Question about Jabsco Pump - Water Puppy 7.8 Gpm
I replaced impeller but cant get any water pressure dont seem to have any air leeks
  • 3,368 Answers
The leak could be in the pump itself. How is the rest of the pump, is it worn. If everything is OK then you have a leak in the suction side.
Posted on Jun 18, 2014
Water pump leeks from holes.does that mean the fan in it isn't turning
The front seal is leaking on the pump. The internal impeller will still be turning.You need to replace the water pump before you loose enough coolant causing the engine to overheat
Apr 08, 2015 | Cars & Trucks
Vehicle is losing water. Already changed water pump. Unsuccessful at resolving issue.
are the carpets in side dry might be leeking from heating unit cylinder head jackets leeking you would see the water running down the sides of the engine split hoses leek in radiator or expansion tank hoses how much does it lose has the mechanic done a pressure test there could be a crack in the block or cylinder head a pressure test would find all these leeks
Mar 26, 2015 | 2003 Buick Regal - Supercharged 3.8L V6 -...
I have 2002 vw jetta wagon and it keeps over heating. We have changed the thermostat fuses relays and the heater core connector. We think the water pump is working fine because it has pressure and...
Pressure is not a good indicator of water pump operation. Pressure in the cooling system comes from the heating of the water and its expansion. Jettas come from the factory with plastic impellers on their water pumps. These have a tendency to break and fail, causing overheating issues. Most aftermarket pumps have metal impellers to prevent this from happening. I would seriously consider having the water pump replaced, especially if it is original and you have more than say 60K miles on the car. It's due for a change anyway and may save you your engine. See what this guy had to say about his Jetta.....
Engine Overheating Due to Damaged Water Pump Impeller Volkswagen Jetta...
Mar 12, 2015 | 2002 Volkswagen Jetta
My radiator hose popped off today iput it on and my car still over heats
You may have an air pocket with no fluid. This would cause over heating. If you have a recovery tank, it is better to add fluid thru there and not directly in radiator neck.
Sep 22, 2014 | 2001 Lincoln LS
Our centurion pool pump motor Model B128 replaced less than 1 year ago. Pool company has to replace the impeller twice. Is this common? I believe the pool co sold and installed a used pump instead
Broken impellers generally are not caused by the pump's motor. Impellers usually fail due to back pressure from the filter when the pump shuts off. Air in the filter is compressed while the motor runs, on your pump 12-15 psi. or a bit higher.
When the motor shuts off that compressed air forces water back to the pump, sometimes with enough force to loosen (or completely throw off) the impeller. If the impeller is loose when the pump starts up again it will instantly re-thread the impeller and strip out the threads.
Check to see if you have a suction leak. After the pump has turned on, bleed the air out from the air relief valve on top of the filter. After the pump has run for a while open the air relief valve and see if air comes out. There should be no air, or just a little.
I have seen this back pressure strong enough to blow the skimmer basket up onto the deck.
What make and model of pump and filter do you have?
Feb 22, 2013 | Pool & Spa
Does not fill with water e1 code
1E means - Water inlet problem >Condition : Not reached to the normal water level in spite of 10 minute water supply
Water supply problem. The inlet hose is kinked. The water pressure is to low (10psi) Inlet valve. The inlet water valve filter is clogged. The hall sensor. The impeller of Air guide is bound. Remedy : Check resistance of inlet valve ( 950-1300ohms) Clean valve. Check pressure. Replace the Air braker.
Mar 29, 2010 | LG 24 in. LDS 5811 Built-in Dishwasher
I have a Shasta pool from 1996. I replaced the
either you have an air leak somewhere on the suction side or your impeller is very clogged. you can fill the pump with water and turn it on, it should try to pick up prime, right when it starts to pull in some water turn it off and try to listen for air leaks or water squirting out somewhere on the suction side. Also, remove the pump basket and try to feel the impeller to see it there is any debris in it. the main cause for a clogged impeller is a cracked or broken pump basket. Also, if the pump has run dry for any period of time, the threaded fitting on the suction side of the pump can shrink and cause a large enough air leak to keep the pump from priming.
Nov 14, 2009 | Pentair 3hp Whisperflo Pool Pump In -...
LG LDF8812ST WONT DRAIN JUST INTERMITTENT BUZZ NOISE
Hi, there may be an obstruction in the pump housing that is causing the motor to freeze or, the impeller may be stripped and , jamming the pump. this will cause the hum you are hearing. the best way to inspect is to , extract the drain pump by, removing
the bottom drain filter housing or sump. manually
move the pump impeller to self it is moving freely. if the impeller is stripped, it will not be able to produce the draining surge necessary to pull the water out.
If the impeller is fine and, there are no obstructions visible, this will confirm pump failure.. replace the pump in this case
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
Jun 19, 2009 | LG LDF8812 Stainless Steel Built-in...
My pump pressure is 10psi i cleaned the de filters they seem fine i have good floe out of my jets but when i hook the pool cleaner up pressure drops to almost nothing. could my impeller be the problem
The pressure you are reading is the pressure in the filter tank as water is pumped though it. When the filter is freshly charged, 9 PSI is a good pressure.
As the filter removes particles from the water the filter gets "dirty" -- it takes more pressure to push the water through it thus raising the PSI.
I think you are viewing this in reverse. Low filter pressure is "good" (as long as it stays above 8 PSI) -- as the filter cleans the water the PSI will increase -- when it gets to 15-20 PSI it needs to be back-washed and recharged.
The pressure drops when the pool cleaner is connected because pool cleaners always pull in air (in varying amounts) because of all the hose connections. This causes your filter/tank pressure to drop.
May 25, 2009 | Hayward 3/4hp Super Pump Inground Pool...
I have a 1993 volkswagon golf and i cant seem to find where to the tap is on the raditor
I think the problem could be your thermostat not opening when hot. Turn the heater on full inside the car and check if you are getting hot air from the vents as the engine reach's its normal running tempreture. It should blow hot, if it blows cold then change your thermostat. Also check all the hoses for leeks.
Sep 07, 2008 | 1993 Volkswagen Golf
Jabsco Pump - Water Puppy 7.8 Gpm Logo
65 people viewed this question
Top Jabsco Plumbing Experts
Gil Shultz
ray gallant
Are you a Jabsco Plumbing Expert? Answer questions, earn points and help others
