Question about Garden
I have to 500 series 22" briggs lawnmower. It will
    New Friend:
  • 11 Answers
Ethanol fuel the carb has to be rebult.
Posted on Jul 16, 2013
freetek
  • 5568 Answers
SOURCE: Gasket for briggs and stratton
I recommend  Jack's Small Engine Repair; they have always had the detail part I needed and their prices are among the lowest.
They will probably have an illustrated parts page for your model.
Jack's
Posted on Mar 22, 2009
AUTODOC01
  • 216 Answers
SOURCE: Won't stay running
these carb /air filter housing gaskets were notorious for warping? there are 2 screws behind the air cleaner remove those and disconnect the throttle cable pull the black square housing off and replace the gasket with a rubber one from local mower shop?
Posted on Aug 28, 2009
  • 41 Answers
SOURCE: my briggs and stratton 550 series lawnmower will not run
Could be float in carb.sticking.Take carb off & apart.Put float in water to see if it floats.Check float by shaking next to ear.If you hear any sound,you need a new float.
Posted on Aug 29, 2009
  • 168 Answers
SOURCE: Fuel starvation on 4.5hp Briggs and Stratton
When you replaced the carburetor on the briggs lawnmower did you also check the tank? Most times if you replace the carburetor and don't clean the tank and if you have any dirt remaining in the tank, then you only washed your feet but kept your socks on while you did it. You should have cleaned that tank extremely well because the tank body is also 1/2 the carburetor. You may have to disassemble the whole thing for a cleaning now. Good luck.
Good luck.
Posted on Oct 09, 2009
mikehowy
  • 177 Answers
SOURCE: after start mower wont run unless I press the primer bulb
carby service maybe required
Posted on Jun 07, 2010
How to replace lawnmower primer bulb on honda GCV160 engine?
Leo, Did not find your exact model, procedures are usually basically the same. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Primer Bulb Replacement Briggs Stratton Engines
HOW TO Replace Lawnmower Primer Bulb
How to Replace Primer Bulb
May 23, 2016 | Honda Garden
SmengesI have a briggs statton 6.75 series Craftman lawn mower 21" cut ,that I cant start. Recently serviced with spark plug, oil and air filter replacement. Brought it home and it the same problem....
I can only go by what you say was done. If you took mower to repairman then it should run. If you took to a buddy who thought he knew, WELL.
Try this first. The primer button is a round button usually BLACK, CLEAR, or RED. Look around your mower and you will find it at the end of the carburator. Carburator is opposite the muffler on your mower. With new gas in your mower ,press the primer button three or four times. Try to start. With all you have done it should start. If it doesn't start, think back and try to remember if you hit something while mowing, if you did then your problem is your timing. With the hit you sheared your timing key. This key keeps your fuel ,compression, and spark happily together to keep your engine running.
Check the other things first and please get back to me, I will be more than happy to help you further. GOOD LUCK.
Sep 01, 2011 | Craftsman 675 Series 190cc 22" Briggs ...
No spark looking for a diagram of the lawnmower
you can always tear the fly wheel off the gap is .20 top dead center before firing on most briggs motors
Aug 16, 2011 | Craftsman 675 Series 190cc 22" Briggs ...
11A600 Briggs Series engine, Only runs without Air cleaner installed, with it on, have to keep feeding it fuel, with primer bulb, no fuel being normally tranfered to engine via normal carb induction....
There is other passages in carburator that maybe causing the problem. If you would like i can look at it and see what it would take to fix it. Ethenal got in carb and caused a clog it jets or in bowl nut but without looking at it. I cant really help to much on it.
Mar 10, 2011 | Briggs & Stratton Briggs Stratton...
Pull cord wont pull,briggs 500 series
Pull the spark plug out and see if it isnt hydro locked. Someone might have overfilled the oil or the carb float may have stuck open and filled the intake with gas!
If the recoil is still stuck you can remove it from the mower and try it without any load on it. Still stuck? The unit might be rusted solid!
You can spray a little penetrating oil into it but be careful.....the oil will soak the pull cord which should be cleaned and degreased immediately following using the penetrating oil.
Jun 22, 2010 | Briggs & Stratton Briggs Stratton...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
