Question about Intex Automatic Salt Water System for Above Ground Saltwater Pool
I added Salt Pool Rejuvenator to the pool it has been in about 1 and half hours is it safe for the kids to swin in
How long should i wait for the kids to swim after adding the Salt Pool Rejuvenator
SOURCE: pool pump
You may have a hard water problem. Remove and inspect the unit containing the plates. You'll be able to see build-up. I was surprised to see how much it had coated the plates after only a month of use. Cap end and soak with vinegar. Re-install. Check regularly. Also, with the initial salt startup, a 16'x48" requires 120 pounds, the first time your low salt light comes on, the manual says to add 30 more lbs. That's a total of 150 lbs. Speed up the salt dissolving process, mix it up physically and aim the return down into the water, remove the skimmer if you have one so intake and circulation is maximized. Run for 24 hrs. Make sure you have a more than adequate pump with a clean filter. I replaced mine with a larger Intex pump.
Posted on Jun 25, 2009
  • 297 Answers
SOURCE: CLOUDY SALT WATER POOL
salt does not solve your problem.
People do no realize that all the salt does for you is that it eliminates having to pour regular chlorine in.
Everything else stays the same as a normal pool with just plain ole h2o
The dilema is that intex filters are to small for the job that needs done especially in your case now that you have the dreaded green monster
your solution is to first get it cleared up
shock your pool with 2 gallons of liquid chlorine and then filter filter filter
You will need to brush the dead algea and vaccum once or twice a day for a couple of days and you must clean that cartridge 3-4 times a day with the garden hose
you will be surprised how much green it will trap
once pool starts to clear and the chlorine level starts to come back down from Mars you can start using your generator again.
you will need to find the amount of time thatorks for you but 3-4 hours will not cut it in the hot weeks
Chlorine consumption is due to #of bathers, heat ,sun, rain so any given day will dictate a different amount of generation needed keep it high so you do not get algea again about 3.0
you also got algea because you were not stiring up the pool enough you again need to filter filter filter every day
try to find some of my other postings with more specifics
Posted on Aug 13, 2009
  • 297 Answers
SOURCE: Green water with salt water filtration system- HELP
you can not blindly just add salt
you need a salt test kit that reads #'s, not color
Get your salt content to as close to 3000ppm as you can any lower than 2800 and you will not produce enough chlorine and any more than 3500 and it will taste bad and could make your water cloudy or trigger high salt alarms
Also remeber to run filter only for 24 hours after adding salt
you also need to realize that a pool goes green for many reasons lack of sanitizer,heat,sun,rain,sun tan oil, 3 of swimmers
A pool need to be turned over at the bare minimum of 3-4 times in a day.
Intex filters are not sufficient to properly do the task
only a good sand filter and seperate pump of about 1 horse will really keep a pool sufficiently cleand but if you follow my advise you can do it with the intex
lets start with the filtering I believe your pool is around 5000 gl
if you have a 2000 gl ph pump then you need to be filtering 7 1/2 -10 hours just to keep your pool clear you do the math for you
as for grnerating your chlorine time varies depending on the situations I mentioned earlier
it is good you are using a stabilizer but that only goes so far if it was hot and sunny and a lot of use chlorine will get ate up any way
And make sure your algaecide is a non foaming kind and stick to the directions
now to your problem at hand
you now need to as you did shock it but you also need to use a lot of elbow grease and remeber this is going to be tedius
Clean your cartridge with the garden hose blast it in the folds as hard as you can
start your filter again and now add 2 gallons of chlorine or house hold bleach
let filter for 12 hours and then with a pool brush not the bristles under your vacuum head scrub the sides and walls continue filtering until you see the settled algae and then vacuum
now clean your cartridge again and repeat if the chlorine is still high you do not need to add but if it went low again then add 1 more gallon
continue doing this until you can see a huge difference
once you can then start with your algaecide again
at this point overdose it as directed on the bottle once your chlorine is low enough to get in then you need to get in and brush under the seems
with the intex liner there are too many seams and folds that need to be addressed
another hint is to have 2 filters one drying while the other is in the unit
a wet freshly cleaned filter does not work and trap particles as well as one that has been dried
Another good chemical to use is a water clarifier this helps minute particles that you can not see clump together thus making it easier for thr cartridge to trap
good luck and if you have any more questions you can e-mail me through this site
Posted on Jul 09, 2010
Testimonial: "Was very helpful, very knowledgeable, unfortunately fairly impatient about being "rated" and called me an A**hole because I hadnt yet rated him due to being sick. (and the fact that I didnt know I even needed to) Thanks for the advice though!"
