Question about Pool & Spa
Starite pump jwpas5f2a4
Return hose to filter broke. Pump ran approx 45 minutes dry. Replaced the hose, cut pump on and it's VERY LOUD now. Still functions as it should. Help!!
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 79 Answers
Its probably ruined the internals of the pump. You will need it rebuilt or replace it. The water is what cools and lubricates the pump. Hope this helps. Chris
Posted on Nov 06, 2014
5 Suggested Answers
john224
  • 1378 Answers
SOURCE: I have a Sta-Rite Max-E-Glas II (1.5hp) Pool pump
Is the pump leaking water? If you lost the prime or are having trouble priming then there would be an air leak somewhere on the suction side of the pump. Poor suction would interfere with the sweep. One way to ell if the pump or suction line(s) are leaking is to examine the inlet basket once the pump is primed. Any air left in there after a few minutes of operation once primed would indicate a leak in the suction/pump.
Posted on Jan 04, 2010
Coastsider
  • 331 Answers
SOURCE: I turned my starite pump on and it just hummed for
Your pump motor or impeller is seized. Disassemble the pump housing and check the impeller to see if it spins freely. If not then check for debris, if impeller appears to be free of debris, then check the shaft seal and motor. If the shaft seal is leaking water, then the motor bearing is likely rusted and will need to be replaced. There are 2 bearings, replace them both along with the shaft seal
Posted on Apr 14, 2010
macdirk
  • 116 Answers
SOURCE: I have a System 3
Sounds like you have a minor leak somewhere. most likely when the system is off the water is siphoning back into pool, and air is slowing seeping into system. Air can be getting in anywhere there is a joint, fitting, valve, seal, union, etc. Leaks can be broken down into two types: leaks on the suction side and leaks on the pressure side. Leaks on the pressure side are relatively easy to spot as you'll see water leaking while the system is running. Leaks on the suction side are harder to find as they **** in air which is obviously not easy to see or find. When the system is running look closely for leaks everywhere. If you find any fix them one at a time till the problem goes away. On the suction side, try wiggling and twisting things to see if you can find anything loose. Replace all union o-rings, the pump basket o-ring, leaf trap o-rings, etc., and see if problem goes away. If you have any 2 or 3-way jandy valves, try turning them while the system is running and see if any air gets in the system. If so you probably need to replace those o-rings as well. If you suspect air is leaking at a fitting somewhere, take some black electrical tape and wrap it tightly around the joint several times to fill the crack (this only works on suction side) this is a temporary repair, but works great to find and temporarily fix an air leak. I've seen people leave a repair like this for over a couple years and still work find, although I don't recommend it. If you find a leak at a pvc fitting, or a threded fitting that is not easy to fix, for example you may need to cut pipe and re-plumb several fittings and valves, there is another type of temporary repair that sometimes works very well. What you do is clean the area very well, take some RTV silicone sealant, and rub it as best you can around and into the leak, then turn on the pump for about 2-3 seconds (this sucks the glue into the crack) then rub more glue into the area as best you can. let this dry over night. If you still can't find the problem you most likely need to call a leak detection company, or get creative and start plugging and pressurizing things to find the problem.
Posted on Sep 19, 2010
  • 35 Answers
SOURCE: Our pool/spa pump will cut
If the motor is very hot it could be shutting off due to a thermal safety device.
Anything that makes the motor work too hard and/or heat up will trigger this.
Blockage in the water lines
Clogged pool filter
Worn motor bearings
Lack of air flow around the motor
Weak or damaged motor windings.
A defective thermal limit switch will **** off the pump when the pump is within heat and load limits.
Posted on May 22, 2011
2003 liebherr 912 running for 10 minutes and then shuting off
Hi There maybe dirt in the bottom of the tank plugging the line up.
also check for air in injection pump. The pump must be blead out.
Hope that helps.
Jan 13, 2014 | Liebherr Excavator
Sta Rite Pool Pump
Probably need new pump if the impeller broke.
If impeller broke, then motor will run, but no water circulates
Call pool company.
Motor resources:
http://waterheatertimer.org/Color-codewire.html#motor
Apr 18, 2013 | Sta Rite Pool & Spa
Water return hose leaking on
Your post got cut off. Leaking on ...what? If the hose is loose, may need to just tighten the hose clamp. If the hose is ruptured, replace the hose.
There are only 2 water return hoses: from heater core to engine, and from radiator to engine- this big hose connects to the water pump on the front of the engine- If it's leaking there, you must determine if it is the hose or the water pump[. If it's the pump it will have to be replaced. Here's hoping it's just the hose. Good luck. Post back for more.
Jul 08, 2012 | Cars & Trucks
Hello, Volut cracked overnight and leaked for several hours, drainig the pool down well over 1 foot. Next day, replaced volute, but now polaris is not functioning. Water is being pumped into the...
With a new volute the most likely causes for low pump flow is a restricted return line, a restricted suction line(or air leak), or there is something wrong with the impeller in that order. There is a filter screen in the return line that can cause the return line to be restricted if it is plugged. It is either in the wall fitting or in the tubing system close to the wall fitting. If it is dirty it means that debris is getting into the system. Typically an early indication that a grid in a DE filter has a leak in it is a plugged cleaner filter screen. The speed of the motor could be causing the problem but this is rare without causing an over current condition in the motor causing it to shut off. My suggestion is first check the return filter screen. If it is dirty then clean it out. Before connecting the return hose start the pump and check the flow by reaching down and manually putting your hand over the water stream coming out of the wall fitting. Turn off the pump and connect the cleaner hose without the filter screen installed. Disconnect the hose from the cleaner and hold the end of the hose while someone turns on the pump. Water should come out of the hose at a high rate. Next install the filter screen and the flow coming out of the hose should be about the same. Now try connecting it to the cleaner. I hope this helps.
Aug 07, 2011 | Polaris Pb4 - 60 Booster Pump
I have a P6RA6f-2006L Sta-Rite pump for my pool. I just opened the pool and run the pump for about 6 days continuously. And the pump stopped some time today. When I turn it on, I heard loud sound but...
More than likely, the bearings are going out on the motor. Usually you'll hear a loud screeching sound when this happens. You have 2 choices here. You can either take the pump to a local repair shop and have the bearings replaced, or you can replace the motor and pump seal. By replacing the bearings only, you're not guaranteed that the motor will last much longer. I always recommend replacing the motor and seal that way you'll be trouble-free for another 4-6 years.
Jun 16, 2011 | Sta Rite Starite Maxepro 15 Hp Ur Pool...
'89 Jeep Comanche Fuel pump not pumping fuel.
If the pump is running with the key on, and you have a hose coming from the pump with no obstructions in the way (such as a fuel filter) and there is no fuel coming out of that open hose, then you need to remove the pump and find out why. It cannot run without pumping something out of the hose (unless you have it connected to the wrong hose (vent or return line) Voltage is important, but if it's running even if volts are low, it still will move some fuel.
Aug 15, 2009 | 1989 Jeep Comanche
Mazda etude 160ie a/c cuts out after approx 45 min driving.
Could be an electrical part that only fails after getting really hot. Coils and ignition modules are known for this. Unfortunately, these parts cannot be tested for this heat-soak type problems, other than to see if spark quality at the plugs has degraded when failing. One other thought. A bad gas cap which is not allowing air to flow in as gas is used can cause this and that is a cheap part to replace just for grins.
Jan 10, 2009 | 2003 Mazda MPV
Pool & Spa Logo
77 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
