Question about aFe 2009 Volkswagen Jetta - TDI - Air Filters
VRL warning light - aFe 2009 Volkswagen Jetta - TDI - Air Filters
I changed the bulb but it keeps saying replace bulb
Look through the settings to see if there is a reset option for warnings or for lamp warnings. Many products with lamps require you to not only replace the lamp but to reset the warning.
Oct 18, 2012 | Ecoquest Fresh Air Air Purifier
How do you change the filter? My in-laws have lost the instructions for their purifier.
You have a Honeywell air filter. Turn it over and there is a big handle which is a screw in the middle. Unscrew it and then lift the entire unit up without the outside screen protection. The filter will have a black pre-filter attached by velcro. Remove it, take outside put on the grass and hose out against the flow of air. (squirt from the inside out to remove stuff). Then use vacuum to blow the filter from inside to the out. Then vacuum the filter from outside in. Let the pre-filter dry. re-install in reverse. If there is a warning light, run on full, then push the warning reset for 10 seconds or more to turn it off.
Mar 01, 2011 | Duracraft DA5010 Air Purifier
Replace air filter warning light to reset?
1. Plug unit into outlet. 2. Press power ON/OFF switch to the ON position. 3. Allow unit to start running at low speed. 4. PRESS and HOLD both the UP and DOWN arrow buttons until the FILTER REPLACEMENT INDICATOR starts to blink. 5. Release both the UP and DOWN arrow buttons. 6. While the FILTER REPLACEMENT INDICATOR is still flashing, again PRESS and HOLD both the UP and DOWN arrow buttons untile the FILTER REPLACEMENT INDICATOR turns off.
If the steps above have been performed properly, the Filter Replacement Indicator will turn offand not flash again for 11 months. If the Filter Replacement Indicator remains on, repeat the steps again.
*Note that in step 6 above, the Filter Replacement Indicator MUST still be flashing when the buttons are pressed the second time.The Filter Replacement Indicator will continue to flash for approximately 3 seconds after the buttons are released as required in step 5 above.
Sep 30, 2010 | Filter Queen Defender Air Purifier
Model 30375 replace filter light
There is a "RESET" icon next to the warning light. See the tiny hole? Get a small toothpick or something similar and simply insert, push, and watch the annoying light go out!
Jun 21, 2010 | Hunter 19' X 21' Room Air Purifier Air...
I placed the filters back in , but the clean red light is still on. this is an ionic pro compact cleaner
Try unplugging it, for a few minutes and wait then plug it in again and see if it resets.
Otherwise you need to reset it.
Most appliances that displays warnings have to be reset after it is corrected.
even your trusty automobile check engine light.
good luck.
Jan 30, 2010 | Sharper Image Ionic Breeze 3.0 Air...
Clean Filter Red light
I cleaned the filters as well earlier and the red filter light still blincked to clean the filters. Then I pushed the power button for about 10 seconds continously and then turned it on and the light turned off.
May 22, 2008 | Brookstone Pure-Ion UV Air Purifier
Fans not working
Yeah, I had this happen to one of mine, the motor bearing siezed. Even though mine had run out of warranty and I kludged a fix for it Oreck replaced it anyways after inspecting the unit.
Temporary kludges that worked: light machine oil on the motor bearing, flipping the motor over internally, turning the unit on its edge so that it rides on a 'fresh' part of the bearing, running the unit on 'high' while I was out of the house.
Apr 27, 2008 | Oreck XL Professional Air Purifier
Hunter 730 carbon pre-filter replacement orange light
Filter lights on your Air Purifier http://www.fastbrowser.net/netpicker/Filter-lights-on-your-Airifie.htm One of the best things about your IQAir Air Purifier is that it has warning lights to tell you when to change the prefilter, gas or hepa filters. Of course how long they last depends on your pattern of usage. For the initial 80% of the filter life the control panel will display a green light next to the corresponding filter on the outline of the unit. When the orange light goes on it does not mean that the filter needs to be replaced immediately but that there is 20% of useful life left. IQAir gives you plenty of time and the machine will tell you how many hours you have left. Once the number of hours gets to within a few hours remaining the orange light will then change to red. It is at this time you should change the filter. If you forget to change it and there are no hours left the hours will go into the negative displaying how many hours you have gone over and the red light will change to a flashing red light.
Just in case you have lost the manual like one of our customers, this is how you reset the filter lights:
1. Press the menu button ( 7 times) until you get to where the display says new filter.
2. Press the enter button and hold it down for 3 seconds and a number 1 will be flashing after the words new filter on the display. This flashing number is so you can enter which filter you have changed. Filter number 1 is the pre-filter, filter number 2 is the V-5 gas filter, and filter number 3 is the Hepa filter.
3. You change the number for the filter by pressing the up arrow button.
4. Once you reach the correct filter number you press the enter button and the control panel will display a question mark after the words new filter on the display. Below this it will say, E = Yes M = Cancel. If you wish to cancel the entry so it does not reset a new filter life, simply press the Menu button.
5. If you want it to reset the filter life for the changed filter, simply press the Enter button. Once this is done, the filter light will change back to the green light, which will show the filter has been changed. If you go to the remaining filter life on the control panel for the filter number you just changed, you will now see the remaining life of the filter in hours has been reset.
  • When most people think of Oreck, an air purifier is usually not the first thing
  • IQAir Dental Series Air Purifier
  • UV air purifiers are very effective at neutralizing airborne pathogens
  • HEPA Air Purifiers
  • REPORT ON THE AIR QUALITY CLEAN UP IN OUR OFFICES
  • Ozone Air Purification
  • Ionic air purifiers come in three different forms
  • WHOLE HOUSE HEPA
  • Dehumidifiers - Ebac Orion
  • Furnace Filters, Electronic, Electrostatic Air Filters - Comparisons, Ratings,
  • Nov 26, 2007 | Hunter 30216 3-SPEED FLOOR MODEL Air...
    Red filter indicator light
    Hi Linda - there is a "reset" hole - you have to stick a pin or a paper clip in the hole when you change the HEPA filter - I just found this out myself! It does work. Mine didn't work right away, but it did end up resetting and went back to green after a few moments. I think this happened to me last time. The filters are really expensive, but you can get them at Walmart. If you need more information, email me at marixyz@aol.com and I'll tell you what model filter, etc.
    Nov 05, 2007 | GE HEPA 106653 Air Purifier
    Reset filter
    The solution is simple. Just press on the little red light that says to reset filter. Its a button that will reset the warning and the light should go out
    May 14, 2007 | Kaz Honeywell Tower Air Purifier with IFD...
    aFe 2009 Volkswagen Jetta - TDI - Air Filters Logo
    22 people viewed this question
    Top aFe Air Purifiers Experts
    Dan Webster
    Dan Webster
    Pcm2048
    Are you an aFe Air Purifier Expert? Answer questions, earn points and help others
