Question about Acer Computers & Internet
Panam I am working another laptop but need to get on the internet on my acer laptop. When I try to connect it says windows cannot fine any networks. I know that the networks are working because the computer that I am using now is on the network
  • Acer Master
  • 27,725 Answers
You will have to open up your network connections
Click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark ! ?
you will need to update or install the driver or it could be firewalled.
Make sure your antivirus program is not blocking the internet connection.
If you are trying to connect through a modem/router you it should have come with a disk then
you might have to connect the usb lead to your modem to get a connection then
Click start control panel administration tools computer management device manager scroll to network adapters should see a yellow question ? exclamation mark ! or a red X right click install drivers.
The driver might be on the disc supplied by your ISP internet service provider
or the motherboard disc
You only need to check the BIOS if you cant install the driver
Make sure you Ethernet/internet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to
press to enter set up (BIOS) press and hold that key to enter bios using arrow keys navigate to integrated peripherals look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its
"Enabled"ima
Click start type cmd press enter you will be in DOS mode
type in ipconfig press enter
you will see all of your internet connection details type in your default gateway adress into your internet search should read something like 10.0.0.138
or you could download one
http://download.cnet.com/2000-20_4.html
on the homepage you will see a search bar type in the ethernet controller freeware you want/need
Realtek RTL8168/8111 PCI-E Gigabit Ethernet NIC http://download.cnet.com/realtek-rtl8168-8111-pci/3000-2112_4-99235.html
http://download.cnet.com/network-drivers/3150-2112_4-0-1-4.html
i device arrows key scroll to nstalled.
Posted on Jul 16, 2013
  • 42 Answers
SOURCE: WPA on a hp ze4805us laptop
I've had a ZE4805US for almost 4 years, and use a linksys wrt54gs wireless router. I use WPA encryption it works just fine for me. Everytime i reload the system with xp from the hp discs WPA is not in the options. The only thing i had to do to get it was do windows update + sp2. Then it's right there in the wireless settings. Hope this helps you out.
Posted on Apr 28, 2008
SOURCE: My acer aspire one mini notebook doesnt connect to internet
This will happen if you let the battery go completely dead. Some files become corrupted.
Solution:- Right click on Settings (preferences some models). Select 'Network' then double click on 'gFTP'. Scroll down to '.gconf' and double click. select and double click on 'system'. Right click on 'Networking'. Scroll down to 'Delete'. Left click on 'Delete'. Confirm 'YES'. Turn off the computer, then restart. What you have done now forces the computer to re-create the networking file. Your networking icon should re-appear on the taskbar. Note this is only for LINUX systems. - Good Luck!
Posted on Feb 25, 2009
vkcelik
  • 77 Answers
SOURCE: Problem's with built in wireless card
A friend of mine had a similar problem for whole 6 months until i uninstalled Norton. So if you use Norton Antivirus use this tool to remove it:
ftp://ftp.symantec.com/public/english_us_canada/removal_tools/Norton_Removal_Tool.exe If link doesn't work use this link: http://majorgeeks.com/Norton_Removal_Tool_SymNRT_d4749.html
Posted on Mar 11, 2009
lorenzo_most
  • 60 Answers
SOURCE: Network did not assign a network address to the
Hi there, the only reason it doesn't work it's because the wireless key is not correct. It usually shows limited connectivity when the wireless key is not correct. Even just a letter upper or lower case will cause the problem. Since you are connected with the other computer go under the Router settings and double check the wireless key. Check what kind of encryption the router is using, make sure your wireless adapter can support it.
Posted on Apr 02, 2009
SOURCE: Cant access internet through wireless network.
if it flashes orange it is trying to connect and detect the internet, if you are connected to your wireless router but no internet check the security keys on the router and the laptop if they are the same, I guess you get the error limited connectivity, and if possible check for programs that could cause your wireless to not get the internet but get connected to the router, check for network magic uninstall the program from your system restart the computer try connecting again.
worst case that can happen is you can try uninstalling the wireless drivers and reinstalling it if the wireless devices gets an error during installation of the driver then you will need to replace your wireless card in your laptop, orange flashing in router meaning it does not detect internet from the modem ^_^
Posted on Jun 08, 2010
How to stop the Wireless Adapter For droping The internet connection Every 1 minute
What are specifications you are using for your wireless network? B, G or N, WEP or WPA-1 or 2 encryption, etc.
