Question about Garden
John deere error code 70 - Garden
braintrust
  • 62 Answers
SOURCE: my 3320 john deere jerks and also shuts off the
You can call a local John Deere distributer. Talk with the parts department and tell them the error code you are getting. Give them your serial number and model number and they can tell you exactly what the error code means. This will allow you to run a search for the error itself and find a part replacement or fix for the error code.
Posted on Oct 27, 2009
wireguy212
  • 1627 Answers
SOURCE: error code 74 on john deere 3320 tractor
Lcd display switch is stuck in the on position either play with the switch until the code goes away or have the dealer replace the switch,it should still have warrenty.
Posted on Dec 02, 2009
wireguy212
  • 1627 Answers
SOURCE: john deere 3320 starts up,engine runs,pto works
Both codes are related to the forward and reverse pedals.To cycle through and clear the codes,turn the key on and then press the forward pedal to the deck within 2 seconds and release and the do the same with the reverse pedal,the code should go away unless the problem persists.If so then you need to check the wiring to the potentiometers on each pedal and also check to see if one has been moved[knocked out of range]If none of the above is the case then either the forward or the reverse solenoids could be stuck there-by letting the tractor think you started it in gear,hence no movement,these checks are not really a do-it-yourselfer type checks so you may need to seek help from Deere,hope this helps,thanks.
Posted on Feb 17, 2010
kel1guy2002
  • 3740 Answers
SOURCE: John Deere 4410 PTO error code. One long flash,
Check the wires on the solenoids.
http://www.tractorbynet.com/forums/attachments/john-deere-owning-operating/39426d1117768879-4410-power-take-off-stopped-665916-solenoids.jpg
Items L, M, N are mid PTO, MFWD, and rear PTO respectively
Also look at the skid plates as the possible cause of wire damage. A cheap spot / zip tie will keep the wires away from any future damage. Often the wires are damaged / torn off by a foreign object striking the Solenoid.
Thanks for choosing FixYa,
Kelly
Posted on Jun 19, 2011
  • 100 Answers
SOURCE: Do you know if I can put a motor off of a John Deere GX 85 onto my John Deere Sabre
as long as the lenth and diamather of the crank shaft are the same
Posted on Oct 26, 2012
John deere 3320 error code 63
You just go to the link I attached I'm sure you will get the solution of your problem.
John deere 3320
May 29, 2017 | John Deere Garden
John Deere 3320 error codes
John deere 3320
John Deere tractor error codes
Don't worry I'm sure you will get the solution of your problem, just check the link I attach.
Technique based repair and service any John Deere
John deere 3320 error code 03
Err 03 Reverse Pedal. Voltage signal out-of-range or not calibrated. Machine does not drive. Contact your John Deere dealer.
Oct 14, 2015 | John Deere Garden
What is wrong if the tractor has a epc 2408.19 error code
Contact John Deere online or try google and type John Deere trouble codes 2401.19
Dec 18, 2014 | John Deere 420,1020,2010,2020,2510,2520...
My 3320 john deere jerks and also shuts off the
Oct 10, 2009 | Garden
Garden Logo
258 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
