Question about GPS
Garmin nuvi 265
It tells me accessory not supported and seems to restart. repeatedly over and over. I just updated the software and maps this week. could this just be a cord issue?
    Problem Solver:
  • 4 Answers
Could do with a maps update .
Posted on Jul 16, 2013
SOURCE: GARMIN NUVI 200 SAYS NO DETAILED MAPS FOUND THAT SUPPORT ROUTING
From the Garmin web site:
Question: What should I do if my Garmin nuvi / zumo displays the message “No Detailed Maps That Support Autorouting.”?
Answer: Please follow these steps to troubleshoot the error message:
Checking the unit:
  1. Hold your finger down on the screen until the message “No Detailed Maps That Support Autorouting” disappears.
  2. If you get a locked maps message following this error please remove any SD cards in the device and skip down to the instructions for “Getting your unlock codes”.If you did not get a locked maps message then please select tools>settings>map>mapinfo button.
  3. Check the box next to the mapping product City Navigator and you should no longer get the “No Detailed Maps That Support Autorouting” message.
Posted on Jun 29, 2008
I had the same problem. What you do is place your finger in the lower right corner where the green button would be and cut it on. When the prompt comes up, click yes. when the no detailed maps comes up again, hold down the green button again. You should then be able to upload the maps.
Posted on Mar 21, 2009
SOURCE: garmin nuvi says, "no detailed maps found to support routing."
I am very sorry to hear that you are having problems with the unit. You
may need to switch the unit on and press and hold the centre of the
screen until the message ?No detailed maps? message disappears.
If your map detail is missing, then the map information may have been
disabled. To check to see if the mapping has been disabled, follow the
steps below:
From the Where to? and View Map page, touch the Spanner icon, settings
(Tools).
Touch Map.
Touch Map Info.
The unit should display the name of the map that is loaded to the unit.
The box in front of the map name should have a tick in it. If it does
not, touch the box to place a tick in it.
Then please test by searching for an address.
Posted on Apr 02, 2009
RPFinney
  • 385 Answers
SOURCE: Garmin nuvi 205 shows no detailed maps found that support routing
Go to your account at garmin that you created to manage your maps.
Click myMaps
Click Manage Maps
You should see your unit and it’s unlock codes
Copy all the unlock codes for your device
Close your internet browser
Right click on your desktop
Click new, and then click a new Text Document
Click on the newly created Text Document icon from the desktop
Type your unlock codes into the document
Click File and Save as
Change the file name to gmapprom.unl (( double check this please ))
Change the “Save as type” to "All files"
Close the document
You should see the file gmapprom.unl on your desktop
Right click on the gmapprom.unl file and then click copy
Plug your Garmin device in and then click Computer/ My Computer
Click on the nüvi drive
Right click on the Garmin folder and click paste
Safely disconnect your Garmin device from the computer
this resolves the problem for you.
Regards
Richard.
Posted on May 19, 2009
SOURCE: Garmin Nuvi 265 W 'system software missing' message
The system bootloader software got scrambled when you did the update. You can escalate it to a software tech and they may be able to give you the bootloader image file. If not, you'll have to get an RMA and send it back for a unit swap.
Navigation map do not show up, next turn etc. Also show message "no map info".
My problem was cured by reformatting the Mini SD card that holds the map data. I had the same problem this week with my Garmin Nuvi 265. After doing an update I received the "No Data Available" message when trying to use my GPS. After trying three days of so-called fixes I remembered that, at least in my case, the map is stored on a Mini SD card. I pulled the card from my Nuvi and popped it into the computer to see what's on there. There are 4 or 5 files associated with the map. I deleted the files and reformated the Mini SD card using the FAT32 setting. I reinistalled the card into my GPS. Prior to connecting the GPS to my PC, I uploaded the latest version of Garmin Express. Once that was loaded I reconnected the GPS and had to re-register the unit. Once that was done the software told me that there was a new update. I ran the update. Lo and behold . . . after about 25 minutes the map was successfully loaded to my Nuvi and it was working as it should.