If everything was working fine at the beginning and no one has changed any of the network settings then that indicates an issue on the laptop.
You can try to reinstall the driver by downloading it from the Acer website as a Windows Update could have installed an 'updated' driver that doesn't work properly.
Jul 06, 2012 | Acer Computers & Internet
Hi , i reinstall window vista in my laptop, after that my wireless does not work. plz help me to splve that issue model no: acer extensa 5420-5038
Heloo utkarsh177,
There should be a CD or DVD driver for your HP laptop. Insert the CD or DVD. You should be prompted to install the drivers, be it the sound card or network card.
Once you have it installed, just go to an area with a wireless connection & you should be all set.
You can also click on the Start menu button or the Windows logo on the bottom left hand side, click on Control Panel.
You can choose Network & Internet or Network & Sharing Center.
On the upper left hand side, find Manage Network Connections. There should be a wireless icon, right click on it & choose status or you can view available wireless network.
Hope that helps.
Yours truly,
Art Pena
Nov 20, 2009 | Acer Extensa 5420-5687 Notebook
I just reinstalled windows xp and when everything was done. I couldn't find my wireless connection link.
Download the drivers from the Acer WEB site Make sure you select the model of your laptop and the XP version of the drivers you that require matches the Windows version that is installed on your laptop. Use this link to get to the Acer support: -
http://www.acersupport.com/notebook/index.html
Nov 08, 2009 | Acer Aspire 5100 Notebook
My internet is not connecting & the acer enet
Acer enet management can cause conflicts with the normal windows connection service.
try disabling acer enet management and then attempting to connect to the internet.
Right click on the enet management icon on your toolbar and then click disable, and then try to connect to the internet using windows.
Oct 29, 2009 | Acer Computers & Internet
Connects to network, strong signal, will not connect to internet.
it looks like wireless card in the laptops need to be changed.
Jun 03, 2009 | Acer Aspire 5610-4648 Notebook
Connect to the internet after Vista clean reinstall
http://gd.panam.acer.com/home/
Put in Notebook-->aspire-->aspire 3680-->confirm
Do this on your desktop and download the networking adaptor to a flash drive and then put it on your vista notebook. Once that is installed then you install the rest from your network on the laptop.
May 21, 2009 | Acer Aspire 3680 Laptop
I am trying to get my laptop to connect to the internet, I've got my router all setup just fine. The laptop shows my network on the available networks. But once I click to connect it says it cannot do so....
this happened to me once. you may try making sure that the internet you are using is connected correctly, if you have a desktop connected to the same router, than make sure the internet is working, and that ou internet provider isnt screwing up. thats how i fixed it. good luck...
Mar 08, 2009 | Computers & Internet
Acer with Windows Vista does not connect to Internet
You're laptop needs to have a profile for the router. Go to Network and Sharing Center, Manage Wireless Networks. Please remove all the listed networks there. Now click on Add, then Add a Network in Range of this Computer. Select the wireless name of your router and connect. If it asks for a network key, please type your wireless security key then connect. That should do it.
Dec 19, 2008 | Acer D-Link 2.4GHz Wireless Router 802.11b...
Stopped connecting to internet through land line
hi there, i had kind a same problem with u, the only difference is mine shows "connected" but i can't surf the internet when others in my network are doing just fine. 1st i tried to uninstall my LAN card driver and the reinstall it back. It worked, i can surf the internet but only for a few minutes. So i installed a firewall, in my case, i installed windows defender. After reinstalling my LAN card driver, i realized an unknown program tried to change some of my LAN driver files, so i denied the program access using windows defender. The problem solved !! Maybe it's a virus or spyware, i don't know because before installing windows defender, my avg and antispyware don't detect any virus/spyware. Hope this help, gud luck
Sep 26, 2008 | Acer Aspire 9300 Notebook
Setting up wireless internet connection , my new acer laptop
hi there i have a problem connecting my new acer laptop to the internet..I've tried your suggestion but i can't still connect to the internet..can u help me to connect my new laptop to the internet? is there a program or a disk for me to open the internet connection of my laptop...thanks a lot and i hope u will help me
Jul 11, 2008 | Acer Aspire 5610-4648 Notebook
Computers & Internet Logo
23 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
