Question about E-Machines eMachines Desktop PC
My screen reads no signal - E-Machines eMachines Desktop PC
  • E-Machines Master
  • 27,725 Answers
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your (motherboard to your hard drive) make sure they have secure dust free connections and are not faulty
if its a 40 pin flat ribbon type it will be the first to fail
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty
even something as small as a faulty electrical fan and its lead can cause you problems
computers need all power and data to continue through every working device and to have an end so any faulty leads will end up with a computer error
Check your RAM.
The RAM is located in the middle of the motherboard.
There are tabs that you can push to release the RAM.
Remove it and put it back in place until the tabs pop out.
Loose RAM can cause your computer not to start properly where you want to see a video signal.
Make sure your graphics card is securely seated with no dust built up or in the socket
if you remove your graphics check the socket to make sure its dust free
Restart your computer then reinstall it this should activate found new hardware wizard
Check the vga lead for secure dust free connection or try another vga lead.
Posted on Jul 16, 2013
The tv is stuck on this screen with the error message weak or no signal I need help on the steps to fix it
I can't read the screen, but weak or no signal means the signal coming in from the cable box or outside antenna is not good.
You would need to check the box and the cable connections.
Dec 19, 2012 | Televison & Video
TV screen reading no signal. We have satellite
tune in tv or put tv in AV / EXT mode the no signal means not tuned or on areal in tv
Nov 28, 2009 | Sony Televison & Video
My monitor ( with less that 6 months use) has been going off while someone is using it--- says out of signal and i have to restart the comouter... and this is not stopping even with a restart
julezj, You will need to connect your monitor to a KNOWN GOOD pc that DOES NOT have the screen saver set to do a time out when the keyboard is inactive. Whenever you state a problem with a monitor on fixya, please mention the monitor technology you are dealing with. CRT (TUBE) or LCD flat screen!! IT HELPS IF WE KNOW TOO!!! Did it really display a screen message that read "out of signal" or did it read "OUT of RANGE SIGNAL"??? Is this monitor used to display HIGH resolution gaming and other high refresh rate imaging? Will this happen if you only have the WIN-desktop showing on the screen? Get back to me with more CLUES as to what happens on the screen. 12fixlouie Bye for now.
Nov 25, 2009 | Gateway Computers & Internet
My plasma screen reads no signal and not available
I am sorry. I have searched and searched and e-mailed and phoned about 20 plus people about this question. No one can come up with one straight answer. Haier themselves don't even know. I would suggest taking it in because it doesn't sound like a self-fix problem.
This is the most help I can give you.
http://www.nytechtvrepair.com/haier_tv_repair.html
Jan 16, 2009 | Insignia LCDTV26 26 in. Television
Well make sure it's on the right source, I have a 50 inch Samsung and when you're on the wrong channel it'll read no signal and you can't do anything. So make sure you have cable hooked up right and make sure it's on the right source or video channel first. I don't know but this might help.
Dec 21, 2008 | Panasonic TH-42PWD6UY 42 in. HD-Ready...
Humm coming from speakers - can't get cable to work
The RF input is the correct one for a cable signal. The other sources use the RCA and other ports which you can connect to other devices, like DVD or VCR players.
If the humm noise only happens when you're on the TV channel then it's likely just the station. Try changing the channel and see if that helps, and make sure the coax is screwed in all the way. Also make sure the other end, if connected to a VCR or other stuff, is tightly attached. If you share cable with many other people and the signal has snow (white spots on the TV), then you may need to buy an RF signal amplifier to reduce the noise.
Source changes the input (RCA versus coaxial versus component inputs), change the channel for different channels..
Jan 31, 2008 | Akai LCT2701AD Television
E-Machines eMachines Desktop PC Logo
19 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
