Question about Creda C361E Electric Kitchen Range
C461e Do you know where we can purchase a replacement hob top? Thanks
  • Caroline Gibbs Jul 17, 2013
    We have a number of cracks in the hob glass on our creda c461e solarplus cooker and wondered if you knew where we could get a replacement. Thanks
Beko HII64403T induction hob, the left 2 rings packed in tonight, they went from 6 to E then turned off. the 2 right rings continued to work.
contact BEKO they will know why they did what they did and will know better what the fix will be . sounds like the 2 units might have burnt out due to not having the pots on them .
Nov 08, 2016 | Kitchen Ranges
Error code e9 on hob aeg hk85440075
From another Post from Daniel T:
E9 on this hob means a user interface control board fault. This is the touch control board which you press to turn on.
What the service manual says is disconnect the hob from the mains connection and leave for 60 seconds. Then wire it back up and turn back on and see what happens.
If still the same then the user control board needs to be replaced.
To access this you need to remove the hob from the work top and remove the screws holding the glass on all 4 sides of the hob.
Then you can lift the glass top off.
From there you will see the user board in the front its the smaller board.
Replace this and that should cure the fault here.
If you need anymore info just get back to me.
My Zanussi induction hob flashes an error code E9 when try
Oct 30, 2015 | AEG Washing Machines
Cannon Cambridge glass top
This would require a new hinge for the lid as they have an internal spring offering the resistance to keep the top in the up position
Apr 06, 2014 | Ovens
Bosch Ceran Schott hob. Number in top left corner
We have this exact same problem, and I've not managed to track down a manual (we rent and the landlord is on holiday).
I've tried holding down all buttons for a time, combinations of buttons, and turning it off at the mains, but no joy.
Did you ever solve this?
[submitting this as 'post solution' but there is no button for 'say you have the same problem'!]
May 27, 2010 | Bosch Cooktops
Want a narrow ceramic cook top / hob
Look at Baumatic 90cm Slimline 4 Hyperspeed Zone Ceramic Hob. Dimensions are 350mm x 880mm
Apr 26, 2010 | DeLonghi Cooktops
Black hob top cracked in two places and small part
yes but costly.have u tryed home insurance accidental damage.
Sep 14, 2009 | Cooktops
One of the knobs on my hob has got scorched but is working but I wanted to know if you can get replacement knobs for the hob. Thanks
Yes. If you're in the UK partsmaster will supply them. There is proabaly an equivalent in the US if you're there.
Aug 31, 2009 | Parkinson Cowan Kitchen Ranges
TOUCH CONTROL HOB (SCHOTT CERAM) GLASS CRACKED
Hi. Yes you can buy a new glass. Most of the come with frame top now. If you get me the model # I can look this up for you and get you an idea on cost.
Vic
May 18, 2009 | Cooktops
Installing Smeg Gas Hob PGF75-3 Ultra Low Profile.
yes u can install it at the top of the drawers but check the gas connection before closing the drawers to make sure ther no problem,the inlet gas connection is in rigth side facing to u.
Nov 28, 2008 | Smeg Cooktops
Neff 4 ring, ceremic top hob - how do I turn on!!
You press the "on" which is on the left. Press the picture of hob you require and press the up and down for temperature. Then put your pan on the hob and it will work. If you need to adjust the temp you need to remove the pan.
Oct 15, 2007 | Neff 23 in. T1443 Electric Cooktop
Creda C361E Electric Kitchen Range Logo
Top Creda Kitchen Ranges Experts
richie46
ray gallant
Pamela Leach
Pamela Leach
Are you a Creda Kitchen Range Expert? Answer questions, earn points and help others
