Imation apollo pro UX-1000 US drivers - Computers & Internet
bob_computer
  • 3153 Answers
SOURCE: Imation apollo pro ux 500gb external hard drive
One or more of the hints below will probably sort out most USB problems with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
6. For FLASH DRIVES you should ensure that the device is set for "quick removal" using the drive control panel properties or use the USB "Safely Remove Hardware" option. If you dont do this there is a very strong chance that any files you transfer may not be there when you plug into another computer.
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
You should also do this to cheack the drives connections are not bad inside the enclosure
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
Posted on Oct 05, 2009
SOURCE: I have an Imation Apollo
not comunicate with my laptop
Posted on Jan 16, 2011
  • 41 Answers
SOURCE: Describe your Imation Apollo UX
Please repost your problem, and enter a description of your problem in the textbox where it says "Describe your Imation Apollo UX 2.5" USB Portable (250 GB) Hard Drive Problem"
Posted on Aug 25, 2011
jryc32
  • 408 Answers
SOURCE: I need to install the
What operating system are you using? There is usually no need for drivers on external HDD. The computer usually recognizes it and installs the necessary software for it.. Let me know if this answers your question and good luck..
Posted on Sep 09, 2011
howard_compu
  • 211 Answers
SOURCE: windows 7 gives a error
Try in another machine. Does not work?
Remove the drive from the case (only if there is no more warantee) and connect the drive directly to your system to determine if the problem is the drive or the enclousure.
Posted on Sep 12, 2011
Imation Apollo M100
https://www.imation.com/en/consumer/external-hard-drives/ External Hard Drives
Jan 29, 2014 | Imation Apollo UX 2.5" USB Portable (250...
Driver windows 98
Hello
If you are trying to update the windows drivers in your computer then I suggest that you use RadarSync because Windows 98 drivers are hard to find nowadays. The software will look for the driver updates in the databases of the manufacturers so you won't have to find them one by one (time consuming).
David
Jun 06, 2013 | Imation Products - imation - Apollo Pro UX...
Apollo USB M250 HDD1TB once pluged in makes pc not responding have tried different pc and cables
Umm well i got a 1 tb Apollo M250 external hard drive an it has a green light.......is dis a problem
Jan 23, 2012 | Imation Products - imation - Apollo Pro UX...
Windows 7 gives a error 43 and does not recognize Imation Apollo Pro UX 1 TB USB Hard Drive
Sep 12, 2011 | Imation Products - imation - Apollo Pro UX...
I need to install the driver information to a new computer for the Imation Apollo Pro UX external hard drive
Sep 09, 2011 | Imation Apollo UX 2.5" USB Portable (250...
Aug 25, 2011 | Imation Apollo UX 2.5" USB Portable (250...
I just got an Imation Apollo UX 320 Gb without need of power supply from my brother in law, as a gift. The problem is that he gave it to me without the cable so I connected it to my computer with a cable I...
try a shorter usb cable long ones typically dont flow enough power unplug all other usb cables and make sure your computer is up to date with all Microsoft fixes [if your using windows] it should either auto-play and pop up or be viewable from [my computer] i hope this works please vote
Nov 29, 2010 | Imation 27390 Apollo Expert UX 2.5" 320GB...
I need an Owners manual for an Imation Apollo UX 2.5" HDD 250 gb
Hello Anaheimflash!
Imation has a User Manual and a Quick Install Guide for the Apollo UX available for download on their website. The link to the download page is Apollo UX
Nov 22, 2010 | Computers & Internet
Computers & Internet Logo
144 people viewed this question
David Payne
David Payne
