Question about Lands Phones
I have a uniden dect1580 6 0 and the red light in the charge base doess
I have a unident dect1580-2 the ligh in the charge basee does not come on and the one on the accessory does. Why is this?
  • 3 Answers
SOURCE: tru9466 base and tru9465-2 handset
Same manual as lethean provided on a similar post but Page 24 if the previously used Base is Unavailable and your phone shows "Deregistration" in the Menu.
Base Unavailable (Handset Only)
To clear the base registration data in the handset, please follow these steps:
Press and hold [] and [#] for more than 5 seconds. Select the BASE UNAVAILABLE submenu.
BASE UNAVAILABLE appears. Move the cursor to select YES, and then press the OK soft key.
ARE YOU SURE? appears. Move the cursor to select YES. Press the OK soft key.
Posted on Nov 01, 2008
  • 3 Answers
SOURCE: cant register/install a new dect 6.0 uniden 2060 phone
I had a similar problem which I finally fixed. You did not say if any of your phones registered.
First try the following recommended by Uniden Support:
Your phone(s) should be fully charged before putting them on the main base.
Unplug the battery from the phone by removing the battery cover and removing the connector. Then, push the # and * key together and hold while you plug the battery back in (requires some dexterity). Continue to hold the two keys until you hear a confirmation tone. This will force the phone to reregister. Put the phone on the main base (if you are sure it has a fully charged battery) and see if it will reregister it to solve the problem.
That did not work for me. So, I followed the instructions to de-register the handset (even though it hadn't really registered). But, I also pretended like the Base was not available (because using the base in this step also failed).
1) Press and hold the hang up and # keys for at least 5 seconds.
2) Move the cursor to select Base Unavailable and then press Select.
3) Select the base you want to deregister from, press Select and then move the cursor to Yes and select.
This causes the phone to delete any of its base information.
At this point, again insure that your phone shows the battery is fully charged and if it is not, put it on the stand alone charger base (not the main base). With the battery fully charged, place it on the base and try registering again by placing it in the main base.
If neither of these approaches help, contact support at Uniden.com.
However, my problems were cleared when I cleared the handset with the second set of instructions.
Posted on Apr 26, 2009
goalie39
  • 469 Answers
SOURCE: After charging a Uniden 2180-2 DECT 6.0, the base stope showing anything on its display. As for the other handset, their display report " searching" since they can' t connect to the base. What is goin
Reset Procedure for Cordless Phones
Question:
What is the general reset procedure for cordless phones?
Answer:
1. Disconnect Battery from handset(s)
2. Disconnect Phone Cord from wall jack
3. Disconnect Phone cord from base unit
4. Disconnect AC adapter from wall outlet
5. Allow to sit for 30 min
6. Reconnect Phone Cord to base
7. Reconnect Phone cord to wall jack
8. Reconnect AC Adapter to wall outlet
9. Reconnect Battery to hanset until you click or feel the plug snap into place
10. Re-Register Handset by placing on main base in most instances
Posted on May 05, 2009
  • 5 Answers
SOURCE: Uniden XS 1210 cordless phone won't connect to base unit
try connecting both phones via the base that is working and see if they recognize each other. Let me know if that works.
Posted on Jul 21, 2009
jyackle5
  • 8197 Answers
SOURCE: how do you adjust volume on base ringer on uniden dxa15588-2
Setting the Main Base Ringer Volume
The main base has three ringer volume settings: high, low, and off. You can change
the ringer volume while in standby mode or while an incoming call is ringing.
1) Press the ringer key.
You hear the ringer at the current volume level
([ ] High, [ ] Low, [ ] off) (if you set the
main base ringer volume to off, “Ringer off” is
announced) and it is displayed on the main base.
2) Press the ringer key repeatedly until the desired ringer
option appears.
3) The system displays the new ringer volume.
Posted on Dec 31, 2009
Hi i have a uniden ZO68 i want to add another hand set to this i have brought another uniden ZO68 second hand hand set and i can't set it up can you help me please
did you get the charging base with the hand set
is it a charging base or a base station base
if it is just a charging base , follow the instructions as how to get the base station to recognize the next phone
if it is a base station, probably won't work as you will have 2 base stations trying to work and that will create conflicts
talk with a telephone technician to see what can be done
Oct 30, 2016 | Uniden Lands Phones
I attempted to register several new TCX 905s to my TRU 8866 base without success. I followed instructions from the owner's manual, from Uniden customer support, and from suggestions from this web site. ...
October 10th, 2013 at 9:19 amPROBLEM:
After de-registering handset, handset displays [REGISTRATION FAILED; UNAVAILABLE] when trying to register handset.
