Go by a local air conditioner supply house and ask them. Usually if they can't get the part they know where to go to get parts for home appliances like Dehumidifers. Take the fan motor with you they may have something on the shelf that will work.
Do you have power to the fan motor? If you do have power to it the motor needs to be replaced good luck trying to find one and if you do find one you will pay a lot for it. Buy a new dehumidifier they are cheap and disposable.
Your call on the $39 replacement replacing the whole thing.
did the TCO you put int have the same specs (temperature) as the one you replaced? I've replaced a lot of these and they'll keep running.
The burning smell points to a failing coil which creates the heat which opens the TCO. you already know how to get the motor coil out so I think the $39 options is better.
Hi, If you are in new Zealand and your 880 model is the NZ 870 model, the fan motor can be got at Carrier Air Conditioning, part # SP-W3035766, for around $105.00.
If the blower motor is siezed up, then you need to replace the motor.
You can have new bearings put in it, but by the time you get thru it will cost you about the same as a new motor and you won't have any warranty on the old motor, you will have at least a one year warranty on the new one.
Hey, I need to buy a new fan motor and will share the install info once I install it myself. My question is: Where can I buy a fan motor for this unit?????
I've seen abunch of these. The fan motor has a fuse wound into the windings. It cannot be replaced you need a new fan motor. The motors seem to run hot normally, leading to a short lifespan.
I suggest buying a better brand unit.
