Question about Dryers
Our dryer works but it does not heat up. - Dryers
  • 2,272 Answers
Here are the most likely problems, starting with the most common to the least common.
The inspection, testing, and repair will require dismantling the machine.
1) The heating element has failed, needs replacement.
2) One of the "overheat thermostats" or "fuse" has tripped, needs replacement.
3) A wire has burned in two inside the back or bottom of the machine, needs repair. ( Near the heating element)
4) A wire has burned in two inside the back of the machine where the electrical cord is attached, needs repair.
5) A circuit breaker has tripped in your fuse box or circuit breaker box, wherever that is in your house/apartment.
Be blessed.
Posted on Jul 16, 2013
Dryer works but timer doesn't move. I just replaced it and still having the same problem.
Kenmore 400 6942 Dryer Heat timer - Questions - Fixya
www.fixya.com > Forum > Dryers > Kenmore > Kenmore 400 6942 Dryer
Kenmore 400 6942 Dryer, heat timer related issues. ... The timer doesn't work. ... the heat turns back on the timer stops,heat shuts off the timer will move again,if the ... not heating/timer knob not turning . the dryer works but is not heating and i ...
kenmore 400 doesn't heat, and timer doesn't move, but dryer ...
www.shopyourway.com > Manage My Life > Questions
I understand your Kenmore 400 Dryer doesn't heat up or the timer doesn't move, butit tumbles sometimes. I found the manual for your Kenmore Dryer in ...
Fixing an Electric Dryer that Doesn't Heat and the Timer ...
? 5:51
https://www.youtube.com/watch?v=0mo_gw0p2CI
Jun 29, 2013 - Uploaded by SamuraiRepairman
Although electric dryers are the simplest appliance to work on, ....and now the dryer won't heat and the timer doesn't advance, butthe motor still runs? .... Diagose a Whirlpool or Kenmore Dryerthat Keeps Running, Wont Shut ...
Dec 21, 2015 | Kenmore 400 6942 Dryer
My ge gas dryer works but no heat
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
Check out this tip that will give more details…
Gas dryer not working gas dryer not heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
Check out this tip to see the things that can fail to cause your electric dryer not to work.
Dryer Troubleshooting Electric dryer wont heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Aug 24, 2010 | GE Dryers
Dryer will not heat. It would initially heat but then the heat would stop.
heatman101
Aug 23, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Model #w8w2780wcwww over and under. dryer works but does not heat. ge model
heatman101
Aug 23, 2010 | GE Dryers
Heats up shuts off wont heat back up
heatman101
Aug 23, 2010 | Whirlpool LGR3624JQ Gas Dryer
Heat comes and goes, most of the time no heat but sometimes heat comes on
heatman101
Aug 21, 2010 | Maytag Neptune MDG5500AW Gas Dryer
My dryer wont heat up. The ignitor coil glows but it only heats up on occasion.
heatman101
Aug 19, 2010 | Whirlpool Dryers
Our dryer works but does not heat up. this is onl...
if you dryer is gas check out this gas no heat tip....
check out this electric no heat tip...
heatman101
May 20, 2010 | Maytag Neptune MDG5500AW Gas Dryer
KGYS850LT / KGYS850LE / KGYS850LQ Gas Dryer: The drier is working fine just no heat?...
heatman101
May 18, 2010 | KitchenAid KGYS850LT Gas Dryer
The timer doesn't work. The dryer just runs until
is the heat working?when the dryer heats up and then the heat will shut off then the timer advances,when the heat turns back on the timer stops,heat shuts off the timer will move again,if the heat is working you could have a bad timer
Mar 12, 2010 | Frigidaire GLER341A Electric Dryer
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
