Question about Coleman Mach 15 Air Conditioner
1988 Fleetwood Wilderness Camper AC fan won't blow capacitor bad
The AC unit on my 1988 Fleetwood Wilderness Camper has a fan that will not blow. I located the run and start capacitors and had them tested. The start capacitor runs "hot" and the run capacitor has an internal short. Noone seems to be able to identify the replacement part for this run capacitor. There are no words/letters/numbers on it and I can't locate specific info on the compressor either. I've been told that most campers this size (25') have 13500 BTU units on them. Any help would be fantastic.
  • 5 Answers
SOURCE: Compressor tries to kick in but then stops.
it is a hard start compacitor, the unit is not supposed to have three compacitors.
Posted on Apr 11, 2009
  • 3074 Answers
SOURCE: I installed a new colman mack thermostat in my
if it is a programmable thermostat you can unhook thermostat and when it comes on select 3 instead of 1. As it sounds as though it is short cycling this happens in older houses with drafts. Hope this helps Tim
Posted on Sep 07, 2010
motor1258
  • 6674 Answers
SOURCE: Hello , this is Bobby
Here's a link to a service manual, with step by step tests to determine whats wrong. I'm thinking compressor shot, but this should confirm, and or help you determine for yourself. Be careful with those capacitors eh !! Read warning in service manual.
http://www.rvcomfort.com/pdf_documents/1976141_copy.pdf
Posted on Oct 19, 2010
  • 43 Answers
SOURCE: I have a Mach3 unit with 1 capacitor 35uf 370 VAC
You need to check the Amp draw at start up of the compressor. Also if you have a meter that can check the compressor capacitor, it needs to be checked. If the capacitor is ok and the compressor starts at a higher Amp draw than the rating on the capacitor, you will need a start capacitor.
Posted on Jun 05, 2011
hvac1960
  • 2133 Answers
SOURCE: AC UNIT RUNS AND ALL OF THE SUDDEN FAN STOPS AND COMPRESSOR WILL RUN A LITTLE WHILE AND STOP. THEN FAN STARTS AND COMPRESSOR KICKS IN AS NORMAL. ONLY HAPPENED A FEW TIMES, BUT I DONT WANT TO WAIT UNT
Check the condensor unit. May be dusty. Clean it. If still problem replace capacitor.
Posted on Sep 07, 2012
What kind of generator for a 1978 Wilderness trailer
1978 Wilderness Prices, Values and Specs Building travel trailers as well as fifth wheel trailers for the first time in the 1970s, recreational vehicle brand Wilderness designed as basic family vacationing and camping. Wilderness would also produce park model vacation units from 1994 to 2002 measuring up to 40 feet in length. A division of Fleetwood, Wilderness was discontinued after the 2009 model year.
Mar 27, 2017 | Televison & Video
What refrigerant is in a Coleman 7300 Series AC Unit, on a 1995 Wilderness Camper?
This unit uses R-22. Here is a link to the service manual:
www.bryantrv.com/docs2/docs/rvp/rvp6789mech.pdf
Jul 17, 2015 | Coleman Heating & Cooling
I need a manual for a fleetwood wilderness trailer camper 32ft long
one of my favorite sites to find free manuals is (PDF foo.com) I have been able to find every manual Ive ever looked for there and have been able to save them to my file folders for printing and future reference try them.
t
Sep 15, 2014 | 2009 Saratoga Pop Up Trailer
I have a 2006 Gulfstream Cavalier 8'x 32' Fema Travel Trailer with a Dometic Duo Therm AC unit which I have recently replaced the fan motor on. Had the dealership bench test motor prior to lea
There is ice forming on the evaporator coils. This is either from a low freon charge or a leak in the seals or windows and doors. Could also be that the drains are not working and water is building up and freezing
Oct 10, 2012 | Dometic Heating & Cooling
Outside AC unit not blowing - Goodman dk-36-1d
1. check to make sure your 220volts is there at disconnect box.
2. check if you 24volts at contactor at the outside unit.
3. if you got it all check the capacitor.
Aug 05, 2012 | Goodman CKL36AR36 Air Conditioner
Ac compressor will not start
Hello, sounds like a faulty capacitor. Check the capacitor to see if it is puffed up at the terminals. It will be located inside the outside unit and looks like like a can that is oval or round.
Jun 17, 2012 | Goodman Heating & Cooling
Need to locate a owners manual for a 2004 fleetwood wilderness advantage2952bs fifth wheel
Contact the manufacturer and provide them the Model number. If it is still in print they can provide you a copy for a fee.
Apr 22, 2012 | Electronics - Others
I can't locate the 12 volt converter in my camper
They hide them under seats, in closets, in side storage compartments.
The unit is often a shoebox sized box with a power cable in and cables to the battery out. OFTEN the fuses are located centurally for the whole trailer.
While properly charging, you should see about 13.5 to 14 volts across the battery.
Aug 29, 2009 | Electrical Supplies
Heil airconditioner is not cooling? Heater works
If no blowing air is coming out to your ac or evaporator fin,your blowing fan is not working.There are several factor to check qualified electrician or ac techician should do this.If you have knowledge on electricity and motor control,beside you should have clamp ammeter to use in trouble shooting of ac electrical circuit.Unplug your ac If there is an opening of blower fan of your ac mostly the top cover open this one locate the wire connection of blowing fan take the color and size.Open the terminal box below the control panel of ac and locate the wire of blowing fan.Check how many leads make sure to make sketch where it was connected from low,medium, and high there is coded color on it,discannect from the terminal, using clamp ammeter set to ohms probe setting R10 check continuinity of winding motor start at common lines(mostly balck color) of one test rod and the other to starting line(mostly red color)take and read the resistance if has a higher resistance your motor is burn out, also with the running line w/c has multple line for speed.If resistance complied to your motor rating or good,If not or burn out replace fun motor.Check your capacitor,doing this set your ohmeter to a higher resistance,connect one red test rod (+) one terminal of capacitor and one black test rod on (-)the other terminal the pointer will deflect steady to higher resistance then reverse the connection of the test rod,the pointer deflect again to higest resistance it will go slow backward setting to zero if you got this result your capacitor is good.But if it does not go set back to zero your capacitor is short.Replaced capaciter.
Mar 10, 2009 | Heating & Cooling
Coleman Mach 15 Air Conditioner Logo
69 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
