Question about Brother DCP-110C All-In-One InkJet Printer
PRINTING ENVELOPES I have the Brother DCP 110C Printer and I am trying to print envelopes for my wedding and it keeps jamming! Please help. Nothing seems to be working and I think I have the envelope lined up properly.
  • 832 Answers
Printer does not except all kinds of envelopes. Please read user guide which envelopes are allowed: http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000000/000063/faq000063_003.html?reg=us&c=us&lang=en&prod=dcp110c_us&Cat=4
Posted on Sep 09, 2007
SOURCE:
Ink spots on envelopes
Hi rebecca,
Go To Below official Hp Printer Forum Page For Your problem And Solve Your Problem Black ink stains envelopes when printing HP Support Forum 955951
Feb 24, 2014 | Canon PIXMA MX340 Wireless Office...
Brother DCP-110C printer not printing!
Clean the heads....................
found in printing preferences / maintainance
Jul 16, 2010 | Brother DCP-110C All-In-One InkJet Printer
I have an HP Photosmart C4180 all in one and would like to know how to print #10 and also wedding size envelopes. I have tried changing the orientation on the Properties tab and changing the envelope size...
Hello Friend,
When you want to print page # 10 please see below and for wedding card printer please select envelope size from printing prefrences menu.
Start>settings>controlepanel>printer>C4180>Properties>printing prefrenes.
Thanks,
Viju
Apr 03, 2010 | HP PhotoSmart C4180 All-in-One Color...
Double printing addresses on envelopes
You need to make sure you set up for envelopes in printing preferences as this makes the fuser a little hotter. If all is set up properly you need a shop to adjust the fuser temperature. The thick envelopes require more heat to bond the toner properly.
Feb 05, 2010 | Brother DCP-7020 All-In-One Laser Printer
Saying paper jam dcp-135c brother printer
 Hello there,If the paper is lodged too far into the printer and can't be removed: Press the power button to turn the printer off.
Pull firmly on the paper to remove it. If you can't reach the paper because it is too far in, raise the front cover and remove the paper from the front of the printer.
Close the front cover.
Press the power button to turn the printer back on.
Resend your document to print.
Ensure that:
The paper is a recommended paper for Laser printers.
You do not force the paper down into the printer when you load it. For example, if you are loading letter or A4 size paper, the top edge of the paper should extend above the top of the sheet feeder.
The printer is on a flat, level surface.
The left paper guide is against the side of the paper.
You do not load too much paper in the sheet feeder. Depending on the thickness of your paper, the sheet feeder can hold up to 100 sheets of paper.
The left paper guide does not cause the paper to bend in the sheet feeder.
Your printer feeds regular paper as expected. If regular paper feeds without causing problems, load the envelopes vertically against the right side of the sheet feeder. Make sure the paper guide is against the side of the envelopes.
Envelopes or the appropriate specialty papers are selected in the printer driver.
You are using a paper or envelope size supported by your printer.
do not forget to rate this solution....good luck
thanks for using FixYa
Jan 30, 2009 | Samsung SCX 4521F All-In-One Laser Printer
Envelopes keep jamming
hello! try cleaning the paper feed roller where you feed the envelope in with denatured alcahol good luck
Dec 29, 2008 | Brother MFC-8460N All-In-One Printer
Printing envelopes from gestetner 3502P
What size are the envelopes?
Envelopes have to be fed through the bypass. #10 envelopes are not recommended to run through the copier. There too small to feed through the fuser rollers and they will jam.
Sep 03, 2008 | Office Equipment & Supplies
Brother DCP 110C has an error on the LCD screen it says unable to print...
try reloading the software and check that the usb lead is connected inside the printer and to your computer.
Sep 02, 2008 | Brother DCP-110C All-In-One InkJet Printer
Printing Envelopes
Hi - You can download the manual from the link below:
Brother DCP-130C
Yes you can print envelopes:
Please update the question & let us know if the information given was useful to you - Good Luck!
Jul 07, 2008 | Brother DCP 130C All-In-One InkJet Printer
Envelope Feeder is not accepting the command
> Home > Support & Drivers > Knowledge Base
Solution --> Phaser 4400 Printer: Printing envelopes
Printing EnvelopesEnvelopes can be printed from the optional envelope feeder, the Multi-Purpose Tray, or Tray 1, 2, or 3.
Guidelines for envelope printing
  • Use only paper envelopes.
  • Do not print on the back of the envelope.
  • Never use envelopes with windows, metal clasps, or exposed gummed surfaces.
  • Keep unused envelopes in their packaging to avoid the effects of moisture and dryness, which can affect print quality and cause wrinkling.
  • Envelopes may wrinkle depending on weight and stiffness of the envelope.
Many applications include a tool for creating an envelope document. For example, Microsoft Word includes an Envelopes and Labels feature in the Tools menu. Be sure to:
  • Select faceup.
  • Clear Clockwise Rotation.
  • Select the feed method with the image centered and the stamp on the envelope to the upper left.
caution_image88x30.gif Never use envelopes with windows, metal clasps, or exposed gummed surfaces; they can damage the printer. Damage caused by using unsupported envelopes might not be covered by your printer's warranty.
note_image33x30.gif Note: The heat from the printing process can melt certain types of envelope glue. If the envelope flap sticks shut after printing the test print, tuck the flaps inside the envelopes when printing the remaining envelopes. Printing envelopes from the envelope feeder
  1. Insert the envelopes into the envelope feeder. For more information, refer to the Trays section of the Trays and Paper Guide on the Interactive Documentation CD-ROM.
    • Place the side to be printed faceup.
    • The top of the envelopes should be toward the left of the printer.
Feb 19, 2008 | Xerox Phaser 4400B Laser Printer
Brother DCP-110C All-In-One InkJet Printer Logo
165 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