This worked for my UNIDEN TRU-9480-2
SOLUTION:
1) Remove handset from base
2) Remove power cord from back of base
3) Press and hold the [find hs] button on base as you plug the power supply back in; the charge light should then be blinking.
4) Return handset to base and it should register
GOOD LUCK!! HOPE THIS HELPS!!
Oct 04, 2013 | Uniden Lands Phones
DECT 1480-4 Uniden Corless phone- how do you get rid of red LED lite ?
Do you mean the status light on the handset or the one on the base? The status light on the base will be on if the answering system is on. The handset status light will be on but steady when the handset is on the charger. (It's a battery charging indicator in that case; take the handset off the charger to stop the charging system. It provides a trickle charge to offset the battery discharging over time) The light blinks to indicate new messages are available on the answering system. Press the Play button on the base or the Messages/Mute button on the handset to play new messages.
Uniden offers the manuals for many of their phones on their support site: http://www.uniden.com/bin/venda?ex=co_disp-view&bsref=uniden&scat=dectphones_mnl . The direct link to the manual for the DECT-1480 is http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/DECT1480-2om.pdf .
I hope this helps.
Dec 02, 2011 | Lands Phones
How do i recharge my uniden phone battery
Phone's "Status Light" Not Illuminating or Battery Failing to Charge
  • 1.Check that the base unit's AC adapter is plugged into the both the base unit and electrical outlet firmly.
  • 2.Wipe the base unit's handset holder's connectors and the connectors on the bottom of the handset with a soft cloth/rag or pencil eraser to remove any loose dust and dirt from the metal connectors.
  • 3.Place the handset firmly in the base unit holder until the "Status Light" illuminates, indicating the battery is charging.
    4.Replace your Uniden cordless phone's battery, by purchasing a compatible battery from an electronic supply store or directly from Uniden. Turn your phone's handset unit over and remove its battery door. Lift the phone's battery pack up and gently unplug the battery's wire connector by pressing in on the connector's side and pulling the connector free from the phone's circuit board. Battery installation is the reverse of removal.
    Read more: Troubleshooting a Uniden Cordless Phone ' eHow.com http://www.ehow.com/how_7252483_troubleshooting-uniden-cordless-phone.html#ixzz1Wkmk0pxX
    Sep 02, 2011 | Uniden Cordless Phone
    My uniden phone says - out of range
    I just finished fighting my phone for this same problem.Try unplugging the base for a minute and plug back in. I had a dead battery, changed it, it still said out of range. Next I deregistered it by holding the "off" and # buttons until the menu popped up saying "deregister". I had to select "deregister without the base" to get it to work. After all this, I unplugged the base, and that is what solved my problem.
    May 25, 2010 | Uniden TRU9585 Cordless Phone
    My uniden axis phone when dead ysterday. There is no information on the display just the light is on
    My Uniden digital powerMax 5.8Ghz hand phone went dead and does not want to take a charge, although the base unit red charger light is on.
    Mar 09, 2010 | Uniden DECT 6.0 Cordless Phone ID
    Codes for unider bc 145xl police scanner
    For a comprehensive database of active frequencies in your area (they're not codes), and a lot of other useful scanning information, visit:
    www.RadioReference.com
    Bill B.
    Listening in since the 60's
    Nov 01, 2009 | Uniden BC244CLT Base Scanner
    Uniden squeel
    You have an antenna problem. Get a good antenna, such as a Wilson 1000 & use the SWR function in the radio to tune it. Wilson antenna come with tuning instructions.
    May 31, 2008 | Uniden PC78ELITE 40-Channels Base CB Radio
    Red light on main base
    Do you have voicemail through your phone co? That blinking can indicate a new voicemail is waiting for you. It could also indicate intermitent charging. Try cleaning the contacts on the base and phone with rubbing alchol and a q-tip. Hope this helps.
    Sep 14, 2007 | Uniden Cordless Phone
    Handset Buttons Stopped Working - Full Battery
    Here is a link to Uniden's site, and on the right side of the page, there is a link for a download manual pdf and helpline
    http://www.uniden.com/products/productdetail.cfm?product=TRU8885-2
    also worth checking if any buttons are stuck, or if the handset is set to pulse rather than tone mode, or if it has had a tumble or knock, possibly the keypad connector has come loose .
    Hope this helps.
    Sep 17, 2006 | Uniden TRU8885-2 Cordless Phone
    Lands Phones Logo
    16 people viewed this question
    Top Lands Phones Experts
    David Burbee
    David Burbee
    Are you a Lands Phone Expert? Answer questions, earn points and help others
