. You'll just have to look for it. Another fix was close saying to only turn of the active control, but it took all 3 of these for it to work consistently. The latter let it work for all of 30 seconds.
Dec 29, 2008 | Philips 42PFL7403D/27 42 in. LCD TV
How do i tune my philips 3590H philips dvd recorder into digital
The User Manual for your DVD Recorder is available here... http://www.p4c.philips.com/files/d/dvdr3380_05/dvdr3380_05_dfu_eng.pdf
Info related to your specific problem is as follows...
Setting your TV channel
programmes
Before the recorder can start recording
the TV channel programmes, you need to
search for the available TV channels and
store them in the recorder.
Note: Make sure you have successfully
made all the required connections to the
recorder, the TV and Satellite Receiver/
Cable Box (if any) and switched them on.
Tuner settings can only be changed
when there is no disc in the disc tray.
A Press SYSTEM-MENU on the remote
control.
�� The system menu appears on the TV.
B Use ���� keys to highlight
{ System Menu - Channel Setup }
and press ��.
Modify Channel Information
Sort Channels
Channel Search
Edit
Sort
C Use ���� keys to highlight { Channel
Search } and press OK.
�� The automatic TV channel search
starts. This process may take several
minutes. Once complete, the total
number of channels found appears on the
TV.
Automatically scan all the receivable analogue local TV
channels and store these channels on the recorder.
�� Use ���� keys to highlight { Channel Search } and press OK.
�� The automatic TV channel search starts. This process may take
several minutes. Once complete, the total number of channels found
and stored appears on the TV.
Modify Channel Adjust a stored TV channel to your preference, improve the
Information reception and the sound quality of that TV channel.
1) Use ���� keys to highlight { Modify Channel Information } and
press OK.
�� The channel menu appears.
2) Use ���� keys to select one of the options.
{ Name } – You can use the numeric keypad 0-9 to select
the channel preset number which you wish to
change.
– Use ����keys to change alphabet/ number and
use ���� keys to select different entry fi elds, then
press OK to confi rm.
{ Scan Mode } – Select TV channel search mode based on
channel allocation or frequency.
– Use ���� keys to select { Frequency },
{ Channel } or { S-Channel } (Special Channel),
then press OK to confi rm.
{ Frequency } – Shows the frequency of the current TV
channel.
– If required, use ���� keys to start the automatic
frequency search and press OK to confi rm.
{ TV System } – Set the TV system that produces the least
distortion of picture and sound.
– Use ���� keys to select a suitable sound mode,
then press OK to confi rm. (See chapter “TV
System Guide” at the back of this manual for
more information).
{ NICAM } – Turn on or off the digital sound transmission
system which improves the sound quality of the
TV channel.
– Use ���� keys to select { On } or { Off }, then
Dec 12, 2008 | Philips DVDR3380/05 DVD Recorder
Frozen Pronto
Hi
Thankyou for the offer, but I finally fixed it.
I searched high and low on the Internet and finally found a document that led me to believe it was WIFI problem. I reset (switched off and on) the WIFI receiver, and removed/replaced the battery in the remote control and hey presto. it worked and is still working.
Daryl
Sep 11, 2008 | Philips Pronto TSU9400 LCD Touchscreen...
How to set the telelvision to use a dvd,
On the remote ther is a tv/av button. Turn the DVD on and press play and the press that buttom on the tv remote and you will see your dvd playing. Have a good day.
Aug 04, 2008 | Philips Magnavox 27MS343S 27" TV
Connecting it to a tv through a stereo with a cable box
Hiya ... you have a simple lead or set up problem .. ensure that the lead is a good quality one .... and also that the correct leads are atttached where they should be on the tv & stereo... select AV....( this is also dependant on the number of peripheral attachments and their set up to the T.V... ie Digital box.. dvd player... scart or aerial connection)... after checking these... use your T.V controls.. select menu... sounds...external sounds... or digital sounds... something similar....select external devices.... ensure that you have the "phono" selected on your hi-fi.. this should sort your problem.
You should remember also that once you use your Hi-fi to listen to your t.v.... some tv sound systems will.. not allow any of the additional speakers attached to the tv to work ..... you should however be able to manipulate bass/treble settings in certain sound modes via your tv remote.
Alternatively if you have the ROCK/POP/CINEMA...etc selection modes on your hi-fi these can also be used for a satisfactory sound...
Have I understood your problem correctly? and has it helped?
Regards Faggly
Mar 26, 2008 | GoVideo VR3840 DVD Recorder/VCR
Has sound but no picture
When you press the menu button on the TV's remote, does the menu come up on the screen? If it does, then check the cables between your signal source and the TV. If you are using a cable or satellite box and have it hooked up with RCA or S-Video cables, the cables could be bad or have pulled out. If you do not see the on-screen menu, then it means that something has stopped working inside the set, such as the vertical sweep or high voltage. In that case have the set serviced by a qualified tech familiar with projection sets.
Aug 25, 2007 | Philips 51PW9363 51" Rear Projection...
Televison & Video Logo
56 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
