Question about Denso 2000 Nissan Sentra A/C Expansion Valve
Where is the expansion valve of a nissan sentra 2000
Where is the expansion valve?
Next to the blower motor,in a box,the freon has to be removed to replace expansion valve,took my Nissan truck to Midas to have one installed.Here's a link to a new one. Expansion Valve at AutoZone com Best Expansion Valve Parts for Cars Trucks... Here's another link,find the cooling unit,it's in their. SAVE 20 GET 10 GIFT CARD ON ONLINE SHIP TO HOME ORDERS OF 100 OR MORE
Sep 17, 2015 | 1997 Nissan Sentra
Where is expansion valve located
The Expansion valve is located in the evaporator box
On this year Nissan it's not to bad of a job. The dash doesn't need to be removed like the newer cars.
  1. To replace the expansion valve, you will need to discharge the AC system. Remove the two AC lines from the evaporator.
  2. Then you will need to remove the glove box
  3. Then you will need to unbolt the evaporator box
  4. Tip it back and remove.
  5. Once you have the evaporator box removed, then you can replace the expansion valve. I would also clean the evaporator box as well since you will have it removed.
May 20, 2015 | 1998 Nissan Sentra
How to replace expansion valve 2000 nissan xterra
You will have to remove the freon to do this,best to take to Midas and let them do it.
Aug 09, 2014 | 2000 Nissan Xterra
LOCATION PCV VALVE IN SENTRA B15 2000 GXE
look in or about valve cover,or under throttle body or near throttle body
Dec 18, 2010 | 2000 Nissan Sentra
I put a new catalytic converta on my Nissan sentra but i am still have a mis-fire what could i do next. 2000 Nissan sentra 1.8 gxe
Check your ignition timing! misfiring causes an advance opening and closing of the exhaust valve and overheating. have a mechanic to check on that w/ proper tools and module. taah!
Nov 17, 2010 | 2000 Nissan Sentra
2000 nissan sentra runs well on warm up, stalls in
Try to clean the throttle plate with a tooth brush and B-12 chemtool (parts store will have). Engine off / remove air inlet duct, open throttle, spray a little and clean thoroughly.
Nov 20, 2009 | 2000 Nissan Sentra
Air Conditioning cutting off and on
On a Fixed Orfice Tube system (FOT) the compressor cycles on and off because there is no other way to regulate the refrigerant. On a Thermal Expansion Valve system (which is what Nissan uses) the compressor stay on because the expansion valve regulates the refrigerant. It is not normal for your compressor to cycle on and off. Check your refrigerant level.
Jun 24, 2009 | 2004 Nissan Sentra
Why is the ac air conditioning not cooling
Could be low on freon, could be a bad compressor, could be a bad expansion valve, could be..... Get it checked out to find out for sure.
Jun 20, 2009 | 2001 Nissan Sentra
AIR CON NOT WORKING - NO COOLING
Could be an expansion valve or as well as the car might need a top-up of gas?
Nov 10, 2008 | 1994 Nissan Sentra 4-Door
Denso 2000 Nissan Sentra A/C Expansion Valve Logo
32 people viewed this question
Top Denso Heating & Cooling Experts
Paul Carew
Tim Whalen
Are you a Denso Heating and Cooling Expert? Answer questions, earn points and help others