  • 297 Answers
SOURCE: My salt water gets green then, i shocked it and
Your last sentence says it all
So many peolpe are led to believe that using a salt system takes away the need of other chemicals
This couldn't be further from the truth A salt system just makes it so that you do not have to physicaly ad liquid chlorine or float tablets
First of all lets get a little educated in pool maintainence 101 and then I will address your problem ( First problem was buying an Intex product ) but I will cover that too
You can not just blindly ad salt to the system
you need to get a salt test kit that reads in #'s not color
You need to get the water to as close to 3000ppm as possible
Any lower than 2700ppm and you can trigger low salt alarm, not to mention not generating enough chlorine
Any higher than 3500 and you can go cloudy, trigger high salt alarm and you could go cloudy
Now for the intex curse
not a single pump/filter is sufficient with the pools they come with
They are to small
A pool needs to be turned over at least 3-4 times in a cycle 24 hours
I do not know your gl or pump size so I will use generic #'s
If you have a 5000gl pool and a 1500gl pump thats 10 1/2 hours of filtering at the minimum
Use your #'s and figure out what you need to be doing
You want to start by getting your salt right this is crucial What it says in the manuals is just a starting point the fine tuning is up to you
Lets now side track and I will tell you how to cure your problem.
This is time consuming but will give you the best results
Blast out your paper cartridge with the water hose now ad 1 gallon ofliquid chlorine
Filter only for 24 hours now brush your pool with a pool brush not the bristles under your vaccum not enough of them to do any good
now clean the filter again and run for a few hours until you see things settle down
Vaccum and clean the filter and start over again
Check your chlorine if it is normal or low ad another 1/2 if it is super high then leave the chlorine step out
Once you are clear again or close to it Ad a non foaming algecide and also ad chlorine stabilizer this is a chemical that you put in a nylon sock and float it behind the ladder this will help hold the chlorine
Once your chlorine level is at the point you can swimm again you should get your best swimmer to get in with a tooth brush and clean the over flaps in the seems that are on the bottom and where the sides connect to the floor
This should do it
lets look at one more thing
Chlorine generation
There may be night that you need to run it 12 hours for chlorine and other nights 5 or so
It all depends on many factors
sun,heat,number of swimmers, sun tan oil and so on
The biggest thing you can do wrong is to not use the pool If it is not being used every day you should brush sides and floor every 3 days or so. The pump is not strong enough to circulate the water properly
One more thing that I do and I have not changed my filters in this being my 3rd season
I have 2 one is always drying
Start with a dry filter and have the other clean and drying
Change them every couple of days.
Never try to use a wet filter it does not work like a dry one
Dont ask why it is just one of those mysteries
Also periodicaly take the hose off the front of the motor your inlet hose this can build up hair and debris that gets in from skimming
Good Luck
Don't forget to rate this
Posted on Jul 27, 2010
Testimonial: "I sure am glad that I finally got real answers to my question. Thanks!"
rulds2008
  • 3866 Answers
SOURCE: Keeps saying low salt level
I would say the rain is diluting the system at this point, or the system sensor has gone out. But if you had heavy rains I would be looking at that idea first.
thanks for using Fixya.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on Jun 23, 2009
High copper, High alkalinity, No chlorine & salty water
call in a pool expert to help you set up the system properly and to check the chlorinator
from your statement you are making things worse by not fixing the problem
Mar 18, 2017 | Intex Automatic Salt Water System for ...
