Question about John Deere Garden
L100 5 SPEED WON.T GO INTO ANY GEAR pulley on transmission just spin.s when clutch is let out.
SOURCE: Maytag Washer PAV2300AWW
Your Thrust bearing on the bottom of the transmission is not releaseing the break. try turning the pulley with the belt off in the opposite direction this should free up your break. If it doesn't replace your brake ststor and rotor as well as your thrust bearing. This should solve your problem. Roger
Posted on Sep 27, 2007
SOURCE: jammed agitator
Some further checking indicated a bad transmission. As the unit is 15 years old, I decided the best solution was a new machine! ..
Posted on Dec 04, 2008
jeffbvegas1
  • 520 Answers
SOURCE: 95 saturn sl 2 5 speed manual transmission, clutch
This vehicle has a pair of shift cables which attatches to the shifter and runs to the transmission shift housing.To diagnose,removal of the center console is in order so you can inspect and verify the shifter/cable connections and movement,then verify the cables move the linkages properly at the transmission . These cables are a fairly common failed part and sold as the set,these are a dealer item and no aftermarket cables are available .
Posted on Sep 10, 2009
Testimonial: "That was nthe problem thanxs!"
  • 432 Answers
SOURCE: Major trouble getting the 5
Good Evening, mostly your transmission is good. I would be questioning the the condition of your clutch disc, but first I would have to say clutch master and or slave cylinder. I have had a few run across the lot where the clutch master cylinder has leaked internally just up above your clutch pedal where the rod goes through the firewall. let me know what you find, and when was any clutch work done.
Posted on Oct 02, 2010
  • 594 Answers
SOURCE: Why won't the clutch engage
not swich on
burnt fuse
faulty relay
faulty relay swith
faulty clutch coil
empty or low freon
Posted on Jun 09, 2011
Spin and then stop and alarm
(1) If the washer won't spin, the clutch assembly might be worn out. The clutch assembly makes the connection between the transmission and the inner tub. It is designed to allow the tub to get up to the proper spin speed gradually. As the clutch wears out it may prevent the tub from spinning. The clutch is not repairable, if it is loud or not working properly it will need to be replaced
(2) If the drive belt is faulty or if it isn't tight on the pulleys the washer won't spin properly and could cause the machine to stop.
Mar 16, 2015 | LG WFT1071TP Top Load Washer
The machine doesn't spin properly and doesn't drain the water
see this causes and fix it. God bless you
Lid Switch Assembly If the washer won't spin the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Motor Coupling If the washer won't spin the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and transmission. Another common problem is the lid switch.
Drive Belt If the washer won't spin, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin properly.
Door Lock Motor and Switch Assembly If the washer spin the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
Drive Block If the washer won't spin the drive block might be worn out or may have come loose. Underneath the agitator the drive block connects the inner tub (the one that spins around) to the transmission. If the drive block wears out the transmission shaft will still spin but the tub may not - or it may spin slowly. This also usually causes a lot of noise. The drive block is relatively easy to replace.
Clutch Assembly If the washer won't spin, the clutch assembly might be worn out. The clutch assembly makes the connection between the transmission and the inner tub. It is designed to allow the tub to get up to the proper spin speed gradually. As the clutch wears out it may prevent the tub from spinning. The clutch is not repairable, if it is loud or not working properly it will need to be replaced.
Clutch Band kit If the washer won't spin, the clutch band kit might be worn out. The clutch makes the connection between the transmission and the inner tub. It is designed to allow the tub to get up to the proper spin speed gradually. As the clutch wears out it may prevent the tub from spinning. If the washer won't spin, this clutch band kit may need to be replaced.
Drive Motor If the washer won't spin the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged It will have to be replaced.
Tub Bearing If the washer won't spin the tub bearing might have seized. This is a common problem and relatively easy to replace.
Tub Seal and Bearing Kit If the washer won't spin the tub seal and bearing might have seized. This is a common problem and relatively easy to replace.
Bearing If the washer won't spin the bearing might have seized. This is not common. The bearing doesn't require any normal maintenance. They generally go bad when the tub seal fails and allows water to leak past into the bearing.
Basket Drive If the washer won't spin the basket drive clutch might be worn out. The basket drive sits on top of the transmission and engages with the inner tub. If the basket drive wears out the tub won't spin.
Basket Drive Hub Kit If the washer won't spin the basket drive hub might be worn out. The hub is a set of plastic gears underneath the agitator. The basket drive hub kit is easy to replace with standard hand tools.
Transmission If the washer won't spin the transmission might be worn out or defective. There are numerous more likely causes when a washer won't spin, which should be checked first.
Sep 28, 2012 | Hotpoint Washing Machines
2000 mazda 626 5 speed manual transmission is stuck in a gear and won't shift out
A clutch problem will not interfere with gear selection when the engine is off and the car stationary.
It does seem like you have a gearbox or gear linkage trouble.
Sep 16, 2017 | 2000 Mazda 626
The tranny on my 883xl will shift through the gears but it won't engage. It will go into neutral. I don't have to engage the clutch to get it to shift through but even with the clutch it wont...
Sounds like your final drive belt is broke. Put the transmission in low gear with the engine off and try pushing the bike. If you can push the bike with the transmission in gear and the belt is not broke, it could be the front belt pulley is stripped in splined area where it goes on the countershaft. to check that take the rear master cylinder loose and remove the front pulley cover. Put the transmission in low gear with the engine off and push the bike. If the front pulley turns and the countershaft does not, the pulley is stripped.
Good Luck
Steve
Jun 18, 2011 | 2004 Harley Davidson XL 883 Sportster
I have a GE top load WLE6650081WW. It pumps but the slow spin is has a knocking sound and then stops spinning. When I set the spin controll to fast it is working fine but it will brake also. Do I need a...
Your transmission is still good that is why it still agitating and spinning. The culprit is the pulley. The transmission pulley is a part of spinning mechanism including the clutch, and the brake. The clutch and the brake are hardly needing replacement, but the pulley. Good luck.
Apr 18, 2010 | General Electric WHDRE526EWW Top Load...
Shaft coming out of transmission that clutch basket slide upon..it this suppose to free wheel while transmission is in gear...please help this is on a big dog k-9 motorcycle..6 speed baker transmission
Without clutch plates installed. The clutch basket inner is directly connected to the tranny input shaft- if you turn the inner clutch basket while in gear it should drive the rear wheel. The outer basket should spin freely regardless of gear selection and have no affect on the tranny.
The input shaft of the tranny itself ( the shaft the clutch basket slides on) should not free wheel when in gear.
Dec 06, 2009 | 2001 Titan Gecko RM
I have a ranch king it sat for 2 years inside, now the transmission will only engage in high gear. Transmission worked well when parked. Mower never abused well maintained.
Start up the tractor, leave the F&R shifter in neutral, put the speed selector in the higest gear and let out on the clutch.
Now with the clutch released, slowly pull the speed selector back to a lower gear until you reach the lowest speed.
Now put it in the park position and turn off the engine.
Restart your engine and try to drive as normal, this should have cured the problem but if it didn't you are going to have to remove the variable speed pulley and clean & lubricate it
Sep 28, 2009 | Garden
Replaced motor,now won`t spin
Something is locked in the transmission--can you turn the inner tub manually? Also, try to turn the driven pulley (the motor and belt driven). The problem could be anything from a seized bearing to a broken gear. Don't keep trying the motor while things are locked up, you could burn it out.
Aug 18, 2009 | Washing Machines
Garden Logo
41 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
