Question about Roland Versa Art RS 640 64-inch Printer
Test print distortion
When i do the test print its looks with distortion
    Champion:
  • 241 Answers
Go through alingment
Posted on Jul 23, 2013
Why does my Xerox Phaser 5500 print distorted watermarks?
Click caret ro right of friend's post, click unfollow without unfreinding.
Feb 26, 2015 | Xerox Phaser Office Equipment & Supplies
My printer will not print in any color. The nozzle check pattern does not run black and the other colors are distorted. I have cleaned print nozzles several time but it doesn't help. Suggestions please
The printer head might be the problem, if you print a test page what do you get?
Easyest solution would be to call your dealer check about warranty while your at it.
May 18, 2008 | Office Equipment & Supplies
Distorted printing
I have this problem also. Replaced parts, followed manual & still can't figure out what to do. Any suggestions?
Dec 10, 2013 | Ricoh Aficio CL3500N Laser Printer
Prints all pages with a with a distorted black background
WEll the thing is that you should really take out the cartige and then shake it and put it back in! it always helps me!!! i always do that hope i helped
Dec 02, 2011 | Lexmark X4650 InkJet Printer
Distorted printing on i560 printer
Double-click print centre icon.
when it opens up, select I560, then click configure.
click I560 then click select
click the down arrow to select test print.
nozzle, alignment etc...
run the tests try resolve the problem.
Hope this helps
Regards
Apr 16, 2009 | Canon BubbleJet i560 InkJet Printer
Lexmark Optra T610 prints distorted and broken text and images
try deleting the printer and drivers completely, then reinstall
Mar 11, 2009 | Lexmark Optra T610 Laser Printer
I have a Xerox Phaser 8400 with image problems. After power up it prints a Startup Page - That page is black text which faded and slightly distorted in some areas and in areas that are in Color only...
What you are describing is a bad print head. You can try running the eliminate light stripes several times, and jet substitution, but most likely the print head will have to be replaced to remedy your problem.
You can try googling. Phaser printer print heads or phaser printheads.
There seems to be a secondary market appearing for those print heads. I can tell you from Xerox, if you have no maintenance agreement, they cost $750 per print head.
Honestly, having worked on about every type of color printer known to man, the new solid ink phaser printers, produce a dry ink image of 2400 x 2400 dpi with ink particles that align end to end. The resolution of those printers are remarkable and can be purchased for less than the price of one of those new print heads.
Now for reliable, albeit somewhat not as sharp a color image, but still exceptional, you really can not beat an HP.
The ink stick technology really no longer has the color vividness advantage it initially had. The inks that align end to end, have ended that advantage and are sure a lot cheaper to operate per page.
Feb 27, 2009 | Xerox Phaser 8400 Laser Printer
Bad photo quality after changing drum
your laser printer
1) print color quality is now distorted that means print skew (technician called)
2) print tint means the print color not enough density,
3) print mottle means print dirty
you may try
1) print distorted--- find out the skew adjustment from your printer manu, it is adjust the image before transfer to the drum.
2) print skew could be happened when the drum replace install not very accurate, so install it more carefully.
3) print tint---you may increase print density from the manu, not fix,
4) print tint---the toner caridge near life cycle or using the less compatible toner. so you have change the quality toner or cartridge (if near life cycle) to improve quality photo print
5)print mottle---toner quality ? or cartridge near life cycle also cause print dirty paper,
Feb 08, 2009 | Konica Minolta magicolor 2300DL Laser...
Downloading to computer
Sounds like a Vista or Picasso problem. Suggest you use explorer to copy photos directly from camera to a folder on your computer, then look at them and see if they are OK, if so, it is a Picasso problem. If the same, is likely a Vista problem. If still in doubt. Take memory stick to a photo lab and load on their system and see what you get.
Sep 20, 2008 | Sony Cyber-Shot DSC-W5 Digital Camera
HP LaserJet 2430n occasionally prints goblety-gook
ISSUE: When printing from the computer, you receive a line of garbage or all of the printed output comes out on one line. SOLUTION: See the following:
  1. Perform a self-test to be sure that the HP LaserJet printer is functioning properly. If the self-test is not correct, remove all cables and accessories (if any) and print a self-test again. If the self-test is still not correct, service the printer. If the self-test is correct, go to the next step.
  2. Reseat or replace the cable. Check the cable for bends or pressure applied by objects resting on the cable. A faulty cable or cables that do not meet the IEEE-1284 Standard can cause print defects by distorting signals.
Jan 09, 2008 | HP LaserJet 2430n Printer
Roland Versa Art RS 640 64-inch Printer Logo
65 people viewed this question
Top Roland Office Equipment & Supplies Experts
Chas Peters
Level 1 Expert
Michael Harrier
David Payne
David Payne
Are you a Roland Office Equipment and Supply Expert? Answer questions, earn points and help others
