Question about Clarion Car Audio & Video
Right speaker doesn t work - Clarion Car Audio & Video
It might have been disconnected from the board or the driver has not been installed.
Sep 14, 2013 | ASUS Computers & Internet
Car Audio
Swap wires between speakers and to make sure it is not the amp, the head unit or wiring. If the right speaker still doesn't work touch a 9v battery to the speaker terminals for a second to verify if the speaker is good or bad (a pop the speaker is working nothing the speaker is bad)replace. Otherwise check the wiring between the amp and the head unit. If all the wiring is good you may have a bad channel in your amp(bad internal connection or bad component(s)) or last there could be a bad channel output on your head unit. If that is your only right speaker and you don't have one in the door and you use an ipod as a source check the cord!
Jul 04, 2013 | Car Audio & Video
speaker problem, needs to be changed!
gt it changed at http://laptopsmumbai.com/
in 30% cheaper rates.
Jul 02, 2013 | Lenovo Computers & Internet
Rear right speaker doesn't work, no matter what we tried. We switched the speaker and cables with one of the others, but just that position (surround right) doesn't work.
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there also if you have the right ones selected
try swapping the speakers around if the problem still persists either the speaker is faulty
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
Sep 09, 2011 | Spherex Xbox 5.1 Surround Sound System...
I have a Technics SU-G70 Amplifier with a problem. Overall, it works fine except for a speaker issue. When turned on, the Left speaker output on the monitor is lit up from 0 to 120. Just below, the...
Sir the problem of your unit is the power IC the other channel of this IC is already faulty. unplug the unit to the main AC outlet then remove the cover of your unit you will see a large aluminum plate the power IC is attach to that heat sink in order to fix this you should replace the IC. Or can you give me the part number of the IC so I can determine the pin configuration. Good day and best regards.
Sep 15, 2011 | Technics Audio Players & Recorders
I just bought a microsoft wireless keyboard 3000 and inserted the USB into the hub. But now when I play a youtube video the sound comes from the laptop instead of the external speakers like it used to. ...
First, you can try unplugging and replugging the speakers. If that doesn't work, right-click on the speaker icon in the taskbar (lower right-hand corner) and select "Playback Devices". When the window opens, you should see your internal and external speakers listed. (Maybe Internal Speakers and "Headphones") Just right-click the option that says corresponds to your speakers and select "Set as Default Device". Close your web browser and re-open it. This should fix the problem.
Aug 27, 2011 | Computers & Internet
My pc left speaker didn't work. no sounds.
If one speaker doesn't work, then I would check the audio with another set of speakers. It could also be the sound balance that is turned all the way to the right. You can change the volume and balance in the control panel and sounds icon.
Jul 09, 2011 | Computers & Internet
The right speaker doesn't work
Make sure all the cables are connected properly.
Treble must be at mid-setting.
Jun 26, 2011 | Altec Lansing ACS 495 Computer Speakers
My lenovo y 430 has no sound for hedset & subwoofer doesn`t work. ... and right speaker works but left one doesn`t what should i do?
Make sure that the correct playback device is set as default in sound properties.
If all is well there then you could try a pair of headphones to see if the sound is working.
If headphones work ok then it is down to your built in speakers, not much you can do unfortunatly unless you are still under warentee
Jul 10, 2010 | Lenovo Tablets & eReaders
Car Audio & Video Logo
27 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marco Avila
Marco Avila
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
