Question about Sony BRAVIA KDL-V40XBR1 Television
Unit will not power up
I have replaced the Power Board to repair what I thought was the problem, the unit when plugged in turns on power/standby light but continues to cycle on and off during the warm up phase and makes a loud click and shuts back off. Screen and fans will activate briefly but seem to also cause the power to cycle off. Entire process lasts 5 sec then starts over?
    Champion:
  • 247 Answers
The lamp may be faulty needs replacement, another culprit is the color wheel when worn out they tend to get stuck and cant spin hence the clicks as tries to spin needs replacement most color wheels come inbuilt in the light engine u will need a tech to replace it and u are good to go remeber the lamp cant turn on if the color wheel is stuck cos its the one that syncrinizes with dmd board which in turn activates the ballast board to fire or light the lamp
Posted on Jul 18, 2013
  • 1694 Answers
SOURCE: No picture or sound - Power Save light blinks red 5 times - nothing on the screen
Best first step = change lamp
Posted on Oct 24, 2007
SOURCE: standby light blinks 6 times
It is fuse issue again. Go to this website and you should have solution or ask for one:
http://www.avsforum.com/avs-vb/showthread.php?t=507602
Posted on Dec 20, 2007
ctf1800
  • 4402 Answers
SOURCE: sont kp-46wt510 blinks 4 times
IC1509 8-759-593-33 IC LA78045 35.98
Q1505 8-729-423-33 TRANSISTOR 2SC3311A-QRSTA
Replacement part
8-729-119-79 TRANSISTOR 2SC2785-FEK-HFE 1.02
these ic locations are different than yours but same part number.
is there a 2sc3311 near by LA78045?
Posted on Jan 10, 2008
SOURCE: Intermittent lamp turn off
your lamp is fried just change it i did the same to mine and it works just like a charm
Posted on May 28, 2008
  • 1039 Answers
SOURCE: KDS-R60XBR1 Sony Projection SXRD
When the tv is working turn it offO on the remote press display,channel 5 number,vol-,pwr quickly in that order. you will see the self check screen. items with a 1 to the right is failure. the remove the slf check screen turn set off.
Posted on May 02, 2009
Haier window unit reset plug not resetting
check the house power board circuit breaker if the light indicator is not working
Jul 25, 2016 | Haier Heating & Cooling
Samsung T220hd won't turn back on from standby
Power up issues on the T220HD monitor are caused by a failure of the capacitors on the IP-49135b power supply board that this unit uses. The repair is easy, you just need to replace the 7 failed capacitors and the unit should be as good as new. Here is a link to some information showing what needs to be replaced to repair the power supply board.
http://www.ccl-la.com/catalog/product_info.php?cPath=21_33_68&products_id=217
I hope this helps.
Nov 21, 2011 | Samsung T220HD LCD Monitor
Marantz receiver standby light blinking
Your unit being stuck in standby mode is an indication that its having a power problem. Remove its plug from the wall and fix it back into the wall, then turn it on again. If its still stuck in safe mode, then the power supply board in the unit is the cause of the problem.
The power supply board might be defective and maybe that's why the unit won't power up. Its receiving power but it cannot transfer the current to the necessary part of the unit because a capacitor, diode, etc may have been faulty. Until these bad components are replaced, the unit might not come on.
To actually find out what's wrong, you need to disassemble the unit with a screw driver and check what's wrong. You will be needing a meter in order to test the components on the power board, once you detect any bad component, you can make necessary replacement at any electronics accessories store withing our vicinity. This is the only way by which you can detect the problem.
Of course, testing the power board with a meter will require someone that has the ability. So it you can't, then you might be needing the help of a repairman or you can call a friend that has the ability to help you out.
I wish you the best of luck.....
Regards.
Aug 11, 2011 | Audio Players & Recorders
When I turn off my Sony Compact av system DAC SC5 it flashes standby. I am unable to turn it back on while it is flashing standby. i have to turn it off at the wall and then wait 30 secs and then turn it...
The unit have a power supply board problems.That the board,where the power ac cord plug into it.Fix the power supply board or replace it,will solved this problems.
Apr 03, 2011 | Televison & Video
My pioneer VSX-D704S won't turn on. Only The standby light turns on.
Jan 17, 2011 | Pioneer VSX-D704S Receiver
My system is on standby mode how i can fix this problem
Your unit being stuck in stand by mode is an indication that its having a power problem. Remove its plug from the wall and fix it back into the wall, then turn it on again. If its still stuck in standby mode, then the power supply board in the unit is the cause of the problem.
If you know about electronics repairers, I would suggest that you disassemble the unit and read the power board/panel with a meter, detect the bad component and replace it.
If you don't know about electronic repairs, take the unit to the nearest repairman to fix the fault for you.
I wish you good luck.
Dec 24, 2010 | Audio Players & Recorders
Vizio L37
Check all electrical connections. If standby light is off when plugged in, probably needs Power Supply board replaced. If standby light is on (Orange/Amber color) may need Power Supply board and or Main Board. If set was shutting down on it's own leading up to it not powering on at all, may need Main Board, and possibly Power Board as well. If standby light has changed from Orange/Amber color to Green, the set IS powered on, and you have an issue other than power.
Oct 04, 2008 | Vizio L37 Television
Sony HDR-SR11 60GB High Definition Handycam® Camcorder
Problem seems in power supply section at VC-516 (main board). If you know how to open and repair it, just check Fuses at VC-516 board and these are located near connector coming from battery / dc-in jack area. One fuse is open in this case.
Aug 11, 2008 | Sony HDR-SR8 HD Camcorder
The unit will only turn on foe a few sec, due the standby light
Just inside the unit your power cord goes into a blackbox (like a coil of wire) that regulates the actual power the unit recieves, this maybe faulty and needs to be replaced but if this unit is out of warranty this maybe more expencive than a new one, the unit will still stay in standby but when you try to turn it on it draws more power and the supply control won't let it. I have had one of these units that has had the same problem in my work and it proved to dear to repair. Sorry hope this helped. You could try bypassing it but you would probably blow the unit up.
Jul 25, 2008 | Onkyo TX-SR600 Receiver
MDS-JE 520
what the problem sounds like is that your power button on ur main deck is broken or its in a standby mode activated by the remote. like some new dvd players that have the click in power button on the front u can turn them off by remote saving having to turn on the whole unit again from the main to use it.
Oct 04, 2007 | Sony MDS-JE520 Mini Disc Player
Sony BRAVIA KDL-V40XBR1 Television Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
