Question about Philips Office Equipment & Supplies
Philips proscreen 2700 - Philips Office Equipment & Supplies
Convergence phillips proscreen
The adjustment requires disassembling the projector. It's not really something that should be attempted in the field.
Sep 08, 2014 | Philips ProScreen 4750 Impact Multimedia...
How to get this to work I have a proscreen 4600, and when plugged in it comes on - so i assume it works, but have no manual- so don't know how it works. Can you assist me?
if you see light immiting then the bulb is ok.
it is probably the input, ensure the input is correctly selected.
eg video or computer.
connect your signal to the back connecor/s
and then on the remote our contol panel select that as your output to the screen.
it may take a while to warm up to get a image on the screen.
also when turning off do not unplug, use the off switch on the remote or control panel so it can
cool the bulb, this helps it last longer. then unplug when the fan has stopped.
I hope this was useful
May 23, 2011 | Philips ProScreen 4600 Impact Multimedia...
Fan is cutting off, then lamp goes out I think it is overheating
have you checked the air filter and openings for good ventilation
Mar 27, 2011 | Philips ProScreen 4600 Impact Multimedia...
User manual
try the viewsonic manual.
www.aboutprojectors.com/pdf/viewsonic-pj506d-manual.pdf
Feb 23, 2011 | Philips ProScreen 4100 Multimedia...
Phlips proscreen 4750, how do i open up the case to get to the inside/ and how do I adjust the convergence?
There is not a lot you can do with it, even setting up the static convergeance as you require a crosshatch generator, dot generator and specialist tools to adjust the LCD immagers.
It is not practical for the laman to attempt an adjustment of this sort.
Take it to a Philips Specialized Repair Centre.
Jan 03, 2011 | Philips Office Equipment & Supplies
Replace lamp
You have to buy a new lamp for this model,it can be ordered online at: projectorshop24.co.uk
May 05, 2010 | Philips ProScreen 4600 Impact Multimedia...
The projector does not operate the "lamp" led blinks in green and turn red after one minute. The switch on button does not replied.
either it's overheated or needs a replacement bulb.Do not cover this unit with anything as it will prevent cooling down..
Jul 27, 2009 | Philips ProScreen 4750 Impact Multimedia...
Help
Your convergence might be out.Go to convergence settings and try the setting and it can be done electronically.
Jan 20, 2007 | Philips ProScreen 4600 Impact Multimedia...
Top Philips Office Equipment & Supplies Experts
jasbo
jasbo
matt martin
matt martin
Are you a Philips Office Equipment and Supply Expert? Answer questions, earn points and help others
