Can't figure how to useuse
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Office Equip... Master
  • 102,366 Answers
Can you figure out the make and model of the printer/copier?
Posted on Jul 16, 2013
My zpad won't hold a charge
Lithium ION batteries are useusally rechargeable. The use mode for these batteries is that there
are a set number of recharges that equate to the life of the battery. Usually that life is
approximately 1,000 charges.
If you use your battery to 50% then recharge, you can do this ~2,000 times. As the life of the
battery is used up, the maximum charge lessens which means where you may have had 8
hours of play time when the battery was new, you will only have 6 hours as the battery life is
used up.
In order for a Lithium ION battery to recharge there must be at least a small amount of charge
left as a "seed" for that recharge. If you drain a L-ION battery down to zero, it may never
recharge again or the max charge will be reduced to an insignificant amount of the original full
charge. eg instead of 8 hours you may only get 15 minutes, or 5 minutes, or no minutes.
You are much better off recharging when 50% depleted than using it up til your product stops.
L-ION batteries cannot be repaired only replaced. Most cheap products using L-ION batteries
cannot have their batteries replaced.
Jun 05, 2014 | Tablets & eReaders
I have 2000 pontiac grand pix and my tail light's are not working and can not figure it out the bulb's and fuses have been checked and they are all working and still can not figure out why
Take off the shroud around the steering colum & check for a broken wire from the light switch. You must have an incomplete circut somewhere (Broken wire or a short but if it was shorting your fuse would probably be blown) so I would 1st check for broken wire.
Jun 24, 2012 | 1997 Dodge Ram 1500 Club Cab
I have a cat 416 backhoe that keeps burning up starters. Can't figure out why. Any Thoughts?
eather a bad ground wire or the flywheel is bent witch will put to mucth of a load on starter
Jan 05, 2012 | Caterpillar Backhoe Tractor
I have a 07 predator 500 that is eating valve shims? I have had it @ the dealer 4 months ago and has done it again. The dealer said it would work or it would happen again in a week or month or a ye
Ensure that your exhaust system is standard - low back-pressure can burn valves out & leave deposits on valvesEnsure the correct plug is in useUse good quality fuel with a lead substitute or octane booster - valve seat pitting occurs without
Dec 31, 2011 | ATK 500 Motorcycles
2010 Elantra Touring - car won't start - doesn't turn over (battery is fully charged), clock/radio & A/C units don't work, and EPS doesn't work. Dealership cannot figure it out.
sounds like a fuse. check them and get back to me. If the shop you took it too cannot figure it out they probably should not be a shop. i hope they didnt get you for a diag fee. Im going to locate a wire diagram to help you figure this out.....Also you said you put a new battery in the car, check that the battery terminals are clean and tight.
Oct 06, 2011 | Cars & Trucks
Can't figure out how to turn on flash for my
You can download the manual from the manufacturer's web site at
http://www.vivitar.com/files_products/236/ViviCam_X024_Camera_Manual.pdf
Aug 07, 2011 | Cameras
How to download fast free anti virus
I have used AVG free edition for years and been happy with the protection.
It is available for download here.... http://free.avg.com/us-en/download-free-antivirus
Apr 20, 2011 | Computers & Internet
I took my Dyson DC 25 Animal apart to clean it, and now the red foot pedal won't lock the vacuum into the upright position anymore. The trouble is the spring pin for the pedal popped out and I can't figure...
That spring thing goes where the pedal screws into the side. When 'facing' the dyson in the front, it's on the left side. The spring's circle part and short stem section goes into a divot area on the pedal. The other end is tensioned (braced) against some housing piece, but once you insert the spring part in the pedal end part, you should be able to figure it out from there.
This darned spring makes the pedal 'tensioned' to where it pops back up vs. flopping nonsensically.
Feb 09, 2011 | Dyson DC25 All Floors Bagless Upright...
12 people viewed this question
jasbo
jasbo
