Question about Dell Inspiron Mini 1012 Netbook (IM1012799OBK)
Mute how do I turn off the mute button on the speaker icon to turn the sound on
  • 3 Answers
Hi sharon, to turn the sound of ur notebook on, u should look on the task bar of ur notebook and u will see the speak icon, click on it and a pop up box will appear,then u click the speak icon to turn on the speak
Posted on Jul 16, 2013
How to Resolve No Sound on Windows Computer?
Ensure that you aren't muted. The Windows Sound icon is small, and it can be tough to see if you are muted or not. Click the Sound icon in the System Tray and then click the Speaker button in the pop-up that appears to toggle the mute
  • If you don't have a sound icon, then your sound drivers are likely not installed correctly.
Inspect the speaker or headphone connection to the computer. A bad connection is one of the most common causes of no sound, and is also one of the easiest to fix. Make sure that your speakers or headphones are plugged in completely, and that the cables and connectors aren't damaged.
Ensure that your speakers are connected to the right port. Make sure that your speakers are plugged into the correct port on the back of your computer. The green port is most commonly used for external speakers, while the orange and black ports are used for surround sound systems and subwoofers. The pink port is for microphones.
Make sure your speakers are powered and turned on. Many speakers require a power connection, and may need to be turned on in order to work. Check the volume controls on the speakers as well to make sure that they're turned up enough to hear.
Reconnect your HDMI cable. A common problem for HDMI users is that no sound comes out of the speakers that the HDMI cable is connected to. A simple fix for this is to unplug and then replug the HDMI cable, which should switch the default playback device to the HDMI device.
Oct 20, 2016 | Microsoft Computers & Internet
I have my tascam bb-1000cd and a wireless mic into record and there is a speaker icon with a slash across it
A speaker icon with a slash across it = your speaker is on MUTE. Try to turn the sound volume up or if you have a MUTE button on the device, press on it to UNMUTE the speaker.
Nov 18, 2014 | Tascam BB-1000CD Portable CD/SD Recorder
I can't turn up the volume n my laptop
Which operating system ?
Acer laptops are typically sold with pre-installed Windows operating systems that offer sound-adjustment features for increasing the volume on the laptop's built-in stereo speakers. These same functions can also be used in tandem with external speakers or headphones to increase the volume, as well as mute all sound on the laptop. If the computer should output an unusually low volume, fixing the problem may be no more involved than sliding a control switch with the computer mouse.
Click once on the speaker icon in the taskbar on the lower-right corner to open a rectangular window with a slide control. Click and hold the left mouse button on the slide control to drag it upward, increasing the volume to the laptop's maximum setting. Click the "Mixer" button below the slider control to open another window with volume controls for "Speakers" and "Applications," adjusting each slide control upward to increase the volume. Be sure the speaker icon below each control is not accidentally muted. Click once on each speaker icon to remove the red circle with a slash through it, which will restore audio. Click the Microsoft flag or "Start" button in the lower-left corner if the shortcut speaker icon is missing from the taskbar. Click "Control Panel" to select "Adjust Sounds" from the Hardware and Sounds category. Hope this helps
Dec 10, 2012 | Acer Aspire 7741z-5731 17.3" 1.86ghz P6000...
How to unmute microphone (microsoft Vista)
::Look EASIEST WAY OF THEM ALL RIGHT HERE::
[1] --> Right Click the Volume Icon at the bottom right corner of your screen [The Task bar].
[2] --> Click [Playback Devices]
[3] --> Right Click the [Speakers] Icon and click Properties
[4] --> Click the [Levels] Tab; and there you will see the Microphone Volume slider (The one at the very bottom of the "HD Audio output" and "PC Beep" sliders where you can un-mute the mic playback (By clicking the unmute icon, than slide the volume up to where you prefer it... Simple smile.gif I hope I was able to help someone with this... wink.gif
Dec 26, 2010 | Computers & Internet
No sound when computer is being shut down or playing music on windows media player. button next to power button not lite up. push mute button back off still cannot get a sound.
Check the volume controls and sound properties. Make sure that the master volume ins not in "MUTE".
Double-click the speaker icon on your tool bar. The volume controls will appear.
Check the Sound properties:
Right-click the speaker icon > Adjust Audio Properties:
Audio tab > make sure to select the right sound device.
Thank you and good luck!
Sep 12, 2010 | Dell Latitude D600 Notebook
How do i turn off the sound
You can use the function button in your keyboard + Mute sound button in the top keyboard rows to mute and unmute the sounds.
(fn key + Mute symbol key)
I hope this is helpful to you.
Thanks
Apr 26, 2010 | Dell Inspiron 2200 Notebook
Acertravelmate4000 got it used,don,t know how to turn off mute,turn on or up volume
The volume may be muted. In Windows, look at the volume
control (speaker) icon on the taskbar. If it is crossed-out, click on
the icon and deselect the Mute option.
The speakers may be turned off. Press Fn-F8 to turn the speakers
on (this hot key also turns the speakers off).
The volume level may be too low. In Windows, look at the volume
control icon on the taskbar.
Fn-? Volume up Increases the sound volume. Fn-? Volume down Decreases the sound volume.
If this helps u let me know
regards
Jan 12, 2010 | Acer Computers & Internet
Warning label on screen
It sounds like a 'mute' icon. Check for a corresponding button on your remote control.
Just to clarify - You say the TV sound is fine but you do not use the built-in speakers...
Can you actually get any sound out of the TV speakers? If you can't it is because the TV is on mute (For your type of setup you will need to turn it off mute and then just turn the volume all the way down.)
If you can get sound out of the built-in speakers and the icon is still showing, it is almost certainly going to be a fault with the TV. You could try unplugging it, leaving it for a minute or two and then plugging it back it. This may well reset it.
Hope this helps!
Jun 30, 2009 | iLO LCT32HA36 Television
Speakers are not making any sounds
ok let's try a simple test.unplug the the usb.i hope that your speaker has its own power supply.turn it on.try to touch the inputs of the speaker, you should hear humming sounds.if yes, then your speaker is ok.if the speaker is getting its power from the USB port, i suggest you should use its independent power.the USB does not have enough to supply your speakers. try also the output jacks for built-in audio of the pc, ok.
May 31, 2009 | Insignia 2.0 Speaker System (2-Piece)
No sound
Check the speaker icon in the taskbar at the bottom, if there is an X then it is muted. Right click to unmute.
Also as it is a laptop there may be a mute button on the keys using the function button and a typical mute icon on a key or even a seperate button altogether.
Mar 18, 2009 | Microsoft Windows XP Home Edition
Dell Inspiron Mini 1012 Netbook (IM1012799OBK) Logo
43 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
