Question about CDI Electronics 116-7323 - Switch Box, 817323A3
98 tigershark ts 1000
My 98 tigershark 1000 will do nothing no power whatso ever to anything any ideas
After installation of New RAM & New Battery, I still saw nothing! T.S. Fan & memory mkn noise. Cleared the CMOS... No exturnal montor! Disasymboled ckn Backlight, & Testn Inverter needs done still.
test it only with battery unplug power cord
then test with only with power cord
you might try it with no ram anything to see if you get the screen to work
power it on then use flashlight very close to see if theres anything on it. in case the screen backlight is bad
Jul 06, 2015 | Computers & Internet
1998 tigershark ts1000
First, check the cables connecting to your battery. Make sure they're not loose. If they are tight, replace the battery.
Jul 15, 2013 | Motorcycles
Have power to the floating cord but tigershark will not run.
My tigershark would start working then stop 20 seconds to 20 minutes later. I found that the power switch was loosing good connection after self check cycle, I turned it on and off rapidly to hopefully clean the contact! I now disconnect and restart by pulling the power cord. I have run two cycles with no problem> I will replace the switch when I get a chance.
Good Luck
Apr 25, 2009 | Aqua Vac Tiger Shark
MY KENMORE 1000 WATT LITERALLY WORKED FINE ONE MINUTE THEN NOTHING THE NEXT. I HAVE NO IDEA WHAT HAPPENED.
Most likely the circuit breaker tripped or the fuse blew. A 1000 watt microwave is using 2/3 of the power available on a typical household circuit of 1500 watts. If anything else is plugged into that circuit u can have a problem. Just reset the breaker or replace the fuse and u will be up and running. if it happens alot you should consider a dedicated circuit for your microwave only.
Apr 21, 2009 | Kenmore 62622 Microwave Oven
Laptop will not boot up on its own power.
check in your power options make sure settings are correct for shutdown and stanby ETC
see if battery is showing fully charged or not in your power options
If everything is okay for power options then you need a new battery
please let me know and don't forget to rate
thanx
Feb 16, 2009 | Dell Inspiron 1000 Notebook
Startup problems/compaq presario 8000 series
Here is what I mean. You don't have to get one here, but here are what they look like.
http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=2779&name=3.5-Enclosure-IDE&Nav=|c:2778|&Sort=0&Recs=10
Jan 15, 2009 | Lenovo IdeaPad Y510 - Intel Core 2 Duo...
I have an unused new Memorex Keyboard which is several years old The boz is marked TS 1000 Windows 95/98 My computer has Windows XP Will this keyboard work in my cmputer?
as long as it has a PS/2 plug or adapter you should be fine.
* a PS/2 plug is the small round keyboard and mouse connector
Dec 04, 2008 | Computers & Internet
CDI Electronics 116-7323 - Switch Box, 817323A3 Logo
78 people viewed this question
Top CDI Electronics Electrical Supplies Experts
Steve
Gene Haynes
Are you a CDI Electronics Electrical Supply Expert? Answer questions, earn points and help others