Mar 20, 2016 | Garmin nuvi 50 Travel Assistant
Hard format nuvi 245w
Downlaod software from this link RMPrepUSB and chose settings from this picture
Jul 24, 2015 | Garmin Nuvi 200 200w 205 205w 250 250w 245...
Will not let me enter an address.....shows NO MAP DATA AVAILABLE?????
update failed or was corrupt or memory failed or wiped just reconnect to pc an let it update again
May 09, 2015 | Garmin nuvi 1100LM 3.5" GPS w/ Lifetime...
Can not put an address in garmin nuvi
Try running an update with Garmin Express, let it sit for 30 Min after it says it is done, then check again
otherwise you may have jsut installed a smaller region ,... again Garmin express could help.
Aug 04, 2014 | Garmin nuvi GPS
No access to free map or traffic updates. Plugged in traffic accessory that came with the unit, and it tells me that the accessory is not compatible with the unit. The serial number on the bottom of the...
If the Garmin Nuvi is sold with "life-time updates" for maps & traffic - updates are available for download at MyGarmin.com once they are available.
A "life-time update" is coupled to the serial number of the Garmin unit. If the serial number does not match the box with "life-time updates" on it - it could be the Garmin Nuvi came from another box without "life-time updates".
Without "life-time updates" - maps are available for free within 60 days after purchase. A "purchase" is registered by the Garmin device if it detects a certain speed or when it's registered at MyGarmin.com - meaning the 60 day countdown starts. Without a "life-time update" for traffic - a traffic subscription must be bought for a country & timeframe. (ie a year).
Jul 08, 2011 | Garmin nuvi 1300 Car GPS Receiver
I want to update my garmin 260w with free updates on the maps. My unit is 2yrs old.
Garmin provides free updates through their website for the first 60 days after a new unit is put into service. After that, you'll have to purchase map updates. (Software updates are free, though.)
That said, you should first point your browser to www.Garmin.com and go through the process of downloading and installing their browser extension. You might have to reboot your computer or restart your browser to finish the installation.
Return to Garmin.com and register your nuvi. At some point, it will ask you to connect your nuvi to the computer via the USB cable. Do so. Your computer will also go through the process of installing the drivers necessary to view the nuvi as a storage device (so you can download photos and the like).
Once everything is up, the browser extension will tell you what the status is of your nuvi and of its maps. If you're entitled to a free map update, it will allow you to do so. If you're due for a software update, you can do that, also.
Nov 25, 2009 | Garmin nuvi 260W GPS Receiver
Hi I have a Nuvi 265. How do I update the
usually POI comes with the map, you should update the map version in order to get newer POI.
Sep 25, 2009 | Garmin nuvi 265 Car GPS Receiver
Is it possible to get free garmin map updates without paying?
No the map updates must be purchased the software is tied to the unit number and can only be used on one unit. The map udates are available from www.garmin.com or most major department stores.
Sep 02, 2009 | Garmin nuvi 265 Car GPS Receiver
Frozen on 'loading...' page during registration
I can help you reset and fix your Garmin Nuvi 265WT.
Not starting, getting stuck on the flashing Garmin logo, or a message about not finding any maps, are indications that the firmware / system software inside your GPS has been corrupted.
There are three steps to take to get your Nuvi 265WT running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin 265WT WebUpdater to replace its firmware / system software.
I hope that helps.
_____________________________
Nuvi 265WT Manuals here.
Jan 30, 2009 | Garmin n?vi 265WT Car GPS Receiver
2009 map update not loading
Fixed. Called Garmin. It seems that version 4.90 FW on the Nuvi 350 (which came shipped on my 350) has a bug where it cannot communicate with the Garmin software either to update maps or update FW. Tech from Garmin e-mailed me a patch that I copied into the Garmin folder on the Nuvi itself, via USB and Windows Explorer. I then rebooted it; the patch installed itself which then allowed the unit to communicate with the map upgrade software and all is well. 2009 map update is now installed and the Nuvi is working fine again. Haven't tried upgrading to newer FW yet; will probably leave well enough alone.
Jul 01, 2008 | Garmin Nuvi 660 GPS Receiver
GPS Logo
29 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
