Question about Miele Touchtronic W1113 Washing Machine
Miele washing machine water intake
I just started the machine and it sounds like water is going into the machine - but it's not gushing through the detergent drawer, nor is any water visible through the window. Where does that water go? I pumped, tried again, same thing. What to do?
SOURCE: miele W830
I have exactly the same problem - what was the answer ?
Posted on Apr 05, 2008
mumma_1
  • 903 Answers
SOURCE: Fabric conditioner drawer
Try cleaning inside the the machine where the soap dispenser drawer fits into. Sometimes this builds up with lots of soap and fabric conditioner residue and stops the conditioner from going through.
Take the drawer back out and look inside where it goes to see if there is a build up of soap etc...
hope this helps
Posted on Nov 03, 2008
futureloginn
  • 734 Answers
SOURCE: miele washing machine wont drain
hi friend,
If your washer won't drain, check these:
It spins, but doesn't pump
It doesn't spin or pump
It pumps, but the water returns
If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many
washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub
that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's
attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the
hoses
from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the
large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using
needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator,
top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might
be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be
turning, the internal impeller may be broken. If so, you need to replace the pump.
If your washer doesn't spin or pump water out but the motor is running, your washer probably
has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the
pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen
or stiff--replace it.
If the water that pumps out of the machine goes back into the machine after the spin cycle, your
washer may be siphoning the water from a laundry tub that has a slow drain, back into the
washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck
in the drain?) Also, check for these problems:
* If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
* If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Posted on Dec 12, 2008
  • 3 Answers
SOURCE: miele touchtronic 1113 washer
There is a float switch in a pan under the machine. This pan is probably full and the float switch is causing the Intake & Drain fault signal. You can lean the machine over to towards the front to partially drain the pan. Put a towel down to catch the water. When you put the machine level again the fault lights should be out. The real question is where did the water come from. You can easily remove the top (4 screws, 1 on each side behind the little plastic caps and 1 on each side of the back. Torx heads) and look down inside while you start the cycle. Look for leaks.
Good Luck,
Dan
Posted on Aug 11, 2009
Mark Harmer
  • 8 Answers
SOURCE: Washing machine problem
Same - there's a company in Denmark which does brushes - you have to hunt them down on the web. The brushes come in a brass slider and spring, and sit in a rubber cage. Make sure you don't throw away any bits of the old brushes as you might need to reuse the old rubber cage.
Another solution (if you have the rubber cage) is to move the brushes along a bit and bend the metal tabs on the brass slider. That will give you a contact again - the machine will work for a few weeks or so, which gives you time to order the new brushes.
Posted on Sep 21, 2009
Miele fault F63
F63 on certain washers is an indication of too much soap is being used. If you live in an area where the water is hard and your not using too much soap you have a clog in one of the hoses used for air. Try to do a hot cycle with white vinegar. On other models the F63 is indicating that the water intake valve didn't find it's position. If this is the case just run an additional cycle.
Jan 21, 2012 | Miele Washing Machines
Hey there, i got a miele w4800 front load washer that stopped working all of the sudden. The buzzer is going crazy and the drain and intake fault lights are flashing. Any ideas of how i could fix this...
You have water in the bottom pan of the machine. grab it at the back and tilt it forward. the water will run out and it will start working again, but you will probably need a concertina hose. This is the hose that connects the detergent compartment to the wash drum.
Feb 15, 2011 | Miele W 4800 Front Load Washer
Miele W1926 check inlet light flashes at the end of rinse fill. When the fill ends, the light goes off. I cleaned all 4 filters at the intake hoses. The problem still exists. What does it mean?
Hi dear.It sounds like you'll need to change water inlet valve very soon.Because,machine waiting water level to be reach,in specific time frame in chosen program parameters to be get completed.If that does not happen,then it starts giving fault indication.Indication stops after fill,because task been competed & computer disregards the fault.If that won't happen then machine going to get stop completely & indication will carry on.Chage the water inlet valve if you can.I hope that helps. Thanks.
Jul 25, 2010 | Miele W1903A Front Load Washer
My Miele Touchtronic W1119 shows the error message Drain/Intake Fault. The intake and filters are fine. What's going on?There is no water standing in the drum. How can I reset this?
Hello Buvamo,
You may want to check the water valve and make sure it is all the way up where the intake line is.
The other area to check for water not draining is the lint trap. While the intake/drain fault is on the door will not open for the lint trap.
There is a release lever at the bottom of the machine (Orange in color) that is below and behind the trap door. Just pull down on the lever and that will open the trap door. You may want to put a towel under there as it will leak once the door is opened. inspect and clean the trap and try running cycle again
Sep 13, 2009 | Miele Touchtronic W1119 Large Capacity...
Miele touchtronic 1113 washer
Good Luck,
Dan
Aug 09, 2008 | Miele Touchtronic W1113 Washing Machine
Miele Novatronic W360
there is still water in the waterproof tray at the bottom of the machine and the float switch has activated. pull the machine out (if pipes allow) and tip the machine backwards to drain the water from the tray.
Jun 01, 2008 | Miele Novotronic W1918A Front Load Washer
Both the intake and drain lights are flashing
There are several simple solutions, one is reading the instruction manual. Check Intake: is any water entering? is it slow? This machine filters debris from the supply water so check the water intake filter. It is inside the end of the intake hose end against the home. Rinse it clean.
Drain: The same fault appears if the drain is clogged. Check if the lint trap is perfectly clean. Check the impeller (a set of fan blades) behind it spins freely. If buttons or coins get in there they can break off the fan blades and you can't drain water. Check the end of the drain hose if it drains. put it into a bucket or tub basin to observe how strong it pumps. Call Miele if these tips don't work. Be at the machine with Model and Serial number ready.
Dec 16, 2007 | Miele Touchtronic W1113 Washing Machine
Miele g841sc dishwasher leaks
Typically the machine only uses 5-6 quarts of water, If you're floor is getting 1 or 2 quarts check for a loosly connected intake or drain hose. I've never seen any overflow drain on a Miele. It only fills the bottom of the tub. The machine uses a logic program that continuously checks the level of fill and drain by water pressure weight so it always runs with proper amount, even if your intake pressure is weak. Now, If you add too much soap then the bubbles can carry a few ounces over a worn door seal. If the seal is damaged then more spray arm water can run down the front of the machine into the float pan. But after it gets less than a pint of water the drain float will start thr drain pump and shut-off the machine controls and alert you. It won't let you run the machine until the water ( and the problem) is gone. Call Miele for help.
Sep 15, 2007 | Miele 23 in. Novotronic G841 Built-In...
Miele Touchtronic W1113 Washing Machine Logo
87 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
