Question about Genesis Onyx 29" Cruiser Bicycle
Where can I find 29" innertubes for my Genesis Onyx bicycle...
What is the spindle size of this bike?
Perhaps if you took it to a local bike shop they could assist .
Dec 29, 2015 | Genesis Onyx 29" Cruiser Bicycle
Stripped handle bar adjustment piece
Your bike appears to use an adjustable stem, which allows rotation to change the height/reach. Although such stems are a fairly new feature, they have been successfully used for several years. Apparently the one spec'd for your bike is not very sturdy. See the posts below from two people who had a similar problem. I suggest you complain to Walmart and ask for a fixed position replacement or a partial refund so you can choose your own stem.
My latest love hate bike the Genesis Onyx 29 beach cruiser
Genesis Onyx 29 Cruiser
Oct 16, 2017 | Cycling
Inner tube tire
Non-standard tube sizes drive me crazy. I did find that WalMart sells the tube on its website:
Walmart 32 Bicycle Inner Tube
This is probably your best bet, as your local bike shop may not stock this tube size because LBS bikes typically stop at 29 inch.
Feb 01, 2014 | Genesis 32" Mens Beach Cruiser Bike, Blue
How to adjust handle bar
Every bike has same way to adjust handle bar and that is pretty easy to adjust.
Please watch movies I attached.
Jan 16, 2014 | Genesis 29" Astra Mens Beach Cruiser Bike
Assembly manual
To remove the crank (the arm the pedal is attached to), you'll need a special tool. I got mine at a bike shop. (Bike shops are our friends.) I use the Park Tools CWP-7. It's pretty much a big bolt with a smaller bolt going through it. You'll remove the cap covering the spindle bolt (if it hasn't fallen out already), remove the bolt that holds the crank are onto the spindle, then thread the "big bolt" part of the tool into the threads for the cap on the crank. You'll then screw the inside bolt into the big bolt, which will push the crank arm off of the spindle.
Dec 30, 2013 | Genesis Onyx 29" Cruiser Bicycle
29" Genesis Onex manual
Manuals are generic, very seldom apply to just one model, and mostly just have safety and very basic info. The Onex is a very basic bike - just a rear derailleur and V brakes. Maintenance is the same as for any similarly equipped bike.
Dec 21, 2013 | Genesis Onyx 29" Cruiser Bicycle
Need manual for Genesis Onyx 29" Cruiser Bicycle
I need Manual complete the " 29 men genesis onex"
Aug 09, 2013 | Genesis Onyx 29" Cruiser Bicycle
My innertube leaks air and i am no familiar with the air intake device on it
There are two kinds of valve on bicycle tubes, Presta and Schrader. You are probably more familiar with Schrader because this is the type used on cars and most bikes. And I am guessing that you have Presta on this bike (Presta is skinnier than Schrader, and it has a little nut that you unscrew, where Schrader has a spring inside it. Google images for "Presta Schrader" and you will see both kinds, and you will also see a little screw-on adaptor that you can use on a Presta to make it fit your pump or air-hose like a Schrader. You can buy these adapters on-line or at any bike store. Good luck!
Oct 03, 2012 | Fuji Bicycles Cross Comp
Need instructions for installing innertube into a bike tire
Remove the wheel from bicycle.
Take the air off the wheel, by pressing with small screw driver or fingertip on the valve while make pressure on the tyre
With the help of a tyre remover lever or with somekind of non sharpie lever, put it between the tyre bed and the tyre and try to take the edge off the bed. Once you got one put another aroun one inch appart and repeat the procedure, then try to slip one of them all around the wheel and you will end with one side of the tyre off the wheel.
push the valve of the innertube in and pull off the innertube.
Put the new innertube inside the tyre and push the valve throught the orifice on the wheel.
By hand, try to put the tyre back on the bed, is good idea at this point put some air on the innertube, but not too much, just enought to get in the tyre and far from the tyre bed.
If not possible to put the tyre back on the bed by hand use the same tool to remove, but be very very carefull not to pinch the innertube, because is very easy to pinch it.
Put air on the tyre and put it back on the bicycle
May 15, 2010 | Cycling
Genesis Onyx 29" Cruiser Bicycle Logo
71 people viewed this question
Top Genesis Cycling Experts
rdjagger
ray gallant
dante
Are you a Genesis Cycling Expert? Answer questions, earn points and help others
