Question about Delphi Iat Sensor Driver Side Lh Left Hand Chevrolet G20 95 94 P30 Ts10072
Iat sensor location for astra 1.4l 16v 1999 - Delphi Iat Sensor Driver Side Lh Left Hand Chevrolet G20 95 94 P30 Ts10072
How to replace intake air temperature sensor 1993 sidekick jlx
there are 2 engines,
the 16valve 4 inject MPI
the 8valve 1 injector TBI
and the 1993 is the year and 92 may not have an IAT, 16v
all other 16v the IAT is in the air cleaner box, in plain site
the 8v all have IAT and are all in one place
seen here.
http://www.fixkick.com/sensors/8v-intake.JPG
http://www.fixkick.com/TBI-1w.jpg
16v is here.
http://www.fixkick.com/sensors/92-95induct.jpg
Jul 23, 2014 | 1993 Suzuki Sidekick
Where is the iat sensor located on 1995 geo tracker
93 or 95?
8v or 16valves.
ok , here are the facts.
all 8v are in the intake manifold just behind the ECT.
the 16v is always on the air cleaner box.
1992 16v the IAT is missing, that is correct. missing , on all USA kicks.
16v has 4 injectors and a MAF (apples and oranges different)
8v has 1 injector, and a MAP
der ohms.
http://www.fixkick.com/ECU/temp-sensors.html
Nov 27, 2013 | 1993 Geo Tracker
Where is the IAT sensor on a 1999 Ford Explorer SOHC V6?
The IAT sensor and your Mass Air Flow sensor will be one in the same located near your filter box on the intake tube
Mar 07, 2011 | 1999 Ford Explorer
Where is the iat sensor located on a 1999 chevy cavalier 4cyl
The Intake Air Temperature (IAT) sensor determines the air temperature inside the intake manifold. Resistance changes in response to the ambient air temperature. The sensor has a negative temperature coefficient. As the temperature of the sensor rises the resistance across the sensor decreases. This provides a signal to the PCM indicating the temperature of the incoming air charge. This sensor helps the PCM to determine spark timing and air/fuel ratio. Information from this sensor is added to the pressure sensor information to calculate the air mass being sent to the cylinders. The IAT is a two wire sensor, a 5-volt reference signal is sent to the sensor and the signal return is based upon the change in the measured resistance due to temperature.
Fig. 1: The IAT sensor is located in the air cleaner outlet tube-2.2L engine and 2.4L engine
Hope helped.
Apr 11, 2010 | 1999 Chevrolet Cavalier
Location of IAT sensor in the car?
For Hyundai Car 1999-05 - Intake Air Temperature (IAT) Sensor Location (check several options):
1.- The IAT sensor is located against the firewall to the left side of the engine. It is combined with the Manifold Absolute Pressure (MAP) sensor.
2.- This sensor is located in the air intake plenum assembly. On some vehicles this sensor is combined with the MAP/MAF sensor.
3.- The IAT sensor is located in the air plenum assembly. On some vehicles it is combined with the MAF sensor.
4.- This sensor is located in the air intake plenum assembly. On some vehicles this sensor is combined with the MAP/MAF sensor.
5.- This sensor is located in the air intake plenum assembly. It is combined with the Manifold Absolute Pressure (AFS) sensor.
6.- This sensor is located in the air intake plenum assembly. It is combined with the Manifold Absolute Pressure (AFS) sensor.
In the next graphic, check the position 2...
FIG : Underhood sensor locations-Elantra 2004-2005 2.0L engine
Hope this help (remember comment and rated this) TY for using Fixya.
Apr 08, 2010 | 2004 Hyundai Elantra
Opel Astra 1600 16v jerking at low rpms when car
i got opel astra 160i 95 model. it jerks when the engine is hot/warm when excellerating.
Jun 09, 2009 | 1999 Chevrolet K1500
IAT sensor location
Don't even bother installing that, it won't do you any good! Check out the reason why here.
Mar 25, 2009 | 1999 Cadillac Seville
IAT Location Buick Regal 1999
iat screws into intake mine has two wires different year though.
Jan 20, 2009 | 1991 Buick LeSabre
I need to located the IAT sensor for a 1999 FORD F-250 disel 7.3
should be in the air intake tube or filter box
Jan 17, 2009 | 1987 Ford Escort
Delphi Iat Sensor Driver Side Lh Left Hand Chevrolet G20 95 94 P30 Ts10072 Logo
18 people viewed this question
Top Delphi Car Audio & Video Experts
Billy Mac
Lawrence Oravetz
Jeremiah Meyer
Jeremiah Meyer
Are you a Delphi Car Audio and Video Expert? Answer questions, earn points and help others
