Question about Stihl Hs45, Hs 45 Hedge Trimmer Bottom Gear Box Cover Part 4228-641-0400
Hs45 backfires spits
Trimmer was running well, then starts running erratically. On trying to restart, engine backfires/spits thru exhaust. Changed plug cleaned carb, replaced with fresh fuel mix. On trying to start still spitting, won't run. Any clues??
  • Stihl Master
  • 1,807 Answers
Sounds like an over fueling issue, Try resetting the carb to its standard settings, screw both tuning screws right in ant then turn anticlockwise to the following settings H 3/4 of a turn. L 1 full turn. This should set it back to standard. If this doesn't help then it could be a carb diaphram or sticking needle.
Posted on Jul 16, 2013
Hs45 does not prime properly and won't run at full revs
Replace the carbeurator and all fuel hoses. The circuits in the carb are stopped up and they are so small they can't be properly cleaned out.
Jun 23, 2014 | Stihl Garden
Backfiring thru exhaust
Valve Lash is incorrect, can also be caused by injector fallout ( injector over heated and continues to dump fuel long past its cut off point ).
May 07, 2014 | Caterpillar C15 Acert Engine Wdisplay...
Stihl hs45 will not start but it will run after i use auto start
Check fuel lines, filter and carb... Sounds like a poor fueling issue. clean and replace carb diaphrams. Check gaskets between cylinder and carb.
Feb 23, 2014 | Stihl Hs45, Hs 45 Hedge Trimmer 450mm 18"...
Backfire, Black smoke from exhaust, spitting and sputtering
If you have not replaced plugs start there A bad map sensor will also cause black smoke and poor running
Feb 15, 2014 | Dodge Durango Cars & Trucks
Backfire thru carb 1340 99 springer
Hi Anonymous, popping, coughing, spitting, or backfiring through the carburator is usually caused by air getting sucked in combustion chamber do bad intake seals leaking. Leaking exhaust gaskets can also be suspect. Remove air cleaner and backing plate, while engine is idling spray WD-40 or Brake Kleen around intake manifold to head area, if RPM's increase you have an intake leak and seals need to be replaced, also spark plugs will be burning whiter than normal. Good luck
Jan 18, 2014 | Harley Davidson Motorcycles
Briggs & stratton mod. 406777-0115-E1 engine backfires thru exhaust
This is a true tale sign of a valve being out of adjustment or possible burnt or sticking. Most likely its just out of adjustment. Setting them to Book Specifications of: Valve Clearance (cold) IN and EX .005" (0.13 mm) should take care of the problem. Since you said that it runs fine rules out the possibility of a sheared flywheel key, though I have seen one run with it slightly sheared. Thanks; George
Apr 22, 2013 | Briggs & Stratton Garden
Backfiring through throttle body on hot start up
Jul 18, 2012 | 2007 Harley Davidson FLSTC Heritage...
1995 honda xr 600r has been backfireing upon acceleration
Are you talking about "backfiring" out the exhaust or "spitting back" through the carb?
Backfiring through the exhaust under acceleration is rare. If he ignition is misfiring, unburned fuel and air mixture is exhausted into the exhaust system. The next time the plug fires, it ignites this mixure. In other words, your engine is "missing" and your ignition system needs attention.
If it's "spitting back" out of the carb, this is usually an indication of a lean mixture. If it's doing it at wide open throttle, you might need to go up one size one your main jet. If it's doing it under less than full throttle acceleration, raise your needle up one notch and try it again. You want to richen the mixture just a bit. Too much and the bike will get sluggish.
Oct 10, 2009 | 1995 Honda XR 600 R
Flywheel removal from TB425CS
YOU MAY HAVE TO USE A PULLER FOR THE FLYWHEEL I CAN'T SEE ANYTHING ON THE BREAKDOWN OF THE ENGINE THAT WOULD SHOW ANY THREADED HOLES FOR BOLTS TO REMOVE THE FLYWHEEL
Sep 17, 2009 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
Starts but won't speed up enough to run
If this is a 2 cycle engine the problem could be that the exhaust is clogged. Most 2 cycle engines have a spark arrestor on the muffler which clogs. could also be the exhaust port from the engine. remove the muffler and check it out.
May 15, 2009 | Garden
Stihl Hs45, Hs 45 Hedge Trimmer Bottom Gear Box Cover Part 4228-641-0400 Logo
518 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
