Question about Acer eMachines Black EL1850G-42w Desktop PC with Intel Celeron E3400 Processor and Windows 7 Home Premium... (884483099900)
The screen reads no signal - Acer eMachines Black EL1850G-42w Desktop PC with Intel Celeron E3400 Processor and Windows 7 Home Premium... (884483099900)
  • Acer Master
  • 27,725 Answers
EMachines flat-screen monitors offer high quality at low cost.
eMachines flat-screen monitors are compatible with most brands of PCs.
Issues with eMachines flat-screen monitors can arise from faulty power sources, cable problems and incompatible settings.
These issues can be resolved by testing step-by-step each possible cause.
Plug the computer's power cable firmly into a working AC outlet.
Press the computer's power button.
Check the LEDs on the front of the computer case to confirm that the computer receives power.
Plug the eMachines monitor's power cable into a working AC outlet.
Press the monitor's power button.
Check the LEDs on the front bezel or power button of the eMachines monitor to confirm that the monitor receives power.
Orange or blinking LEDs indicate low power or no signal.
Green LEDs denote a working connection..
Perform a monitor self-test.
Switch off the monitor.
Unplug the video cable from the monitor.
Press the eMachines monitor's power button.
An eMachines logo, Windows logo or "no signal" message indicates that the monitor is working properly.
Plug the eMachines monitor's video cable into the video port on the computer.
Attach the monitor's included DVI-to-VGA adapter to the monitor's VGA cable if your computer has a DVI port (15 or 25 pin-slots with 1 side slot) in place of a VGA port (15 pin-slots, no side slot).
Press the eMachines monitor's input button to change the monitor's setting to match the computer port used.
Set your monitor to DVI if connected to your computer's DVI port.
Set your monitor to VGA if connected to your computer's VGA port.
Connect the eMachines monitor to a known working computer with a known working video cable if the problem persists. Contact Gateway, eMachines manufacturer, if the monitor issue is not resolved.
Posted on Jul 16, 2013
The tv is stuck on this screen with the error message weak or no signal I need help on the steps to fix it
I can't read the screen, but weak or no signal means the signal coming in from the cable box or outside antenna is not good.
You would need to check the box and the cable connections.
Dec 19, 2012 | Televison & Video
TV screen reading no signal. We have satellite
tune in tv or put tv in AV / EXT mode the no signal means not tuned or on areal in tv
Nov 28, 2009 | Sony Televison & Video
My monitor ( with less that 6 months use) has been going off while someone is using it--- says out of signal and i have to restart the comouter... and this is not stopping even with a restart
julezj, You will need to connect your monitor to a KNOWN GOOD pc that DOES NOT have the screen saver set to do a time out when the keyboard is inactive. Whenever you state a problem with a monitor on fixya, please mention the monitor technology you are dealing with. CRT (TUBE) or LCD flat screen!! IT HELPS IF WE KNOW TOO!!! Did it really display a screen message that read "out of signal" or did it read "OUT of RANGE SIGNAL"??? Is this monitor used to display HIGH resolution gaming and other high refresh rate imaging? Will this happen if you only have the WIN-desktop showing on the screen? Get back to me with more CLUES as to what happens on the screen. 12fixlouie Bye for now.
Nov 25, 2009 | Gateway Computers & Internet
My plasma screen reads no signal and not available
I am sorry. I have searched and searched and e-mailed and phoned about 20 plus people about this question. No one can come up with one straight answer. Haier themselves don't even know. I would suggest taking it in because it doesn't sound like a self-fix problem.
This is the most help I can give you.
http://www.nytechtvrepair.com/haier_tv_repair.html
Jan 16, 2009 | Insignia LCDTV26 26 in. Television
Well make sure it's on the right source, I have a 50 inch Samsung and when you're on the wrong channel it'll read no signal and you can't do anything. So make sure you have cable hooked up right and make sure it's on the right source or video channel first. I don't know but this might help.
Dec 21, 2008 | Panasonic TH-42PWD6UY 42 in. HD-Ready...
Humm coming from speakers - can't get cable to work
The RF input is the correct one for a cable signal. The other sources use the RCA and other ports which you can connect to other devices, like DVD or VCR players.
If the humm noise only happens when you're on the TV channel then it's likely just the station. Try changing the channel and see if that helps, and make sure the coax is screwed in all the way. Also make sure the other end, if connected to a VCR or other stuff, is tightly attached. If you share cable with many other people and the signal has snow (white spots on the TV), then you may need to buy an RF signal amplifier to reduce the noise.
Source changes the input (RCA versus coaxial versus component inputs), change the channel for different channels..
Jan 31, 2008 | Akai LCT2701AD Television
Acer eMachines Black EL1850G-42w Desktop PC with Intel Celeron E3400 Processor and Windows 7 Home Premium... (884483099900) Logo
287 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
