Question about Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model
No start battery full charged, not rolling over or anything!! sos
Check all battery connections... Follow the Positive cable (usually red) to the starter solenoid. Check connections. There should be at lease 3 wires attached to the solenoid, Battery cable IN, Battery cable OUT and a Smaller wire from the ignition switch. Test to see if you have power at the small wire when the ignition with(key) is turned to the START position. If there is no power, check the Seat kill switch and the clutch pedal switch. On most tractors, the clutch pedal has to be depressed to start the engine. If there IS power at the starter solenoid, check the Battery OUT cable. If there is power at this cable, check your starter. If there is no power at the Battery OUT cable, and there is power at the ignition wire, replace the starter solenoid. Hope this helps...
Posted on Jul 16, 2013
Club car won't start turns over slow battery is full charged?
battery could be fully charged but it depends on the amps from the battery. try jump starting using another vehicle or a jump starter, if you try these and it runs faster and starts change the battery also make sure the battery is the compatible battery for your vehicle some time the wrong battery is fitted to the vehicle, check these out before checking anything else
Jun 29, 2017 | Cars & Trucks
Motor run fine just died yesterday so I took seat off and the battery had blew off to caps were the acid is I replaced the battery rode it for about 15 miles then cut it off got a Gatorade and went to...
It's time to do a full check on your charging system; that's probably why it blew the caps off in the first place.
Odds are that new battery you put in is completely flat (lost charge).
Oct 11, 2013 | Honda Motorcycles
Turns over but wont start
try changing the spark plugs and see if that helps.
Dec 14, 2009 | 1999 Chevrolet S-10 Pickup
No elec power wont start battery full charge
check the 100 amp main fuse right near the battery
Dec 08, 2009 | 1993 Toyota Pickup
Rolled our 2007 800 SXR - ended up upside down. Rolled it clockwise back to upright. Re-started it without looking into engine compartment. It ran 5-6 seconds then stopped. Now the starter can't turn the...
i would remove all of the water and then manually turn the engine over alot without starting it SOON to get the water out of the pistons- if it was hydro locked this might prove quite challenging.
Aug 06, 2009 | 2000 kawasaki VN 2000 Classic LT
SOS is keeping me from calling or recieving anything
The SOS means your phone is locked and you can only use it with the original provider network
it is possible that if you battery got super low or you updated your software you relocked your phone.
Contact an unlocking service if you want to use another provider.
Jun 17, 2009 | RIM BlackBerry Pearl 8100
Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model Logo
56 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