I have done everything the manual says, but my saltwater system will not stop blinking error code 91. The salt level is fine, and the cell is clean. Do I need to replace the cell. My pool is now green and...
Bummer!!! Looks like you checked both things that would cause the code 91 error for "Low Salt". Here's what I've done to solve my low salt "91 code in the past.. I overshoot by 1/2 bag = 20lbs of the recommended salt add quantity when the code appears. Calculate by using this formula..
.0067 X Pool Gallons. I have a 14,000 gallon pool and when I get the 91 code for low salt, I add about 110 lbs of salt. Manual says 93 lbs...let it circulate for 24 hours by running the pump only and then start the chlorination cycle.. Before doing this, you MUST make sure the cell in clean.. If any calcium buildup inside, it can give you a false "Low Salt" alarm.
I hope this helps!!
If this helps, please rate... Thanks
Jul 17, 2011 | Intex Automatic Salt Water System for ...
I bought a 8 by 30 intex pool without a filter howcan I clean the pool
you can use a Vortex cleaner that uses your garden hose
it is called Swin Safe
Supa Vac Water Care Kit with Leaf ScoopThe Swim Safe Supa Vac Water Care Kit with Leaf Scoop allows you to quickly clean or empty a wide range of water fixtures.
The Swin Safe Supa Vac Water Care Kit includes hose and accessories.
You should be able to buy this fram any decent Pool shop or Google it on line
Jul 03, 2010 | Computers & Internet
Registering low salt
your pool has approximately 12,500 gallons of water
this calls for about 310 pounds of salt.
One of your problems can be the acis rain ate away at your salt content
You really need to get aalt test strip kit the kind that reads #'s not the colored strips
Get you salt to as close to 3000ppm as possible to low towards 2700 will throw off the alarm and also to high around 3800 and up will alarm also.
It is also possible to have to much salt and the unit will read 91
Get the pool to 3000ppm either by draining 20% or so and adding fresh water or adding salt which with your amount so far I am thinking you will need to lower it
Run filter only to thouroughly mix the pool for at least 24 hours before trying to generate chlorine.
In the meantime also take your electro cell and soak it in vinegar for 4-6 hours rinse well and put it back together
Jun 16, 2010 | Intex Automatic Salt Water System for ...
Low salt alarm on Intex system
so what does the test strip say. Should be as close to 3000ppm as possible anything close and under 2700ppm will trigger a low salt also you must run filter only for 24 hours to thouroughly mix the salt before trying to turn on the generator
Jun 14, 2010 | Intex Automatic Salt Water System for ...
Salt water pump worked good now will not go to cholorine, no code
I EAS GOING TO UPGRADE TO A SALT PUMP FOR OUR POOL LET ME DO SOME RESEARCH ON THIS FOR YOU
Aug 16, 2009 | Intex Automatic Salt Water System for ...
We switched to the saltwater system and the water is cloudy
hello way too much for me to type if you want to call I can go through it have a pad of paper and pen ready
Mark
586-625-2300
Jul 19, 2009 | Intex Automatic Salt Water System for ...
I don't know how much salt is needed for my 18x6 pool 3 bags have been added and the system keeps beeping more salt needed.
keep adding salt.(1 to 1/2 bag at a time - let mix in for an hour - re-test)
If you live in high rainfull areas - you will need to add about 1 to 2 bags of salt after every heavy rainfull.
Jun 30, 2009 | Intex Automatic Salt Water System for ...
Pool pump
Jun 14, 2009 | Intex Automatic Salt Water System for ...
My salt water system keeps saying low salt, but it has more than enough, what do i do
Ours said low salt too after we had added enough, then added 25 pounds more. I was really worried of adding too much because then you have to drain it and start all over again! We waited about 6 hours after adding the last amount, giving it plenty of time to dissolve, and now it's working fine. How long are you waiting in between additions of new salt and running the system? Good luck!
Jun 13, 2009 | Intex Automatic Salt Water System for ...
Intex Automatic Salt Water System for  Above Ground Saltwater Pool Logo
145 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
