Question about Refrigerators
Norcold refrigerator N842 model refrigerator. After running for about 40 minutes, when vehicle was turned off, and back on, the control panel began beeping with NO CO in the window. After attempting to turn off and then on again it still says NO CO. I understand it may need to be hard reset, in the wiring box outside. I do not have the wiring diagram to know which wires to unplug, and then replug, and which to use the jump wire to short across. How do I know which wires to use for this model Refrig.???
  • 116 Answers
SOURCE: control panel for freezer and refrigerator
Behind the back panel of the freezer section is the evaperator assembly. on the rh side of the evaperator is a sensor pack that is for the defrost cycle. there is a thermo fuse inside of this pack that is open. The fridge goes into an error state if this fuse is open. unplugging the fridge resets the system. the sensor pack will have to be replaced.
Posted on Apr 27, 2007
Just_Bobz
  • 448 Answers
SOURCE: Wiring hard start capacitor in GE refrig
I would go back to person who gave that advice because just the right touch on that capacitor and YOU my friend will be in the hospital. If this is helpful, please post as such. TY
Posted on Jan 17, 2009
roadrunning1
  • 152 Answers
SOURCE: wiring diagram for thermo king street boss
need the model number for this one
Posted on May 10, 2009
  • 193 Answers
SOURCE: Need wiring diagram or schematic for GE refrigerator
if you look on the back there should be one stuck to the inside of the case near the compressor. if not go here: http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=TFX20JRSM
Posted on Aug 14, 2009
SOURCE: finding wiring diagram whirlpool refrigerators
take off bottom cover should be on back if not look around compressor they usually leave them stuck around there
Posted on Apr 12, 2010
I have a Norcold 2 door fridge. It works fine on propane or electric but I hear a VERY loud bang and see flames shoot out. It is a propane leak some place but checked fittings and lines -no leaks.
is this new? never been used before or old. ? please read this
Norcold, Inc. Product Recalls - Call 1-800-767-9101 Monday - Friday 8:00 am to 8:00 pm EST
The Norcold, Inc. refrigerators listed below have been recalled.
It is important to implement this safety enhancement to prevent an unsafe elevation in the temperature of the cooling unit should the unit fail in operation. This enhancement seeks to minimize the risk of injury or ***** due to fire.
Norcold Inc. has decided to recall certain 1200, 1201, 1210 and 1211 model gas/electric refrigerators with serial numbers from 315525 to 13088811, non-consecutively. The refrigerator's model and serial number are located inside the fresh food compartment. These refrigerators may have cooling units with a cooling unit serial number between 700000 to 13085759. This is a new recall campaign to include all 1200, 1201, 1210 and 1211 models.
Even if your refrigerator was repaired as part of a previous recall, it is necessary to have it repaired again to minimize the risk of injury or ***** due to fire.
If you have one of these refrigerator models, use the following procedure:
  1. Identify and write down the refrigerator model. If it is a Norcold 1200, 1201, 1210 and 1211 model, go to step 2.
  2. Identify and write down the refrigerator serial number. If the serial number falls in the range of 315525 and 13088811, go to step 3.
  3. Identify and write down the cooling unit serial number. If the serial number falls in the range of 700000 and 13085759, go to step 4.
  4. Call your dealer immediately.
The installation of the High Temperature Sensor will be at no cost to you.
Owners of recalled refrigerators should NOT operate their refrigerator until it can be professionally repaired by your dealer or a Norcold authorized service center.
If you have one of the recalled refrigerators and you:
Currently reside in the RV, you should immediately:
  1. Set the refrigerator controls to "OFF".
  2. Unplug the refrigerator through the service vent on the outside of the vehicle.
  3. Contact your dealer, a Norcold authorized service center or Norcold's Recall Center at 1-800-767-9101 as soon as possible to get assistance.
Do not currently reside in the RV, you should immediately:
  3. Disconnect from shore power.
  4. Contact your dealer, a Norcold authorized service center or Norcold's Recall Center at 1-800-767-9101 as soon as possible to get assistance.
