Very often problem with this model. In 60% it can be resolved only with reconnecting the Touchscreen flex / ribbon cable (If the Touchscreen is not broken of coerce (: ) .
If this solution not helped you then you must to change your Touchscreen.
To start, gently separate one corner of the case using the black spudger.
Step 2
Once you have successfully pried the spudger in between the front case and back case, continue do so around the entire tablet until the back case is completely disconnected.
Step 3 - Battery
Remove the 5mm screws that are securing the battery to the rest of the tablet.
Use the Phillips #00 Screwdriver to remove the 5mm screws.
Whether it's a *.pdf file or not, as soon as 1 programme can display the content of the manual, the same programme should be able to print it. e.g. print from adobe accrobat reader directly. Otherwise install the "open office" suite (costs 0) to open the manual file. that software should be able to print the content. (make sure the printer is correctly installed on your system.)
You will have to factory reset the unit: 1. Switch off 2. press vol+, hold, then press power 3. If display goes on: Release power but hold vol-up 4. Toggle Lockswitch (On->Off->On->Off)
