Question about Cowon J3 (16 GB) Digital Media Player
J3 turns off and reset won't help
How can I reset service spaner light on my 2015 Chery J3
Hi. Thanks for your question. You can follow some steps and reset the service spaner light on 2015 cher J3. For assistance you can visit https://www.reliable-store.com and download the entire workshop manual which includes all the information along with the diagrams for better understanding. Good day!
Feb 26, 2018 | Cars & Trucks
Tip
Sony PCG-7142L - VGN-NS110E CMOS Reset via jumper
This method will remove the master password from the system or reset the CMOS when the system will not boot to allow bios clearing.<br /> <br /> 1) First you need to remove the ram cover at the back of the unit.<br /> 2) Remove the battery from the unit<br /> 3) Remove the 2nd Dimm if it is there (the one closest to you)<br /> 4) Locate solder beads J3. This is what you will jump<br /> <br /> <br /> <img src="erustownsend_1.jpg" /> <br /> 5) Next you will need to lay the laptop on its' side.<br /> 6) Jump the J3 beads and then turn the unit on.<br /> 7) If you did this all correctly, the unit will clear its cmos and reset.<br /> 8) Turn unit off and then replace the memory, memory cover and battery.<br /> <br /> Good luck
on Mar 08, 2011 | Computers & Internet
How do I unlock my galaxy j3 forgotten my password
Pompeo, You may have to do a hard/factory reset to get it up and running. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
FAQ SAMSUNG J320P Galaxy J3 2016
How to Hard Reset Remove Password Samsung Galaxy Core Prime
How to reset your android if you forgot your password and google account
Galaxy J3 What do do if Forget my Screen Lock Password on my Samsung...
Jul 02, 2016 | Cell Phones
How to reformat j3
Restore the OS. Space my be corrupted or used up by old updates and cluttered files.
Mar 07, 2014 | Cowon J3 (16 GB) Digital Media Player
Digix bd 500. worked fine for a couple Weeks. now it froze up and won't turn on. the power lite is dimly blinking. but still won't turn on. is there a way to reset without turning on? I have check...
1) test the outlet wall for 120vac 2) test the power cord for open 3) test the power switch tv for defective 4) power supply inside faulty repair.
God bless you
Jul 25, 2013 | Televison & Video
Camshaft timing mark kia carnival j3 engine
As you haven\'t stated the year or your engine size or if diesel or petrol, I cant be bothered to look it up. But just in case this helps it is for a Carnival up 2009 2.0 K5 KV6 engine, (in the UK I have no idea what the J3 engine is) the only other information I have is the second pic for the 2.9 crdi KJ engine. Hope it helps
May 03, 2013 | Kia Carnival Cars & Trucks
1995 geo tracker won't start. I've replaced everything except the ignition switch. It used to click when i turn the key, now it won't even click.
DISCONNECT YOUR BATTERY AND RECONNECT, THIS SHOULD RESET THE BRAIN.
ALSO...WHEN YOU TURN THE KEY, LISTEN TO HEAR IF YOU CAN HEAR THE FUEL PUMP COME ON...IF NOT, GUESS WHAT? HOPEFULLY NOT!... BUT,YOU MAY NEED TO REPLACE THE FUEL PUMP, IF YOU CAN'T HEAR IT WHEN YOU TURN THE KEY, AFTER YOU'VE RESET THE BATTERY!
HOPE THIS HELPS!
Aug 30, 2011 | Geo Tracker Cars & Trucks
I have a GSL25JFPA BS that the frig side will not cool properly. Repalced the mother board. t stat in freezer and thermistor in frig. Freezer works fine. Damper will open when first plugged in but closes...
Unplug the refrigerator and then plug back in. Using multimeter check between J3-1 and J3-4.
Must be done within 10 seconds of starting. You should have 6 VDC. If you do replace damper, if not replace motherboard.
Jul 06, 2011 | GE GSL25JFPBS Side by Side Refrigerator
Phone Won't turn on past the samsung word..wondering if there's a reset button or something. Cuz it won't fully turn on
you can reset it by pulling out the battery for a minute or two and then reinstall it. If that does not do it you will have to take into a phone service center.
If this was helpful please give it a thumbs up to help others
May 17, 2011 | Cell Phones
Cowon J3 (16 GB) Digital Media Player Logo
Top Cowon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Cowon Audio Player and Recorder Expert? Answer questions, earn points and help others