Failure to follow these instructions can result in a fire causing injury or *****. To locate an authorized service center,
http://webcache.googleusercontent.com/search?q=cache:tnsP3IdSqhgJ:www.thetford.com/customer-support/recall-information/+&cd=10&hl=en&ct=clnk&gl=uk
if you have this model STOP using it!!!
Jun 19, 2017 | Refrigerators
Thetford gas igniter burns but ignition is not seen by control unit
Without the make & model...
the only answer possible is a "TYPICAL" SWAG: Looks like NORCOLD is most likely your manufacturer (although I've also seen U-Line).
SPARES are good to have... (now you understand).
On-Line parts abound everywhere... It is likely an "electric"
(because of your control board statement).
I'll put up sample Pix from Amazon & eBay.
http://www.ebay.com/sch/i.html?_nkw=Norcold+Refrigerator+Thermocouple
Your THERMO-COUPLE (flame monitor)... same (type) thing that always fails on our water heaters... typically costs $6 if you are buying one in advance... up to $24 (twice that for the "Refrigerator versions" $12 to $48) in you hour of need... Unless you call a "service" (plumber) person... Then just start adding on those ZEROs.
These also can use an INTERRUPTER (same price range)...
Buy them both... As you can tell... they are good spares to keep around (I always buy a NEW thermo-couple & put it on a nail
with a "NEW water heater installation (keeps evil spirits away).
I'd recommend you post the complete make, model & year...
Defective GAS appliances can be quite deadly... even if the work is done properly... improperly the sky (is quite literally) the limit...!!
Could NOT more strongly URGE... Buy and USE a good carbon-monoxide monitor/alarm.
Truly a LIFE-SAVER.
All gas utility companies will (or used) to QUICKLY send out their representatives to inspect/light gas appliances..
Historically this was always a FREE SERVICE...
(but sadly that the extent of my knowledge... HISTORIC).
Be safe... Comment me back if you need:
(never test for leaks with a match... My grand-daddy taught me that (course hair & eyebrows grow back... MOST of the time).
Norcold Refrigerator Thermocouple
Apr 11, 2016 | Refrigerators
Norcold fridge in my motorhome
Norcold fridges are now part ofThetford one of the largest suppliers of mobile and marine products. You do not quote the model so not sure if a 3 way (gas/mains/12v) or AC/DC. The most common problem with all mobile fridges is the heater unit is faulty. Thetford have discontinued spares for a large range of norcold models. Information can be obtained on the Thetfold.com website.
Good Luck
Jul 09, 2014 | Refrigerators
We have a Norcold model N811FLT, it is connected to power, but is continuously running on gas. We've tried resetting it with no change. Could it be the power board or the control board?
you can reset the control board . to do this you must ground the # 15 terminal with a jumper wire to ground. this is usually the terminal next to the white & violet wire. check diagram.
Jul 07, 2014 | Thetford Norcold RV Cooler/Freezer
Won't cool and cycles every 5 to 8 seconds
Compressor cutting out. Do you hear a clicking sound at the back of the fridge every time ir cuts out? If so, it is the compressor.
Or it could be the temp control but less likely.
The next time it cuts out, fiddle with the temperature control If this brings the fridge back on, replace the temperature control.
Oct 25, 2013 | Norcold Inc Norcold DE0061R Refrigerator
I have a Norcold n611 fridge gets too cold and freezes even on lowest setting.
The temperature control thermostat, alson known as the colds control thermostat has gone bad and basically isn't converting electrical/temperature signal properly and needs to be replaced.
May 10, 2012 | Thetford Norcold RV Cooler/Freezer
How do you reset circuit board on norcold refrigerator
No way to do that other than to unplug refrigerator for at least ten minutes and then plug back in. Don't use surge protector, power strip, or extension cord.
Sep 21, 2009 | Thetford Norcold DE0051 Refrigerator
Norcold rv refrigerator freezer
Make sure the thermister is attached firmly to the fins in the back. The boards on a Norcold can be reset a service center familiar with this process is your best bet. It takes disconecting the board and then shorting it out best to leave it to some one who is familiar.
Aug 16, 2008 | Dometic NDR 1292 Refrigerator
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
