Question about Refrigerators
Kenmore coldspot I have a 1993 refrigerator with water dispenser. I would like to know if there is a water filter or no. Thank you.
fridgetech
  • 473 Answers
SOURCE: Kenmore Side by Side Refrigerator Ice Maker Not Working
A couple things to check here. First see if there is ice in the tray. If so chances are the ice maker will need to be replaced however these are very reliable ice makers. If no ice in the tray pull up on the ejector blade (don't worry you won't break it) turn clockwise to start the ice maker thru a cycle. The ejector blade is the long white bar with fingers on it that run the length of the tray. Once it completes a cycle it should fill with water. If no water then either the fill tube is frozen over and will need to be defrosted or the water valve is bad.
Posted on Oct 05, 2007
  • 100 Answers
SOURCE: Kenmore Refrigerator stopped dispensing water
Either your water tank in the fridge froze up, the waterline that goes up the freezer door from the bottom hinge froze, or the switch that your glass hits is damaged. Do you hear any humming or noises when you put your glass up to get water?
Posted on Oct 30, 2007
SOURCE: Water filter stuck on my Kenmore Fridge
I had the same problem. I coudn't get the knob to turn. I ended up taking the front grill off so I could get a better grip on the knob. Once I did that I still have to put a lot of pressure on the knob to turn it but that did the trick. When I got it turned a quarter turn then it was easy to pull the filter out. Hope this helps!
Posted on Jan 11, 2009
woodchuck789
  • 4066 Answers
SOURCE: Kenmore side by side refrigerator water dirty
You may need to replace the water reservoir located behind the crisper. They are known to flake and cause the problem you describe. They are usually replaced with a coil of water line instead of one larger reservoir to stop the problem.
Posted on Oct 11, 2009
SOURCE: getting water
I have Kenmore Coldspot refreidgerator and am having a problem with water pooling inside the fridge at the bottom underneath the drawers (mostly the left side). Where is the water coming from and it formed a thin ice.
Thanks
Posted on Dec 22, 2009
Where is the water filter on kenmore coldspot 106.9505712
On the front bottom of your unit you have a grill. On the grill there is a round knob. Turn the knob 1/4 turn counter clockwise and pull the filter out. Note the slot on the back of the knob that holds the old filter. Slide the old filter out of the slot and replace with the new filter.
Reinsert the filter with the knob into the filter housing. Turn the knob 1/4 turn clockwise to lock it in.
Now, the new filter has air in it. At your water dispenser, fill cups with water. There will be a lot of air and water coming out. Continue this until all of the air is out of the filter and there is just water fill.
When to change your water filter - Your unit has a water filter change light. This light is not tied into water pressure. It is like a egg timer. Every 6 months it will light. This does not mean you need to change your water filter. Change your water filter when your ice cubes start to get small or the water coming out of your dispenser is of a low flow. Depending on your family size, you may not need to change your water filter for several years.
My name is Peter. I am a retired Sears Home Services refrigeration technician.
Oct 24, 2014 | Kenmore Refrigerators
Why has my Kenmore coldspot 106.54609300 stoped dispensing water and making ice?
if it not getting enough water pressure it will not work. check your line going to it if it's ok turn water off then where the water line goes to the frig unscrew it check the filter.
Jul 30, 2014 | Refrigerators
Kenmore coldspot- 106 Model 9537654
The Kenmore Model 106.9537654 does not appear to have a water filter. Thanks Sea Breeze
Here is a PDF of the parts=> 106.9537654 Parts
Jul 15, 2013 | Kenmore Refrigerators
Kenmore Coldspot Model 51572200 is leaking water all over the floor
On the bottom rear of the refrigerator as you are looking at it from behind the left side where the water is feeding into there should be a double valve. 1 is for the water and the other to the icemaker. Many times that valve won't shut off, however the switch that dispenses the water is evidentially bad and needs to be checked if it is stuck open.
Jun 03, 2017 | Kenmore Side by Side Refrigerator
Kenmore coldspot 10656929600 ice dispenser flap
probably will have to take dispensor apart to see what the problem is there, front cover should pry off from bottom
Jul 07, 2009 | Refrigerators
Water dispenser won't stop dispensing water!
Hi I dont have the knowledge of your fridge, but I'm just going to throw this idea your way , please forgive me if im wrong :)
Perhaps the problem is due to syphonage, the discharged liquids are creating a vacuum along the line.
Did you reposition the height of any supply hoses ? none of them should be above/higher the outlet source itself.
You could also try installing a inline reverse flow suppressor
(small plastic filter that only allows one-way direction of flow.
Jun 10, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
there is valve for each right at the water inlet, your valve is stuck or your coil is bad......get a new valve.
Nov 03, 2007 | Refrigerators
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
