Question about Onkyo Audio Players & Recorders
Onkyo tx nr626
When i change the channel on the tv the onkyo still plays the sound from the previous channel rather than the current one.
  • 3 Answers
SOURCE: Onkyo - direct tv code for tx-ds 787
does anyone knows the code to control the onkyo TXDS 787 through the comcast.remote.?
Posted on Aug 21, 2008
  • 151 Answers
SOURCE: Echo when connecting Samsung Plasma to Onkyo TX-SR602
Make sure you have the tv volume turned right down as this will cause an echo,also set amp to prologic 2, and set up xover to suit your speakers or go for the THX standard of 80 hrtz and as a rule of thumb set front L,C,R speakers to zero rears to about +4or5 and your sub to -5[ dont know which speakers you have but try setting the subs on board volume to the 10,o,cloak position],also make sure the speakers -,+ are wired the same at the amp and speakers.
Hope this helps.
CABLE GUY.
Posted on Jan 06, 2009
  • 13 Answers
SOURCE: how powerful loudspeakers can my Onkyo TX-SV444 tackle, maintaining good sound?
buy 6ohms or 8 ohms speakers. 4ohms consume too much power and sometimes causes short circuit. (safety first!)
Posted on Mar 04, 2009
dunnbiker
  • 8546 Answers
SOURCE: No audio on any channel, even in audio setup mode, no audio headp
If you have any of its sound outputs connected to a TV or tape deck do they get the signal? If so, then we know there is sound processing somewhere inside the unit but not emerging to anyplace that requires amplification.
A quick basic check would be to tune an FM station, run an RCA cable pair from the audio output for a tape deck (see the picture at the link) to an analog audio input on your TV. Select that input on the TV and you shouls hear the FM station, or anything the receiver is configured to play. If it's silent then there is no audio signal circulating in the receiver to get out to the amplifiers.
http://www.onkyousa.com/images/hookup/TX-SR803/detail_tapedeck.jpg
Check to make sure Multi-Channel input is not selected unless that is what you're listening to as it bypasses all other sources analog and digital EXCEPT the tape; and check any Mute or Zone Controls, too.
If you hear the program on the TV but not through any attached speakers, then the amplifiers are all disabled for some reason. The click I asked about before... when you turn it on does it get a click about 5 seconds later. That would be the protection circuitry turning OFF to allow the amplifiers to function.
I notice it has a Tape function. Make sure it isn't selected as it assumes a tape deck or processor is attached and will only play back what would be coming FROM the tape deck or processor. On my Pioneer receiver it also disables any digital signal processing.
Sometimes when I'm watching TV with the remote on the seat someone moves and something bad happens. It's always some unfamiliar button that gets touched unintentionally. Look over the remote for things like MUTE, Multi-CH, Tape.
Posted on Apr 03, 2009
marsrover
  • 682 Answers
SOURCE: Onkyo TX-SR701 no Digital output sound!!
befor go to any direction please repeat your system setup as manual told you(for digital output setting)
Posted on Apr 09, 2009
Onkyo tx nr626 when volume high like 70-80 it turn off sign check speaker wires
soundslike a shorted speaker or a speaker that is being over-driven
Jan 07, 2015 | Onkyo Tx-sr507 A/V Receiver
NR626 - no sound
If none of your speakers gives any sound, perhaps you pressed the mute button on the remote control?
Make sure you have a source selected, that will give sound. Choose a low volume, before switching anything. You can destroy your speakers, when switching on with full volume.
If some speakers work, and only the surround does not work. check if you have surround sound as input. If you only feed 2 channels you can't expect to hear more than 2 channels.
Jul 01, 2014 | Onkyo TX-NR626
I have a new NR626 and I am unable to get the Sub Woofer Pre Out to work with my Bose Lifestyle Series II system with speakers. I tried connection the Bose through RCA to the NR626's Pre Out jacks, bu
usually if you have a sub out (line level) on the receiver..u can plug it directly into a pwrd sub and its plug and play..try putting another source into the woofer to see if its blown..if its not..then play with your menu settings on your nr626..get back to me if you need more help
Jan 08, 2014 | Onkyo TX-NR626
I recently purchased an onkyo tx-nr626 receiver with phono input. When playing albums , I don't get full sound. Sound is clear but not full and loud.
Different cartridges put out various levels based upon their technology - make sure you are using the proper input for their output. A line level input 1V P-P won't work on most phono cartridges and will require a preamp to boost it to the higher level.
Dec 23, 2013 | Technics SL-BD20D Turntable
Hi, I am having trouble connecting my Nintendo Wii to my Onkyo TX-SR507
Take the adapter cable from the Wii that plugs into the back of the Wii and converts the output(audio/video) into RCA style pin plugs, you will have: RED=right channel audio, plug it into any of the red audio INPUT on your Onkyo, then you will have WHITE=left channel audio, plug it into the other white INPUT jack next to the red plug on the Onkyo, then you will have YELLOW= video(picture) that will go directly to the yellow video INPUT on the back or side INPUTS of your TV.
Then when you want to play the Wii, set the input mode on the Onkyo to the inputs that you connected the red and white plugs into, then change the input on your TV to which ever the input is labeled on your TV in which you plugged the yellow plug into, you now will have sound comming from your Onkyo and the Wii up on the TV screen ready to play. Good luck!
Jan 27, 2010 | Onkyo Tx-sr507 A/V Receiver
Muffled sound from rear speakers why watching TV
switch the HDMI cables around to make sure its not one of them, if the problem is one of them it will move with the cable,if no change i would suspect the coaxial cable next.
Feb 12, 2009 | Onkyo TX-SR506 Receiver
Onkyo TX-SR500 Dolby Digital problem
I just read over the problem you were having with your Onkyo TX-SR500 receiver. It sound like the unit needs to be setup for all five channels.Sence your symptom says the diplay shows Dolby D3/2.1. According to the owners manual with the remote control look for speaker setup whin the button is pressed the current speaker setup will be shown in the display. Press the preset/adjustment<> to change the current setting to five speakers. the listening mode will automatically change according to the number of channels you selected. Hope this helps. Radiotech
Aug 14, 2007 | Onkyo TX-SR500 Receiver
DVD/TV Problem with TX-LR552
Did you change your TV input to DVD as well?
Jul 26, 2017 | Onkyo TX-LR552 6.1 Channels Receiver
60 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
