Question about Home
Jacuzzi bathtub won t turn off - Home
4 Suggested Answers
  • 123 Answers
SOURCE: Does new jacuzzi bathtub nead the heater
Jacuzzi heaters are an addon and are a convnience accessory. They are not required for functionality of the unit. I personnaly do not have a heater in either of mine.
Thx
Deathstalker
Posted on Sep 01, 2009
tunde007
  • 2382 Answers
SOURCE: Kohler jacuzzi, whirlpool bathtub will
Hi, first check the air switch hose that connects to the "button"
Open the access for the pump there should be 1/4" poly tubing (probably clear) that connects to the pump motor. It just slides over a barbed nipple usually located somewhere on the back of the pump housing opposite the pipe connections. Make sure it is in place properly. If it is in place then look else where. The tubing also connects to the back of the air switch "button". This button connection rarely fails, especially if the tub was working and now does not. But if the tub is newly installed and may have disconnected during installation. this connection is probably going to be difficult if not impossible to verify since it is usually concealed after installation.
Some pump motors have resets some do not. If it does it probably is on the very back of pump oppositethe pipe connections.
Also check to make sure that any electrical outlets in the bathroom, or any where in a nearby radius of the tub, to see if they have "GFI" reset buttons and make sure that they havn't tripped by pushing in the button between the plug-ins named "reset". Usually the circuit for the pump will be tied into one of these switches to add ground fault protection to the circuit.
If your pump is not working after checking these things it may be dead. Does your pump "hum" after pushing the button? Do you smell any type oder around the pump that would suggest a "burnt motor"?
If the pump is dead you will have to replace it.
Posted on Nov 07, 2010
uspartscente
  • 717 Answers
SOURCE: the panel on my jacuzzi bathtub keeps falling off. Previous owner said something about needing clips.
You will need to get those clips at your local Jacuzzi Whirlpool Dealer or use Velcro to hold each panel in place.
Rod
US Parts Center
888-521-6183
Posted on Mar 05, 2013
Heaters for a jacuzzi
Heaters for jacuzzi bathtubs. Click here for a list of what will work for any bathtub.
Bath Heaters
Rod
U S Parts Center
888-521-6183
Mar 17, 2013 | Jacuzzi RapidHeat In-Line Heater U395000 [...
The panel on my jacuzzi bathtub keeps falling off. Previous owner said something about needing clips.
Rod
US Parts Center
888-521-6183
Mar 04, 2013 | Jacuzzi Home
When I try to turn off my Jacuzzi tub it will not turn off. I pushed the gfi and it went off. I then reset it a few days later and the tub would not turn off and this time the gfi would not shut it off. ...
You will need to have a technician from the store you purchased it from install a new switch.
To be up to code, you should have a GFI for your Jacuzzi to plug into and a GFI circuit breaker dedicated only for your Jacuzzi. I
If you already have it, that's great, but if not check with an electrician for installation.
Regards
Apr 05, 2011 | Jacuzzi Mito, 5 Soaking Bathtub -...
Jacuzzi whirlpool bath not working when i turn it on i get a buzzing sound
buzzing sounds tend to be a motor problem. You may need to change the pump. When you turn it on it just buzzes? that indicates a bad motor.
Dec 20, 2010 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
Why does black slimy film come out of my jacuzzi everytime I use it even though I clean it? and now my drain is clogged
black slime come from not using regularly..fill jacuzzi and pour a cup of dishwasher detergent and turn jacuzzi on for a while..
Nov 21, 2010 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
We have a new Jacuzzi tub and went to turn it on
check to make sure the pumps on and that its wired correctly and that all valves are open.
Feb 22, 2010 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
I have a jacuzzi corner tub. The control panel
I would expect there is a Jacuzzi dealer in your town and I would guess he has parts. If you purchase parts locally, not only are you helping your neighbor but also, you will have the opportunity to pick his brain on tips to install.
Thanks for your interest in FixYa.com.
Feb 20, 2010 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
My american standard jacuzzi tub is pluged in but jets won't turn on
check for power at plug in if power your vacume switch is probably out replace switch.
Apr 28, 2009 | American Standard 2771.002.021 Cadet 5' x...
Home Logo
152 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
